deployprobe.g for Euclid not running
@adamfilip so if your X and Y (assuming they are driver 0 and 1) aren't homed, it should home. If they are homed, it should echo stop1.
Are you trying this with or without the motors homed? -
I run this after i have already homed
this is my config if it helps
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.5 on Wed Jan 08 2020 19:38:55 GMT-0500 (Eastern Standard Time) ; General preferences ;M564 H0 ; allow movement without homing G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"TitanXY" ; set printer name M669 K0 ; Motion Kinematics for Cartesian mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; X Motor physical drive 0 goes backwards previously P0 M569 P1 S1 ; Y Motor M569 P2 S1 ; Z physical drive 2 goes backwards M569 P3 S1 ; E0 Extruder physical drive 3 goes Forwards ;M569 P4 S1 ; 2nd Y Motor on E1 Driver M584 X0 Y1 Z2 E3 ; set drive mapping , Y is on two drivers. E1 as well M350 X16 Y16 Z4 I1 ; configure microstepping without interpolation, previously 32 M350 E16 I1 ; configure microstepping with interpolation M92 X80 Y80 Z800 E409 ; set steps per mm M566 X900 Y900 Z50 E1600 ; Set maximum instantaneous speed changes (mm/min) JERK M203 X21000 Y21000 Z500 E10000 ; Set maximum speeds (mm/min) M201 X2000 Y2000 Z50 E5000 ; Set accelerations (mm/s^2) ;M204 P1000 T3000 ; Set printing and travel accelerations M906 X1100 Y1100 Z1200 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent X1400 Y1400 Z1300 M84 S30 ; Set idle timeout M572 D0 S0.01 ; Pressure Advance ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X300 Y300 Z550 S0 ; set axis maxima ; Endstops M574 X2 S1 P"!xstop" ; X max active high endstop switch M574 Y2 S1 P"!ystop" ; Y max active high endstop switch M574 Z1 S1 P"!zstop" ; Z min active high endstop switch ;Euclid Settings M574 E1 S2 ; M558 K0 P5 C"^zprobe.in" H4 F500 60 T9000 A1 S0.01 G31 K0 P500 X0 Y-39 Z3.55 M557 X10:290 Y10:290 S40 ; define mesh grid S86 = Spacing 86mm ;Magnetic Filament Monitor ;M591 D0 P3 C"e1_stop" S1 ; filament monitor connected to E0_stop ;M591 D0 ; display filament sensor parameters for extruder drive 0 ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M140 H0 ; Map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M307 H1 B0 R1.591 C187.0:154.2 D7.57 S1.00 V24.1 M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S285 ; set temperature limit for heater 1 to 280C M307 H1 R1.71 C175.5:157.9 D5.73 S1.00 V24.1 ;Chamber Temp M308 S2 P"Chamber" Y"thermistor" T100000 B4725 C7.06e-8 A"Chamber" ; Fans M950 F0 C"fan2" Q500 ;create fan 2 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off ;M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency ;M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ;M950 F2 C"fan1" Q500 ; create fan 2 on pin fan1 and set its frequency ;M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ;M564 S0 H0 ;disable homing and no limits on movement
@adamfilip it should just run then. I don't see anything wrong with the logic.
What version of RRF are you running? -
Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.1 (2022-06-01)
Duet WiFi Server Version: 1.26 -
If you have two steppers for the Y axis why do they not appear in your M584 commands?
Normally it would look like this (based on the comments):
M584 X0 Y1:4 Z2 E3
@fcwilt actually I use too, its changed to only a signal Y.
sorry some old notes still linger -
@jay_s_uk yeah its weird.
I restarted the machine. did home all.
ran the macro and nothing.
not even the first echo statement showed up in console -
I copied the entire deployprobe.g code into a macro and it runs on its own
so it seems like the deployprobe.g itself isnt being run when asked with
M401 P1 ;Deployprobe -
Just to provide another point of view.
I no longer home things as needed because I found I did not like homing taking place unexpectedly because I had tried to do something that required the printer to be homed, like mount the probe.
So now I just check that the printer is homed and abort if it is not.
I have a Euclid on one of my printers but I don't use the deploy/retract feature that is part of the firmware. I call my routines to mount/unmount the probe as needed. I have found that for normal operations I can keep the probe mounted except during actual printing. Any operation that needs the probe, such as setting the Z=0 Datum, mounts the probe and leaves it mounted. In the print start code just before actual printing begins the probe is unmounted.
Just food for thought.
@adamfilip said in deployprobe.g for Euclid not running:
M401 P1 ;DeployprobeDoesn't the firmware track the state of the probe and only run the deploy/retract routines when it thinks it needs to?
@adamfilip If the euclid is your only probe, drop the
P1
and only run M401. Alternately, try P0 because your probe definition assignes ID 0. -
@oliof Thank you both M401 and M401 P0 worked!
@adamfilip only other error im getting in console is
Probe Pickup complete
Warning: G3000: Command is not supported -
G90 ; absolute positioning G0 X150 Y150 G3000 ; move to the center of the bed M400 ; wait for moves to finish
@adamfilip probably just a typo and should be F
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
