error reading -273.1
hello i have this error my bed Sensor 0 type Thermistor using pin bedtemp, reading -273.1, last error: sensor open circuit, T:100000.0 B:3950.0 C:0.00e+0 R:4700.0 L:0 H:0 help
@sgk
@sgk that means its not wired correctly or you're using the wrong thermistor input in your config.g
@jay_s_uk
I didn't do anything it works before I just installed a mks mosfet and after I got that I put it back as before without the mosfet and now I have this error -
@sgk better check your wiring then as something has come loose
@sgk
@jay_s_uk
the cables are well connected I really do not understand -
if the wires are fine, you may have connected the thermistor in the wrong place or defined the wrong pins.
I understand what you're trying to tell me except that I didn't change anything and before it worked perfectly
@sgk well theres no other answer to give you. if you didn't change the config at all then its definitely wiring
@jay_s_uk i have this Error: Temperature reading fault on heater 0: sensor open circuit
@sgk yes, because your wiring has issues. no connection = open circuit
@sgk If you are unwilling to check what the error points at, we can't help you. Insisting it worked before is not helping.
@oliof OK I will check the cabling
@sgk find the problem with the hs bed thermistor probe thank you
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
@sgk problem solved it was the thermistor of the bed hs thank you to you
