    error reading -273.1
    461
      A Former User @A Former User
        A Former User @jay_s_uk
        @jay_s_uk
        the cables are well connected I really do not understand
        • oliofundefined
          oliof @A Former User
          if the wires are fine, you may have connected the thermistor in the wrong place or defined the wrong pins.
            A Former User @oliof
            I understand what you're trying to tell me except that I didn't change anything and before it worked perfectly
            jay_s_ukundefined oliofundefined 2 Replies Last reply Reply Quote 0
              jay_s_uk @A Former User
              @sgk well theres no other answer to give you. if you didn't change the config at all then its definitely wiring
                @jay_s_uk i have this Error: Temperature reading fault on heater 0: sensor open circuit
                  @sgk yes, because your wiring has issues. no connection = open circuit
                  • oliofundefined
                    @sgk If you are unwilling to check what the error points at, we can't help you. Insisting it worked before is not helping.
                      @oliof OK I will check the cabling
                        @sgk find the problem with the hs bed thermistor probe thank you
                        • Phaedruxundefined Phaedrux has marked this topic as solved
                          @sgk problem solved it was the thermistor of the bed hs thank you to you👍
