Hotend temperature not rising at all
494
    Velvia
    I have a 50w cartridge connected to a duet smart effector, to the H+ and H- input. I have tested the cables with a volt meter. I've also tried with a different cartridge. Here's my config and M122
    M308 S0 P"temp1" Y"thermistor" T118000 B3950 ; configure sensor 0 as thermistor on pin temp1
    M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
    M308 S1 P"temp0" Y"pt1000" ; configure sensor 1 as PT1000 on pin temp0
    M950 H1 C"out2" T1 ; create nozzle heater output on out2 and map it to sensor 1
    M143 H1 S350 ; set temperature limit for heater 1 to 350C
    M950 F1 C"out9" Q400 ; create fan 1 on pin out9 and set its frequency
    M106 P1 S0 H1 T50 ; set fan 1 value. Thermostatic control is turned on
    M950 F2 C"out6" Q500 ; create fan 2 on pin out6 and set its frequency
    M106 P2 S0.5 H-1 ; set fan 2 value. Thermostatic control is turned off
    M563 P0 S"DragonHF" D0 H1 F0 ; define tool 0
    M112
    M122
    RepRapFirmware for Duet 3 MB6HC version 3.4.1 (2022-06-01 21:09:01) running on Duet 3 MB6HC v1.01 or later (SBC mode)
    Board ID: 08DJM-9P63L-DJ3S0-7JKF0-3S86T-TAJR8
    Used output buffers: 1 of 40 (12 max)
    Static ram: 151000
    Dynamic ram: 64368 of which 24 recycled
    Never used RAM 135160, free system stack 156 words
    Tasks: SBC(ready,0.5%,476) HEAT(notifyWait,0.0%,318) Move(notifyWait,0.0%,267) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.0%,333) TMC(notifyWait,7.7%,92) MAIN(running,91.4%,1231) IDLE(ready,0.3%,30), total 100.0%
    Owned mutexes: HTTP(MAIN)
    Last reset 00:04:55 ago, cause: software
    Last software reset at 2022-06-20 00:17, reason: User, GCodes spinning, available RAM 135280, slot 2
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
    Error status: 0x00
    Aux0 errors 0,0,0
    Step timer max interval 134
    MCU temperature: min 37.2, current 37.4, max 37.9
    Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
    12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
    Events: 1 queued, 1 completed
    Driver 0: standstill, SG min 0, mspos 840, reads 11182, writes 19 timeouts 0
    Driver 1: standstill, SG min 0, mspos 904, reads 11182, writes 19 timeouts 0
    Driver 2: standstill, SG min 0, mspos 24, reads 11182, writes 19 timeouts 0
    Driver 3: standstill, SG min 0, mspos 8, reads 11187, writes 14 timeouts 0
    Driver 4: standstill, SG min 0, mspos 8, reads 11190, writes 11 timeouts 0
    Driver 5: standstill, SG min 0, mspos 8, reads 11190, writes 11 timeouts 0
    Date/time: 2022-06-20 00:22:05
    Slowest loop: 37.38ms; fastest: 0.04ms
    === Storage ===
    Free file entries: 10
    DMs created 125, segments created 5, maxWait 23082ms, bed compensation in use: none, comp offset 0.000
    === MainDDARing ===
    Scheduled moves 5, completed 5, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
    === AuxDDARing ===
    Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
    Segments left: 0
    Movement lock held by null
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Queue is idle in state(s) 0
    LCD is idle in state(s) 0
    SBC is idle in state(s) 0
    Daemon is idle in state(s) 0
    Aux2 is idle in state(s) 0
    Code queue is empty
    === CAN ===
    Messages queued 2639, received 0, lost 0, boc 0
    Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 1477/0/0
    Tx timeouts 0,0,1476,0,0,1161 last cancelled message type 30 dest 127
    === SBC interface ===
    Transfer state: 5, failed transfers: 0, checksum errors: 0
    RX/TX seq numbers: 12038/12038
    SPI underruns 0, overruns 0
    State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2b880
    Buffer RX/TX: 0/0-0, open files: 0
    === Duet Control Server ===
    Duet Control Server v3.4.1
    Code buffer space: 4096
    Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
    Full transfers per second: 41.00, max time between full transfers: 241.3ms, max pin wait times: 76.3ms/18.8ms
    Codes per second: 0.25
    Maximum length of RX/TX data transfers: 3080/992
    Whenever I try to heat it, I just get:
    Error: Heater 1 fault: temperature rising too slowly: expected 2.32°C/sec measured 0.00°C/sec
    Homegrown, grass fed and organically built 350mm delta
    undefined 1 Reply Last reply 19 Jun 2022, 22:52 Reply Quote 0
      fcwilt @Velvia
      @velvia
      I don't know the ins and outs of the "smart effector".
      How does it connect to the 6HC board?
      undefined 1 Reply Last reply 19 Jun 2022, 22:55 Reply Quote 0
        Velvia @fcwilt
        @fcwilt to a 2-pin connector at "out_2"
        undefined 1 Reply Last reply 19 Jun 2022, 22:57 Reply Quote 0
          fcwilt @Velvia
          @velvia said in Hotend temperature not rising at all:
          And it also connects to "temp0"?
          undefined 1 Reply Last reply 19 Jun 2022, 23:03 Reply Quote 0
            Velvia @fcwilt
            @fcwilt pt1000 to temp_0, yes. It reads the temp fairly correctly +/- 1-2 degrees, but cartridge won't start heating at all.
            undefined 1 Reply Last reply 19 Jun 2022, 23:10 Reply Quote 0
              fcwilt @Velvia
              Have you run heater tuning yet?
              Example: M303 H1 S200
              undefined 1 Reply Last reply 19 Jun 2022, 23:11 Reply Quote 0
                Velvia @fcwilt
                @fcwilt Yes, but it fails, since it won't start heating at all. It works fine for the bed.
                undefined 1 Reply Last reply 19 Jun 2022, 23:20 Reply Quote 0
                  fcwilt @Velvia
                  @velvia
                  Well seems to me that problems must be:
                  • in the wiring
                  • with the board output
                  You say have tested the wiring.
                  Have you tried connecting to the out1 connections - with the appropriate changes to the **config.**g file - just to see if the problems line with out2?
                  undefined 1 Reply Last reply 19 Jun 2022, 23:40 Reply Quote 0
                    Velvia @fcwilt
                    @fcwilt out1 is the heatbed. I have tested out3, and still the same issue. It could still be the wiring, I'm just not sure how to test it other than with a volt meter. Maybe I've connected it wrong on the smart effector, I don't know.
                    https://docs.duet3d.com/hardware/smart_effector/smart_effector_v2_wiring.png
                    I connected the output from the mainboard to the ones circled in green. And HEATER to the heating cartridge in the hotend.
                    undefined 1 Reply Last reply 19 Jun 2022, 23:50 Reply Quote 0
                      fcwilt @Velvia
                      @velvia
                      There is a problem with that diagram unrelated to your issue. Notice on the input H+ is shown as a solid yellow shape. On the heater output H+ is shown as a yellow/black shape. It means nothing from a practical point of view since heaters don't have polarity.
                      You mention that out 1 is the heated bed. So you are not using the actual bed heater output, out 0?
                      If you have tested both out 2 and out 3 then the problem must lie in the wiring.
                      What do you get when you measure the resistance across the lead ends that connect to the 6HC?
                      undefined 1 Reply Last reply 20 Jun 2022, 00:00 Reply Quote 0
                        Velvia @fcwilt
                        @fcwilt said in Hotend temperature not rising at all:
                        Nothing. It seems to be a poor connection/crimp. Not the first time during this build. I'll try redoing it. It was very hard, since I had to use thick cables for tiny crimps.
                        undefined 1 Reply Last reply 20 Jun 2022, 00:04 Reply Quote 0
                          fcwilt @Velvia
                          The connectors used for those outputs accept fairly large wires easily.
                          What size wire are you using?
                          What sort of crimp tool are you using?
                          undefined 1 Reply Last reply 20 Jun 2022, 00:06 Reply Quote 0
                            Velvia @fcwilt
                            @fcwilt You're right, the output side is fine, but the input on the smart effector is terrble.
                            undefined undefined 2 Replies Last reply 20 Jun 2022, 00:08 Reply Quote 0
                              Velvia @Velvia
                              @velvia 18 AWG
                              undefined 1 Reply Last reply 20 Jun 2022, 00:11 Reply Quote 0
                                Velvia @Velvia
                                @velvia Tested the wires again, red to red and black to black, no problems. They are both whole.
                                undefined 1 Reply Last reply 20 Jun 2022, 00:13 Reply Quote 0
                                  fcwilt @Velvia
                                  You mean to say they did not use the same connectors for both the input and output connections?
                                  That is not a good idea at all.
                                  You can always "cheat" a little. Short lengths of small gauge wires are not going to be a problem.
                                  So if you have the tools you could solder and heat-shrink two 50mm lengths (or so) of small gauge wire to the long large gauge wires coming from the 6HC. That would make crimping the small connectors much easier.
                                    fcwilt @Velvia
                                    You need to verify the resistance across the ends of the two wires that would connect to the 6HC.
                                    undefined 1 Reply Last reply 20 Jun 2022, 00:30 Reply Quote 0
                                      Velvia @fcwilt
                                      @fcwilt Did that now and discovered the issue. Yet another poor crimp by me. It threw me off since it worked the first time I tested it. Now the heater works
                                      undefined 1 Reply Last reply 20 Jun 2022, 00:34 Reply Quote 1
                                        fcwilt @Velvia
                                        @velvia
                                        Glad to hear you got it sorted.
                                          Velvia @fcwilt
                                          @fcwilt Thank you for all the help!
                                          undefined 1 Reply Last reply 20 Jun 2022, 00:39 Reply Quote 0
                                          9 out of 21
