    Hotend temperature not rising at all
    518
    • Velviaundefined
      Velvia @fcwilt
      @fcwilt out1 is the heatbed. I have tested out3, and still the same issue. It could still be the wiring, I'm just not sure how to test it other than with a volt meter. Maybe I've connected it wrong on the smart effector, I don't know.
      https://docs.duet3d.com/hardware/smart_effector/smart_effector_v2_wiring.png
      I connected the output from the mainboard to the ones circled in green. And HEATER to the heating cartridge in the hotend.
      Homegrown, grass fed and organically built 350mm delta
      • fcwiltundefined
        fcwilt @Velvia
        @velvia
        There is a problem with that diagram unrelated to your issue. Notice on the input H+ is shown as a solid yellow shape. On the heater output H+ is shown as a yellow/black shape. It means nothing from a practical point of view since heaters don't have polarity.
        You mention that out 1 is the heated bed. So you are not using the actual bed heater output, out 0?
        If you have tested both out 2 and out 3 then the problem must lie in the wiring.
        What do you get when you measure the resistance across the lead ends that connect to the 6HC?
        Velviaundefined 1 Reply Last reply Reply Quote 0
        • Velviaundefined
          Velvia @fcwilt
          @fcwilt said in Hotend temperature not rising at all:
          Nothing. It seems to be a poor connection/crimp. Not the first time during this build. I'll try redoing it. It was very hard, since I had to use thick cables for tiny crimps.
          • fcwiltundefined
            fcwilt @Velvia
            @velvia said in Hotend temperature not rising at all:
            The connectors used for those outputs accept fairly large wires easily.
            What size wire are you using?
            What sort of crimp tool are you using?
            • Velviaundefined
              Velvia @fcwilt
              @fcwilt You're right, the output side is fine, but the input on the smart effector is terrble.
              Velviaundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
              • Velviaundefined
                Velvia @Velvia
                @velvia 18 AWG
                • Velviaundefined
                  Velvia @Velvia
                  @velvia Tested the wires again, red to red and black to black, no problems. They are both whole.
                  • fcwiltundefined
                    fcwilt @Velvia
                    You mean to say they did not use the same connectors for both the input and output connections?
                    That is not a good idea at all.
                    You can always "cheat" a little. Short lengths of small gauge wires are not going to be a problem.
                    So if you have the tools you could solder and heat-shrink two 50mm lengths (or so) of small gauge wire to the long large gauge wires coming from the 6HC. That would make crimping the small connectors much easier.
                    • fcwiltundefined
                      fcwilt @Velvia
                      You need to verify the resistance across the ends of the two wires that would connect to the 6HC.
                      • Velviaundefined
                        Velvia @fcwilt
                        @fcwilt Did that now and discovered the issue. Yet another poor crimp by me. It threw me off since it worked the first time I tested it. Now the heater works
                        • fcwiltundefined
                          fcwilt @Velvia
                          @velvia
                          Glad to hear you got it sorted.
                          Velviaundefined 1 Reply Last reply Reply Quote 1
                          • Velviaundefined
                            Velvia @fcwilt
                            @fcwilt Thank you for all the help!
                            • fcwiltundefined
                              fcwilt @Velvia
                              Any time.
                              • Phaedruxundefined Phaedrux has marked this topic as solved
