    Hotend temperature not rising at all
    519
    • Velviaundefined
      Velvia @fcwilt
      @fcwilt pt1000 to temp_0, yes. It reads the temp fairly correctly +/- 1-2 degrees, but cartridge won't start heating at all.
      Homegrown, grass fed and organically built 350mm delta
      • fcwiltundefined
        fcwilt @Velvia
        @velvia said in Hotend temperature not rising at all:
        Have you run heater tuning yet?
        Example: M303 H1 S200
        Velviaundefined 1 Reply Last reply Reply Quote 0
        • Velviaundefined
          Velvia @fcwilt
          @fcwilt Yes, but it fails, since it won't start heating at all. It works fine for the bed.
          • fcwiltundefined
            fcwilt @Velvia
            @velvia
            Well seems to me that problems must be:
            • in the wiring
            • with the board output
            You say have tested the wiring.
            Have you tried connecting to the out1 connections - with the appropriate changes to the **config.**g file - just to see if the problems line with out2?
            • Velviaundefined
              Velvia @fcwilt
              @fcwilt out1 is the heatbed. I have tested out3, and still the same issue. It could still be the wiring, I'm just not sure how to test it other than with a volt meter. Maybe I've connected it wrong on the smart effector, I don't know.
              https://docs.duet3d.com/hardware/smart_effector/smart_effector_v2_wiring.png
              I connected the output from the mainboard to the ones circled in green. And HEATER to the heating cartridge in the hotend.
              • fcwiltundefined
                fcwilt @Velvia
                @velvia
                There is a problem with that diagram unrelated to your issue. Notice on the input H+ is shown as a solid yellow shape. On the heater output H+ is shown as a yellow/black shape. It means nothing from a practical point of view since heaters don't have polarity.
                You mention that out 1 is the heated bed. So you are not using the actual bed heater output, out 0?
                If you have tested both out 2 and out 3 then the problem must lie in the wiring.
                What do you get when you measure the resistance across the lead ends that connect to the 6HC?
                • Velviaundefined
                  Velvia @fcwilt
                  @fcwilt said in Hotend temperature not rising at all:
                  Nothing. It seems to be a poor connection/crimp. Not the first time during this build. I'll try redoing it. It was very hard, since I had to use thick cables for tiny crimps.
                  • fcwiltundefined
                    fcwilt @Velvia
                    The connectors used for those outputs accept fairly large wires easily.
                    What size wire are you using?
                    What sort of crimp tool are you using?
                    • Velviaundefined
                      Velvia @fcwilt
                      @fcwilt You're right, the output side is fine, but the input on the smart effector is terrble.
                      Velviaundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                      • Velviaundefined
                        Velvia @Velvia
                        @velvia 18 AWG
                        • Velviaundefined
                          Velvia @Velvia
                          @velvia Tested the wires again, red to red and black to black, no problems. They are both whole.
                          • fcwiltundefined
                            fcwilt @Velvia
                            You mean to say they did not use the same connectors for both the input and output connections?
                            That is not a good idea at all.
                            You can always "cheat" a little. Short lengths of small gauge wires are not going to be a problem.
                            So if you have the tools you could solder and heat-shrink two 50mm lengths (or so) of small gauge wire to the long large gauge wires coming from the 6HC. That would make crimping the small connectors much easier.
                            • fcwiltundefined
                              fcwilt @Velvia
                              You need to verify the resistance across the ends of the two wires that would connect to the 6HC.
                              • Velviaundefined
                                Velvia @fcwilt
                                @fcwilt Did that now and discovered the issue. Yet another poor crimp by me. It threw me off since it worked the first time I tested it. Now the heater works
                                • fcwiltundefined
                                  fcwilt @Velvia
                                  @velvia
                                  Glad to hear you got it sorted.
                                  Velviaundefined 1 Reply Last reply Reply Quote 1
                                  • Velviaundefined
                                    Velvia @fcwilt
                                    @fcwilt Thank you for all the help!
                                    • fcwiltundefined
                                      fcwilt @Velvia
                                      Any time.
                                      • Phaedruxundefined Phaedrux has marked this topic as solved
