    Hotend temperature not rising at all
    519
    • fcwiltundefined
      fcwilt @Velvia
      @velvia said in Hotend temperature not rising at all:
      @fcwilt pt1000 to temp_0, yes. It reads the temp fairly correctly +/- 1-2 degrees, but cartridge won't start heating at all.
      Have you run heater tuning yet?
      Example: M303 H1 S200
      Velviaundefined 1 Reply Last reply Reply Quote 0
      • Velviaundefined
        Velvia @fcwilt
        @fcwilt Yes, but it fails, since it won't start heating at all. It works fine for the bed.
        Homegrown, grass fed and organically built 350mm delta
        • fcwiltundefined
          fcwilt @Velvia
          @velvia
          Well seems to me that problems must be:
          • in the wiring
          • with the board output
          You say have tested the wiring.
          Have you tried connecting to the out1 connections - with the appropriate changes to the **config.**g file - just to see if the problems line with out2?
          • Velviaundefined
            Velvia @fcwilt
            @fcwilt out1 is the heatbed. I have tested out3, and still the same issue. It could still be the wiring, I'm just not sure how to test it other than with a volt meter. Maybe I've connected it wrong on the smart effector, I don't know.
            https://docs.duet3d.com/hardware/smart_effector/smart_effector_v2_wiring.png
            I connected the output from the mainboard to the ones circled in green. And HEATER to the heating cartridge in the hotend.
            • fcwiltundefined
              fcwilt @Velvia
              @velvia
              There is a problem with that diagram unrelated to your issue. Notice on the input H+ is shown as a solid yellow shape. On the heater output H+ is shown as a yellow/black shape. It means nothing from a practical point of view since heaters don't have polarity.
              You mention that out 1 is the heated bed. So you are not using the actual bed heater output, out 0?
              If you have tested both out 2 and out 3 then the problem must lie in the wiring.
              What do you get when you measure the resistance across the lead ends that connect to the 6HC?
              • Velviaundefined
                Velvia @fcwilt
                @fcwilt said in Hotend temperature not rising at all:
                Nothing. It seems to be a poor connection/crimp. Not the first time during this build. I'll try redoing it. It was very hard, since I had to use thick cables for tiny crimps.
                • fcwiltundefined
                  fcwilt @Velvia
                  The connectors used for those outputs accept fairly large wires easily.
                  What size wire are you using?
                  What sort of crimp tool are you using?
                  • Velviaundefined
                    Velvia @fcwilt
                    @fcwilt You're right, the output side is fine, but the input on the smart effector is terrble.
                    Velviaundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                    • Velviaundefined
                      Velvia @Velvia
                      @velvia 18 AWG
                      • Velviaundefined
                        Velvia @Velvia
                        @velvia Tested the wires again, red to red and black to black, no problems. They are both whole.
                        • fcwiltundefined
                          fcwilt @Velvia
                          You mean to say they did not use the same connectors for both the input and output connections?
                          That is not a good idea at all.
                          You can always "cheat" a little. Short lengths of small gauge wires are not going to be a problem.
                          So if you have the tools you could solder and heat-shrink two 50mm lengths (or so) of small gauge wire to the long large gauge wires coming from the 6HC. That would make crimping the small connectors much easier.
                          • fcwiltundefined
                            fcwilt @Velvia
                            You need to verify the resistance across the ends of the two wires that would connect to the 6HC.
                            • Velviaundefined
                              Velvia @fcwilt
                              @fcwilt Did that now and discovered the issue. Yet another poor crimp by me. It threw me off since it worked the first time I tested it. Now the heater works
                              • fcwiltundefined
                                fcwilt @Velvia
                                @velvia
                                Glad to hear you got it sorted.
                                Velviaundefined 1 Reply Last reply Reply Quote 1
                                • Velviaundefined
                                  Velvia @fcwilt
                                  @fcwilt Thank you for all the help!
                                  • fcwiltundefined
                                    fcwilt @Velvia
                                    Any time.
                                    • Phaedruxundefined Phaedrux has marked this topic as solved
