    BtnCmd-DWC Plugin - Customise DWC - v01.04.00 29-05-25
    Plugins for DWC and DSF
    27
    245
    40.2k
    • MintyTreborundefined
      MintyTrebor @mrwulff
      @mrwulff I cannot replicate this behaviour.
      I tell a lie - I have just replicated it - let me look into it.
      NodeDSF - Native Node-Red integration with Duet boards.
      BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
      ReleaseMgr - Duet update info inside DWC.
      Repo
        @mrwulff I found the issue. I will push an update out later once I have run some quick sanity checks.
        Repo
          @mrwulff Published v0.10.09
          Changes:
          • fixed resizing issue with custom panels
          • removed Event feature
          As previously noted in the last release - this version depreciates the Event system from BtnCmd. I have depreciated this feature as the introduction of 'tab sleeping' by many of the main browsers causes issues for this feature, plus the functionality no longer aligns with the core of BtnCmd.
          Repo
          MintyTreborundefined 1 Reply Last reply Reply Quote 0
            MintyTrebor @MintyTrebor
            Published Beta 0.10.10 for DWC 3.4
            Changes:
            • Updated Alt Web Cam panel to align with recent DWC webcam changes
            • Removed >= 5000 ms update interval requirement from Alt Web Cam Panel settings
            • Added CNC Panels :
              • CNC Info Panel
              • CNC Movement Panel
              • CNC Spindle Speed Panel
            • Added CNC detection - Available Panels will now be filtered based on FFF/CNC operating mode
            Repo
            o_lampeundefined 1 Reply Last reply Reply Quote 1
            • o_lampeundefined
              o_lampe @MintyTrebor
              @mintytrebor said in BtnCmd-DWC Plugin-Custom Layouts & Buttons - v0.10.10 08-06-22:
              I want to try your plugin for a CNC/Laser combo machine I'm currently building. Will there be a difference in panel availability, if I switch back_and_forth from laser- to CNC-mode too?
              Or is there a combo mode possible that would show laser panels and CNC at the same time?
                MintyTrebor @o_lampe
                @o_lampe I released an update 2 mins ago to allow the Panels in both Laser & CNC mode 😊
                https://github.com/MintyTrebor/BtnCmd/releases
                Repo
                • chrishammundefined chrishamm referenced this topic
                • Adamfilipundefined
                  Adamfilip
                  Is there someplace to download different configurations of entire layouts of panels and buttons.
                  or a way to load user created custom panels themselves.
                  would be great if we could share various configurations to get us 90% of the way there.
                  MintyTreborundefined 2 Replies Last reply Reply Quote 2
                    MintyTrebor @Adamfilip
                    @adamfilip said in BtnCmd-DWC Plugin-Custom Layouts & Buttons - v0.10.11 11-06-22:
                    There is no functionality to share custom panels/layouts. Only the backup and restore feature. I will add the request to the wish list, and look into it.
                    Repo
                      @adamfilip
                      Released BtnCmd Beta 0.10.12
                      Change-Log:
                      • Added Import / Export feature
                      • Changed Backup Icon actions
                      Notes on Import / Export:
                      Importing Layouts and custom panels designed on a different screen resolution may result in objects displaying incorrectly. This limitation cannot be changed.
                      Repo
                      Adamfilipundefined 1 Reply Last reply Reply Quote 2
                        Adamfilip @MintyTrebor
                        @mintytrebor Thank you!
                        Now we just need people to export their custom layouts / panels. 🙂
                        If you make one please share here with a screen capture of how it looks and a download link
                          Published BtnCmd Beta 0.10.13
                          Changes:
                          • Enabled Auto Restore Feature - read more here
                          • New Experimental Feature for SBC users - read more here
                          • Added the ability to include object model values in MQTT msgs, and HTTP Post data - read more here
                          Repo
                          Adamfilipundefined 1 Reply Last reply Reply Quote 0
                            @mintytrebor
                            Anyway to enable responsive layout with mobile.
                            cant even scroll unfortunately.
                            PC
                            Iphone
                              @adamfilip https://github.com/MintyTrebor/BtnCmd/wiki/Edit-Mode
                              Repo
                                @mintytrebor "General Notes On Layouts:
                                BtnCmd uses absolute pixel positions to locate and fix the size of objects in layouts. This means that opening a layout on a screen with a different resolution to the original will have various impacts on the original positions of the objects - this is especially true when opening a layout designed on a desktop on a mobile device. Dynamic scaling for different resolutions will not work for BtnCmd layouts."
                                Would be nice to make the layouts responsive to different screen sizes
                                • M7460undefined
                                  M7460
                                  Hi , can this plugin change the PanleDue screen ?
                                  Thanks
                                    MintyTrebor @M7460
                                    @m7460 No
                                    Repo
                                    M7460undefined 1 Reply Last reply Reply Quote 0
                                    • M7460undefined
                                      M7460 @MintyTrebor
                                      @mintytrebor Thanks , do you know how one could do this? I need to lose some buttons and add some
                                      Thanks Martin
                                        MintyTrebor @M7460
                                        @m7460 Sorry No.
                                        Repo
                                        • cosmowaveundefined
                                          cosmowave
                                          Is there a way to change object model values (like retraction length) direct in a panel?
                                          Mankati FSXT+, DeltaTowerV2, E3D MS/TC
                                            MintyTrebor @cosmowave
                                            @cosmowave global variables can be set with an input panel.
                                            For changing values that are normally set through gcode commands, its best to use a global variable to hold the value, and then use the variable in a macro.
                                            EG:
                                            Have an input panel to set the variable value (in your case retraction length)
                                            Have a button to run a macro that sets retraction length using the global variable
                                            Repo
                                            cosmowaveundefined 1 Reply Last reply Reply Quote 0
