    BtnCmd-DWC Plugin - Customise DWC - v01.04.00 29-05-25
    Plugins for DWC and DSF
    27
    245
    42.1k
    • MintyTreborundefined
      MintyTrebor @Adamfilip
      @adamfilip
      Released BtnCmd Beta 0.10.12
      https://github.com/MintyTrebor/BtnCmd/releases
      Change-Log:
      • Added Import / Export feature
      • Changed Backup Icon actions
      Notes on Import / Export:
      Importing Layouts and custom panels designed on a different screen resolution may result in objects displaying incorrectly. This limitation cannot be changed.
      NodeDSF - Native Node-Red integration with Duet boards.
      BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
      ReleaseMgr - Duet update info inside DWC.
      Repo
      Adamfilipundefined 1 Reply Last reply Reply Quote 2
      • Adamfilipundefined
        Adamfilip @MintyTrebor
        @mintytrebor Thank you!
        Now we just need people to export their custom layouts / panels. 🙂
        If you make one please share here with a screen capture of how it looks and a download link
        MintyTreborundefined 1 Reply Last reply Reply Quote 0
          Published BtnCmd Beta 0.10.13
          Changes:
          • Enabled Auto Restore Feature - read more here
          • New Experimental Feature for SBC users - read more here
          • Added the ability to include object model values in MQTT msgs, and HTTP Post data - read more here
          Repo
          Adamfilipundefined 1 Reply Last reply Reply Quote 0
            @mintytrebor
            Anyway to enable responsive layout with mobile.
            cant even scroll unfortunately.
            PC
            Iphone
              @adamfilip https://github.com/MintyTrebor/BtnCmd/wiki/Edit-Mode
              Repo
                @mintytrebor "General Notes On Layouts:
                BtnCmd uses absolute pixel positions to locate and fix the size of objects in layouts. This means that opening a layout on a screen with a different resolution to the original will have various impacts on the original positions of the objects - this is especially true when opening a layout designed on a desktop on a mobile device. Dynamic scaling for different resolutions will not work for BtnCmd layouts."
                Would be nice to make the layouts responsive to different screen sizes
                • M7460undefined
                  M7460
                  Hi , can this plugin change the PanleDue screen ?
                  Thanks
                    MintyTrebor @M7460
                    @m7460 No
                    Repo
                    M7460undefined 1 Reply Last reply Reply Quote 0
                    • M7460undefined
                      M7460 @MintyTrebor
                      @mintytrebor Thanks , do you know how one could do this? I need to lose some buttons and add some
                      Thanks Martin
                        MintyTrebor @M7460
                        @m7460 Sorry No.
                        Repo
                        • cosmowaveundefined
                          cosmowave
                          Is there a way to change object model values (like retraction length) direct in a panel?
                          Mankati FSXT+, DeltaTowerV2, E3D MS/TC
                            MintyTrebor @cosmowave
                            @cosmowave global variables can be set with an input panel.
                            For changing values that are normally set through gcode commands, its best to use a global variable to hold the value, and then use the variable in a macro.
                            EG:
                            Have an input panel to set the variable value (in your case retraction length)
                            Have a button to run a macro that sets retraction length using the global variable
                            Repo
                            cosmowaveundefined 1 Reply Last reply Reply Quote 0
                              cosmowave @MintyTrebor
                              @mintytrebor said in BtnCmd-DWC Plugin-Custom Layouts & Buttons - v0.10.13 11-07-22:
                              Yes... Thats my actual use case
                              • o_lampeundefined o_lampe referenced this topic
                                Released Beta 0.10.14
                                Changes:
                                • Bug fixes and improvements to the Global Variable Input Panel, specifically addressing the alignment issues of switches, and right aligned variable values.
                                Repo
                                moth4017undefined 1 Reply Last reply Reply Quote 2
                                • moth4017undefined
                                  moth4017 @MintyTrebor
                                  @MintyTrebor
                                  Thanks for the update
                                    MintyTrebor @moth4017
                                    Released Beta 0.10.15
                                    Changes:
                                    • New Panels : Jobs List, Macro List, Events List
                                    • Alt Web Cam Panel - New option to add a button on the webcam image to open an external page - use to open config pages for various webcam services, eg Motion.
                                    • Global Setting : Auto Start BtnCmd - Automatically switch to BtnCmd when DWC loads
                                    • Global Setting : Change DWC Top Bar Color
                                    Repo
                                    • falco22undefined
                                      falco22
                                      Hello, first of all, excellent plugin! I have a question. configure the plugin as I want, but when sending to print, it automatically goes to the default status screen of the webcontrol. Is it possible to stay in the custom tabs? I hope it has been understood.
                                        MintyTrebor @falco22
                                        @falco22 If you are referring to the Job list Panel - then it will be using standard DWC behaviour to switch views on job start.
                                        Repo
                                        falco22undefined 1 Reply Last reply Reply Quote 0
                                        • falco22undefined
                                          falco22 @MintyTrebor
                                          @MintyTrebor said in BtnCmd-DWC Plugin-Custom Layouts & Buttons - v0.10.15 06-11-22:
                                          No, I mean, when I print a file, it goes directly to the status panel in dwc, and I would like it to stay in the Btncmd panel
                                            cosmowave @falco22
                                            @falco22 I think, you don't understand correctly what @MintyTrebor means...
                                            He means, that the job panel in DWC, where you start the job, is not under his control.
                                            After starting a job it is standard for DWC to jump to status screen. MintyTrebor can only change the BtnCmd plugin.
