BtnCmd-DWC Plugin - Customise DWC - v01.04.00 29-05-25
@o_lampe I released an update 2 mins ago to allow the Panels in both Laser & CNC mode
undefined chrishamm referenced this topic
Is there someplace to download different configurations of entire layouts of panels and buttons.
or a way to load user created custom panels themselves.would be great if we could share various configurations to get us 90% of the way there.
@adamfilip said in BtnCmd-DWC Plugin-Custom Layouts & Buttons - v0.10.11 11-06-22:
would be great if we could share various configurations to get us 90% of the way there.There is no functionality to share custom panels/layouts. Only the backup and restore feature. I will add the request to the wish list, and look into it.
Released BtnCmd Beta 0.10.12
https://github.com/MintyTrebor/BtnCmd/releasesChange-Log:
Added Import / Export feature
Changed Backup Icon actions
Notes on Import / Export:
Importing Layouts and custom panels designed on a different screen resolution may result in objects displaying incorrectly. This limitation cannot be changed. -
@mintytrebor Thank you!
Now we just need people to export their custom layouts / panels.
If you make one please share here with a screen capture of how it looks and a download link -
Anyway to enable responsive layout with mobile.
cant even scroll unfortunately.
PC
Iphone
@mintytrebor "General Notes On Layouts:
BtnCmd uses absolute pixel positions to locate and fix the size of objects in layouts. This means that opening a layout on a screen with a different resolution to the original will have various impacts on the original positions of the objects - this is especially true when opening a layout designed on a desktop on a mobile device. Dynamic scaling for different resolutions will not work for BtnCmd layouts."Would be nice to make the layouts responsive to different screen sizes
Hi , can this plugin change the PanleDue screen ?
Thanks
@m7460 No
@mintytrebor Thanks , do you know how one could do this? I need to lose some buttons and add some
Thanks Martin
@m7460 Sorry No.
Is there a way to change object model values (like retraction length) direct in a panel?
@cosmowave global variables can be set with an input panel.
For changing values that are normally set through gcode commands, its best to use a global variable to hold the value, and then use the variable in a macro.
EG:
Have an input panel to set the variable value (in your case retraction length)
Have a button to run a macro that sets retraction length using the global variable -
@mintytrebor said in BtnCmd-DWC Plugin-Custom Layouts & Buttons - v0.10.13 11-07-22:
Have a button to run a macro that sets retraction length using the global variableYes... Thats my actual use case
undefined o_lampe referenced this topic
Released Beta 0.10.14
Changes:
- Bug fixes and improvements to the Global Variable Input Panel, specifically addressing the alignment issues of switches, and right aligned variable values.
Thanks for the update
Released Beta 0.10.15
Changes:
- New Panels : Jobs List, Macro List, Events List
- Alt Web Cam Panel - New option to add a button on the webcam image to open an external page - use to open config pages for various webcam services, eg Motion.
- Global Setting : Auto Start BtnCmd - Automatically switch to BtnCmd when DWC loads
- Global Setting : Change DWC Top Bar Color
Hello, first of all, excellent plugin! I have a question. configure the plugin as I want, but when sending to print, it automatically goes to the default status screen of the webcontrol. Is it possible to stay in the custom tabs? I hope it has been understood.
