Pressure advance and variable flow ratio
@mikeabuilder I think he mean 1200mm^2/s and 4000mm^2/s. The dot is the digit delimiter, not decimal point.
@trchen - well, that makes a lot of sense.
I think Firmware wishlist is probably not the right place for this post. It is not really a new feature, but more of tweaking.
My apologies for tagging you directly, @dc42, just want to make sure you are aware of it. We have a few users at Voron Discord who suffered from PA-related issues that is specific to RRF.
I did some more experiment afterwards. I wrote a SuperSlicer postprocessing script to insert a short pause
G4 P1
(basically forcing RRF to decelerate to 0) when flow ratio changed by more than 5%. It mitigated my bridging problems even if printing at normal bridging speed (75mm/s). It is only circumstantial evidence but I think it's worth some investigation.Here's my SS script if anyone's curious:
#!/usr/bin/python3 import sys from io import StringIO from math import hypot THRESHOLD = 1.05 x = y = None e_rate = 0.0 buffer = StringIO() for line in open(sys.argv[1], "r"): if not line.startswith("G1 "): buffer.write(line) continue dx = dy = de = 0.0 for clause in line.split(): if clause[0] == "X": if x is None: dx = None else: dx = float(clause[1:]) - x x = float(clause[1:]) elif clause[0] == "Y": if y is None: dy = None else: dy = float(clause[1:]) - y y = float(clause[1:]) elif clause[0] == "E": de = float(clause[1:]) if dx is None or dy is None: buffer.write(line) continue dxy = hypot(dx, dy) if dxy < 0.00001: new_e_rate = 0.0 else: new_e_rate = de / dxy if e_rate == 0.0 or new_e_rate == 0.0: pass else: ratio = new_e_rate / e_rate if ratio >= THRESHOLD: buffer.write("G4 P1\n") buffer.write(line) e_rate = new_e_rate with open(sys.argv[1], "w") as f: f.write(buffer.getvalue())
@droftarts could you please move this thread to a more suitable category? Hopefully someone will then take a look at this. Thanks!
@trchen thanks for sharing your thoughts. Have you tried building a version of the firmware with permitted extruder jerk set to zero in DDA::MatchSpeeds? If you haven't, would you like me to build one for you?
@argo just a side note that I am not surprised RRF3.4 with IS does cause rounded corners because that's what IS effectively is for -- smoothing out the movement so it's not a sharp direction change that induces ringing. If you disable IS in 3.4, do you regain the sharp corners?
Input Shaping only has marginal effect on how the corners do look like. I did tests with and without IS.
I did also play around with different jerk settings (5 mm/s up to 15 mm/s) and the result is also pretty much the same.For testing purposes I would like to revert back to RRF 3.3
but it seems the 1LC rev 1.1 is not supported by RRF 3.3 because I can't activate the heater.As far as I remember I did not have this issue with RRF 3.3 but that can still be a coincidence.Edit: I'm not sure the issue I'm having is related to the findings of trchen and I don't want to hijack his thread, so I'm creating a new one with my findings.
@dc42 I haven't, but I'm happy to try! I predict it will have similar effect as my slicer postprocessing script. I'll do an experiment to see if it reinforces or disproves our theory.
I just got my build environment set up. I will be busy at work this week, probably will start my experiments over the weekend.
The first experiment would be hardcoding the E jerk during MatchSpeeds to some small value and see how bridges behaves.
(The jerk value can't be zero due to FP errors. Something like 0.01 is probably more reasonable. I feel MinimumJerk==0.1 may still be high for extruders.)I still haven't think through what a better jerk policy should be. Allowing the total speed to mismatch between two moves doesn't feel right either because multiple rapid small moves could rack up a lot of speed change in small amount of time.
On the other hand, what's so different with the policy we have today? With the current jerk policy you can make a lot of small moves to form very small turn radius, effectively bypassing the acceleration limit. For example, Gyroid infills are notoriously demanding for acceleration. I suspect we are actually able to cheat by breaking down curves to multiple small moves, by setting "Slicing --> Filtering --> Internal resolution" smaller in the slicer.
An idea I have in mind is to maintain a "jerk potential" which is recharged at the rate of acceleration while capped at the jerk maximum. Once the jerk potential is depleted no more instantaneous speed change is allowed.
