    NEMA 23 23HS22-2804S
    Using Duet Controllers
    612
    • rexxundefined
      rexx @o_lampe
      @o_lampe its a stock Stratasys they are designed to take it and is silicone 200C wire
      rexxundefined 1 Reply Last reply Reply Quote 0
      • rexxundefined
        rexx @o_lampe
        @o_lampe the bellows will be added and fire pillows added inplace of the 80C stable foam for isolation soon but not soon enough
        • rexxundefined
          rexx @rexx
          @rexx i am just going to try 1200 mA and see if its suffice i was hoping somone was able to say they have used 23's down to 1200mA but want a bench mark for when all else is on
          • rexxundefined
            rexx @o_lampe
            @o_lampe LDO also makes a HT stepper good to 180C so magnets are ok until then
            • o_lampeundefined
              o_lampe
              I recently found, that these motors run fine with higher driver voltage and lower amps. But it depends, how much speed or torque you need.
              Anyway, 48V allow for a wider range of settings.
              If you have the 6-wire version, you can change their behaviour even more.
              rexxundefined 1 Reply Last reply Reply Quote 1
              • o_lampeundefined
                o_lampe @rexx
                @rexx said in NEMA 23 23HS22-2804S:
                That would be my plan B, if the 23HS22 fail, replace them with LDO HT motors
                • rexxundefined
                  rexx @o_lampe
                  @o_lampe kool i did not know this cheers but i have 8 wire paired up to 4 and am only 24V currently booooo but am only cartesian so i want to target 1600mA but will try to start at 1200 and see
                  • o_lampeundefined
                    o_lampe @rexx
                    @rexx Pairing them to parallel coils is probably the best config for 24V 👍
                    • rexxundefined
                      rexx @o_lampe
                      @o_lampe will your adverage meanwell power supply surge DC voltage side if the AC side volts fluctuate slightly from the chamber heaters on and off of ac mains power much? what do you think?
                      • o_lampeundefined
                        o_lampe @rexx
                        @rexx
                        No, AFAIK these switch mode PSU are immune against sagging AC voltage. Their control loop is on the output side and there are huge capacitors between the AC rectifier side and the output.
                        rexxundefined 2 Replies Last reply Reply Quote 0
                        • rexxundefined
                          rexx @o_lampe
                          @o_lampe i think so too.
                          i know it would if the chamber was on the DC side but would think the auto voltage input would have ability then regulate the DC side stable
                          • rexxundefined
                            rexx @o_lampe
                            @o_lampe i thought so but wanted to confirm your correct another beer?
                            • rexxundefined
                              rexx @o_lampe
                              @o_lampe i am drawing 6A on the chamber side at 120vac and have 6A remaining @ 120VAC the PS has 21A at 24V and i am using a 80w heater 7 1A fans at 24vdc and 3 nema 23 and one nema 17 ldo HT and 6HC lost of room left eh? yes i am Canadian!
