    NEMA 23 23HS22-2804S
    Using Duet Controllers
    612
      60 to 80% is usually the guide. But it's just a loose guide.
      If you think the motors are going above 80c, then lower the current. If that leaves you with too little torque, lower the acceleration.
      rexxundefined 1 Reply Last reply Reply Quote 0
      • rexxundefined
        rexx @Phaedrux
        @phaedrux sorry I mean to say ambient meaning the chambers heat not motor heat i am good down to 1600 and can get 7k Acc reliably but is a bit warm say 45Cish i was thinking to goto 1200 and try 5K to off set the chamber heat witch will be turned on soon i just dont know how the AMBIENT heat impacts the steppers performance thus tuning it coldish without the chamber first
        • o_lampeundefined
          o_lampe @rexx
          @rexx
          I wonder which parts of the motor might suffer most from high ambient temp? I guess the biggest effect would be demagnetisation of the stator?
          Is there a way to shield the motors from chamber temp in your frame? I understand that most people aiming for high chamber temps try to build their frames with motors outside of the hot zone or use watercooling.
          rexxundefined 3 Replies Last reply Reply Quote 0
          • rexxundefined
            rexx @o_lampe
            @o_lampe its a stock Stratasys they are designed to take it and is silicone 200C wire
            • rexxundefined
              rexx @o_lampe
              @o_lampe the bellows will be added and fire pillows added inplace of the 80C stable foam for isolation soon but not soon enough
              • rexxundefined
                rexx @rexx
                @rexx i am just going to try 1200 mA and see if its suffice i was hoping somone was able to say they have used 23's down to 1200mA but want a bench mark for when all else is on
                • rexxundefined
                  rexx @o_lampe
                  @o_lampe LDO also makes a HT stepper good to 180C so magnets are ok until then
                  • o_lampeundefined
                    o_lampe
                    I recently found, that these motors run fine with higher driver voltage and lower amps. But it depends, how much speed or torque you need.
                    Anyway, 48V allow for a wider range of settings.
                    If you have the 6-wire version, you can change their behaviour even more.
                    rexxundefined 1 Reply Last reply Reply Quote 1
                    • o_lampeundefined
                      o_lampe @rexx
                      @rexx said in NEMA 23 23HS22-2804S:
                      That would be my plan B, if the 23HS22 fail, replace them with LDO HT motors
                      • rexxundefined
                        rexx @o_lampe
                        @o_lampe kool i did not know this cheers but i have 8 wire paired up to 4 and am only 24V currently booooo but am only cartesian so i want to target 1600mA but will try to start at 1200 and see
                        • o_lampeundefined
                          o_lampe @rexx
                          @rexx Pairing them to parallel coils is probably the best config for 24V 👍
                          • rexxundefined
                            rexx @o_lampe
                            @o_lampe will your adverage meanwell power supply surge DC voltage side if the AC side volts fluctuate slightly from the chamber heaters on and off of ac mains power much? what do you think?
                            • o_lampeundefined
                              o_lampe @rexx
                              @rexx
                              No, AFAIK these switch mode PSU are immune against sagging AC voltage. Their control loop is on the output side and there are huge capacitors between the AC rectifier side and the output.
                              rexxundefined 2 Replies Last reply Reply Quote 0
                              • rexxundefined
                                rexx @o_lampe
                                @o_lampe i think so too.
                                i know it would if the chamber was on the DC side but would think the auto voltage input would have ability then regulate the DC side stable
                                • rexxundefined
                                  rexx @o_lampe
                                  @o_lampe i thought so but wanted to confirm your correct another beer?
                                  • rexxundefined
                                    rexx @o_lampe
                                    @o_lampe i am drawing 6A on the chamber side at 120vac and have 6A remaining @ 120VAC the PS has 21A at 24V and i am using a 80w heater 7 1A fans at 24vdc and 3 nema 23 and one nema 17 ldo HT and 6HC lost of room left eh? yes i am Canadian!
