    I could use some help
    682
    64.0k
      A Former User @A Former User
      @fcwilt the Z-endstop is still saying it's at the min stop.
        @fcwilt Z must be wrong, don't you think?
        • fcwiltundefined
          fcwilt @A Former User
          @mac said in I could use some help:
          @fcwilt with X depressed, X is at min stop, everything else is as it has been.
          With Y depressed, Y is at min stop, everything else is as it has been.
          Fantastic.
          So we know the X and Y endstop are working.
          But the Z is not. It should do the same as the X and Y.
          Please do this - from the DWC console execute M574 by itself - it should report how each endstop is configured.
            A Former User @fcwilt
            @fcwilt
            6/27/2022, 9:17:19 AM	M574
            Endstop configuration:
            X: low end switch connected to pin !io5.in
            Y: low end switch connected to pin !io6.in
            Z: low end switch connected to pin io2.in
            A Former User? fcwiltundefined 2 Replies Last reply Reply Quote 0
              @fcwilt something about that doesn't look right?
              • fcwiltundefined
                @fcwilt
                Great. You getting the hang of this, aren't you!
                So it says the Z endstop is configured on the low end, is connected to io2.in and does not have the ! character because the white wire is connected to the NO connection on the switch.
                But it seems that pressing or not pressing the Z endstop switch doesn't change what M119 reports.
                Did you verify that the Z endstop switch is still plugged onto the IO2 connector?
                  droftarts administrators @A Former User
                  @mac are you sure z endstop is connected to io2? Check with wiring diagram. https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mini_5+_Hardware_Overview#wiring-diagram
                    A Former User @droftarts
                    @droftarts hey's baaaaaaaaaccccccccckkkkkkk
                    I just moved the white wire on the 5 pin io2 connector from io2_out to io2_in, The green wire is still in the center of the connector / connected to GND.
                    fcwiltundefined A Former User? 2 Replies Last reply Reply Quote 0
                    • fcwiltundefined
                      Well that certainly should make a difference.
                      Please run the M119 tests with the Z endstop switch pressed and not pressed.
                        @droftarts @fcwilt M119 reported all of the axis are NOT STOPPED, WAIT A MINUTE!!!!!
                        6/27/2022, 9:28:48 AM	M119
                        Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: not stopped
                        6/27/2022, 9:28:11 AM	M119
                        Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped
                        Look at the timecode, between :11 and :48 Z changed!
                          @droftarts @fcwilt I knew there was a reason I named this machine Frankenstein's Cinderella.
                          • fcwiltundefined
                            So it seems like the Z endstop switch is now working?
                              @droftarts @fcwilt I turned off the machine, then turned it back on. M119 reports that Z is at min stop.
                              My finger isn't anywhere near it.
                              But, when I depress Z, and send M119, it says Z NOT STOPPED.
                                @droftarts @fcwilt Z needs to be reversed, doesn't it.
                                • fcwiltundefined
                                  Just edit the M574 line for the Z endstop and add the ! character, save, re-boot and re-test with M119.
                                  You see what X and Y endstops do.
                                  You need to get Z doing the same.
                                    @fcwilt @droftarts FREAKIN' SUCCESS!
                                    With all of the endstops up, all of them are off, with Y endstop depressed, it is at min stop. with Z depressed, it is at min stop, and with X depressed, it is at MIN STOP!
                                      @droftarts @fcwilt I wonder where that puts us?
                                      • fcwiltundefined
                                        Congrats.
                                        Now that you know the endstops are working you can proceed to fine tune your homing code.
                                        Because you have a Z endstop you can start with that.
                                        One Z is homed then homing X and Y is a piece of cake.
                                        How about doing one at a time.
                                        Please post your Z homing code which should be in homeZ.g
                                          @fcwilt
                                          ; homez.g
                                          ; called to home the Z axis
                                          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jun 27 2022 06:45:01 GMT-0700 (Pacific Daylight Time)
                                          G91                      ; relative positioning
                                          G1 H2 Z5 F3600           ; lift Z relative to current position
                                          G90                      ; absolute positioning
                                          G1 X-10.875 Y4.375 F3600 ; go to first probe point
                                          G30                      ; home Z by probing the bed
                                          ;G91                     ; relative positioning
                                          ;G1 Z5 F60               ; lift Z relative to current position
                                          ;G90                     ; absolute positioning
                                          • fcwiltundefined
                                            @mac
                                            OK that is code for homing with a Z probe.
                                            Now that you have a working Z endstop you can use simpler code.
                                            Something like:
                                            G91               ; relative movements
                                            G1 H1 Z-250 F3600 ; fast move toward Z endstop
                                            G1 Z10            ; backup off a bit
                                            G1 H1 Z-15 F360   ; slow move toward Z endstop
                                            G90               ; absolute movements
                                            G1 Z10 F3600      ; move to 10mm off the bed to allow X and Y movements
