I could use some help
@fcwilt for a moment I was confused as to where the 0 was, i.e., the number before the "colon" is . . . .
But I figured it out!
@fcwilt so where do these responses put us?
@mac said in I could use some help:
We are still need to test the X and Y endstop switches to see what M119 reports when a switch is pressed or not pressed.
@fcwilt with X depressed, X is at min stop, everything else is as it has been.
With Y depressed, Y is at min stop, everything else is as it has been.
@fcwilt the Z-endstop is still saying it's at the min stop.
@fcwilt Z must be wrong, don't you think?
Fantastic.
So we know the X and Y endstop are working.
But the Z is not. It should do the same as the X and Y.
Please do this - from the DWC console execute M574 by itself - it should report how each endstop is configured.
6/27/2022, 9:17:19 AM M574 Endstop configuration: X: low end switch connected to pin !io5.in Y: low end switch connected to pin !io6.in Z: low end switch connected to pin io2.in
@fcwilt something about that doesn't look right?
Great. You getting the hang of this, aren't you!
So it says the Z endstop is configured on the low end, is connected to io2.in and does not have the ! character because the white wire is connected to the NO connection on the switch.
But it seems that pressing or not pressing the Z endstop switch doesn't change what M119 reports.
Did you verify that the Z endstop switch is still plugged onto the IO2 connector?
@mac are you sure z endstop is connected to io2? Check with wiring diagram. https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mini_5+_Hardware_Overview#wiring-diagram
@droftarts hey's baaaaaaaaaccccccccckkkkkkk
I just moved the white wire on the 5 pin io2 connector from io2_out to io2_in, The green wire is still in the center of the connector / connected to GND.
Well that certainly should make a difference.
Please run the M119 tests with the Z endstop switch pressed and not pressed.
@droftarts @fcwilt M119 reported all of the axis are NOT STOPPED, WAIT A MINUTE!!!!!
6/27/2022, 9:28:48 AM M119 Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: not stopped 6/27/2022, 9:28:11 AM M119 Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped
Look at the timecode, between :11 and :48 Z changed!
@droftarts @fcwilt I knew there was a reason I named this machine Frankenstein's Cinderella.
So it seems like the Z endstop switch is now working?
@droftarts @fcwilt I turned off the machine, then turned it back on. M119 reports that Z is at min stop.
My finger isn't anywhere near it.
But, when I depress Z, and send M119, it says Z NOT STOPPED.
@droftarts @fcwilt Z needs to be reversed, doesn't it.
Just edit the M574 line for the Z endstop and add the ! character, save, re-boot and re-test with M119.
You see what X and Y endstops do.
You need to get Z doing the same.
@fcwilt @droftarts FREAKIN' SUCCESS!
With all of the endstops up, all of them are off, with Y endstop depressed, it is at min stop. with Z depressed, it is at min stop, and with X depressed, it is at MIN STOP!
