    I could use some help
    682
    63.5k
      A Former User @A Former User
      @fcwilt are the S0 and S1 reversed?
      • fcwiltundefined
        fcwilt @A Former User
        @mac said in I could use some help:
        No they are correct.
        But, just FYI, there is a simpler form of M208 (at least I think it is simpler)
        M208 X0:220 Y0:220 Z0:240
        Notice no S0 or S1.
        The number before the : character is the min value for the axis specified by the letter.
        The number after the : character is the max value for the axis specified by the letter.
        I find it easier to remember "min then max" rather then "is it S0 or S1".
        That's just me.
          A Former User @fcwilt
          @fcwilt for a moment I was confused as to where the 0 was, i.e., the number before the "colon" is . . . .
          But I figured it out!
            @fcwilt so where do these responses put us?
            • fcwiltundefined
              We are still need to test the X and Y endstop switches to see what M119 reports when a switch is pressed or not pressed.
                @fcwilt with X depressed, X is at min stop, everything else is as it has been.
                With Y depressed, Y is at min stop, everything else is as it has been.
                A Former User? fcwiltundefined 2 Replies Last reply Reply Quote 0
                  @fcwilt the Z-endstop is still saying it's at the min stop.
                    @fcwilt Z must be wrong, don't you think?
                    • fcwiltundefined
                      Fantastic.
                      So we know the X and Y endstop are working.
                      But the Z is not. It should do the same as the X and Y.
                      Please do this - from the DWC console execute M574 by itself - it should report how each endstop is configured.
                        @fcwilt
                        6/27/2022, 9:17:19 AM	M574
                        Endstop configuration:
                        X: low end switch connected to pin !io5.in
                        Y: low end switch connected to pin !io6.in
                        Z: low end switch connected to pin io2.in
                          @fcwilt something about that doesn't look right?
                          • fcwiltundefined
                            @fcwilt
                            Great. You getting the hang of this, aren't you!
                            So it says the Z endstop is configured on the low end, is connected to io2.in and does not have the ! character because the white wire is connected to the NO connection on the switch.
                            But it seems that pressing or not pressing the Z endstop switch doesn't change what M119 reports.
                            Did you verify that the Z endstop switch is still plugged onto the IO2 connector?
                              droftarts administrators @A Former User
                              @mac are you sure z endstop is connected to io2? Check with wiring diagram. https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mini_5+_Hardware_Overview#wiring-diagram
                                A Former User @droftarts
                                @droftarts hey's baaaaaaaaaccccccccckkkkkkk
                                I just moved the white wire on the 5 pin io2 connector from io2_out to io2_in, The green wire is still in the center of the connector / connected to GND.
                                fcwiltundefined A Former User? 2 Replies Last reply Reply Quote 0
                                • fcwiltundefined
                                  Well that certainly should make a difference.
                                  Please run the M119 tests with the Z endstop switch pressed and not pressed.
                                    @droftarts @fcwilt M119 reported all of the axis are NOT STOPPED, WAIT A MINUTE!!!!!
                                    6/27/2022, 9:28:48 AM	M119
                                    Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: not stopped
                                    6/27/2022, 9:28:11 AM	M119
                                    Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped
                                    Look at the timecode, between :11 and :48 Z changed!
                                      @droftarts @fcwilt I knew there was a reason I named this machine Frankenstein's Cinderella.
                                      • fcwiltundefined
                                        So it seems like the Z endstop switch is now working?
                                          @droftarts @fcwilt I turned off the machine, then turned it back on. M119 reports that Z is at min stop.
                                          My finger isn't anywhere near it.
                                          But, when I depress Z, and send M119, it says Z NOT STOPPED.
                                            @droftarts @fcwilt Z needs to be reversed, doesn't it.
