    Weird macro behaviour
    Gcode meta commands
    971
    • fcwiltundefined
      fcwilt @Exerqtor
      This post is deleted!
      • Exerqtorundefined
        Exerqtor @fcwilt
        @fcwilt said in Weird macro behaviour:
        Please get in the habit of copy-and-pasting files into the </> tag, one tag per file.
        This will create a scrollable region right in your post so the rest of us don't have to download a file to view it.
        Didn't know that was the perfered way in larger files (esp when refering to line numbers), fixed now 👍
        fcwiltundefined deckingmanundefined 2 Replies Last reply Reply Quote 1
        • fcwiltundefined
          fcwilt @Exerqtor
          @exerqtor
          Nothing jumps out at me.
          When it happens to me I starting "sprinkling" my code with echo statements so I can track the progress of the code and see exactly where things go wonky.
          And I have to remind myself to check the DWC Console which may list an error message giving a clue to what went wrong.
          Exerqtorundefined 1 Reply Last reply Reply Quote 0
          • Exerqtorundefined
            Exerqtor @fcwilt
            @exerqtor
            Yeah i've done that and confirmed that it goes past the klicky_load.g and it also runs the klicky_status.g after klicky_load (since it changes the global to attached when it's done), BUT if i throw a echo after klicky_status.g on line 40 it dont get called out, the next thing that happens is the "bed allready leveled" on line 96 😆 i can't figgure out what the f is going on at this point.
            • fcwiltundefined
              fcwilt @Exerqtor
              @exerqtor said in Weird macro behaviour:
              OK let me take a closer look.
              JOOC, how many values can the global status variable have?
                deckingman @Exerqtor
                @exerqtor Is it possible that sensors.probes[0].value could be something other than 0 or 1000? I'm not seeing anything that could catch that which would mean that the global.klicky_status would not be set to "attached" nor "docked".
                • Exerqtorundefined
                  Exerqtor @deckingman
                  @deckingman Nope, it's a simple on/off microswitch so it can't output anything else.
                  Changing the global variable two times in a short amout of time shouldn't have anything to say either should it? 🤔 I'll uncomment the status refresh before klicky_load.g tomorrow to see if that changes anything.
                  • fcwiltundefined
                    fcwilt @Exerqtor
                    No that should not have an effect... except I did read about a problem in 3.4.1, with one macro calling another... now what was the work around... I don't remember.
                    Perhaps you can find those posts.
                    • Exerqtorundefined
                      Exerqtor @fcwilt
                      Oh you did? Haven't seen that mentioned yet, i'll try to find it!
                      EDIT: Is this the thread you were refering to @fcwilt?
                      • Del87undefined
                        Del87
                        My observations regarding macros:
                        M83 via console works.
                        Makros file containing one string M83 not working.
                        Dmitry
                        gloomyandyundefined 1 Reply Last reply Reply Quote 0
                        • gloomyandyundefined
                          gloomyandy @Del87
                          @del87 When a macro is run some settings are saved and restored I'm pretty sure that the extruder absolute/relative mode is one of them, so M83 in a macro may appear to do nothing. See: https://docs.duet3d.com/en/User_manual/Tuning/Macros_tasks#running-macros
                          Del87undefined 1 Reply Last reply Reply Quote 2
                          • Del87undefined
                            Del87 @gloomyandy
                            @gloomyandy
                            dunno that, thanks!
                            Dmitry
                            • fcwiltundefined
                              fcwilt @Exerqtor
                              Yes - you found it.
                              • Exerqtorundefined
                                Exerqtor @fcwilt
                                @fcwilt
                                Adding echo "" at the end of the nested macros did the charm, thanks for the heads up on that one!. Lets hope @chrishamm finds a fix for it soon 🤣
                                fcwiltundefined chrishammundefined 2 Replies Last reply Reply Quote 1
                                • fcwiltundefined
                                  fcwilt @Exerqtor
                                  @fcwilt
                                  Glad to hear it is now working for you.
                                  • mikeabuilderundefined
                                    mikeabuilder
                                    Glad it's working, but I'll toss in couple of comments.
                                    The comment - Per @deckingman comment, I think it's good coding practice to check probe values with a ">X" vs "=Y".
                                    Another comment - I don't see an initialization for global.klicky_status. If it was not initialized, you should have seen an error in the console or log file. Adding an "else with a message stating klicky status is not defined and an abort would be nice, that way you've covered all options for global.klicky_status. Even better would be a third return value for gloabl.klicky_status in klicky_status.g. on Line 12 add an else set global.klicky_status = "invalid". Then you'd see if the value passed back to the main macro is neither 0 nor 1000.
                                    My speculation is that if the variable was not initialized it might abort the "code block" that contains it, which might be the block starting on line 1and ending on line 90.
                                    Exerqtorundefined 1 Reply Last reply Reply Quote 1
                                    • chrishammundefined
                                      chrishamm administrators @Exerqtor
                                      @exerqtor I've got a fix ready that will be part of the next 3.4.2-b1 version. dc42 has already merged it.
                                      Duet software engineer
                                      • Exerqtorundefined
                                        Exerqtor @mikeabuilder
                                        @mikeabuilder said in Weird macro behaviour:
                                        Noted, then i guess this will taste better:
                                        if sensors.probes[0].value[0] < 1
                                          set global.klicky_status = "attached"
                                        elif sensors.probes[0].value[0] > 999
                                          set global.klicky_status = "docked"
                                        echo ""
                                        global.klicky_status get's initialized along with all my other globas thru a macro named "globals.g", "globals.g" on it's side gets called by "init.g" as one of the last steps in my "config.g".
                                        end of "config.g"
                                        M950 P0 C"out2"        ; create output Port0 attached to out2 connector for LED lights
                                        M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"                             ; set voltage thresholds and actions to run on power loss
                                        M572 D0 S0.0        ; Disable Pressure Advance
                                        M98 P"/sys/lib/init.g"                                                         ; iniate external configs
                                        M501        ; load config-override.g
                                        T0        ; select tool 0
                                        "init.g":
                                        ; /sys/lib/init.g
                                        ; Called in the end of config.g
                                        ; Used to setup more stuff
                                        M98 P"/sys/lib/globals.g"                                                      ; setup global variables
                                        M98 P"/sys/lib/speed/speed_printing.g"                                         ; set normal speed & accel
                                        M98 P"/sys/lib/current/xy_current_high.g"                                      ; set normal xy currents
                                        M98 P"/sys/lib/current/z_current_high.g"                                       ; set normal z currents
                                        M98 P"/sys/lib/fw_retraction.g"                                                ; set firmware retraction settings
                                        "globals.g"
                                        ; /sys/lib/globals.g
                                        ; Called by init.g
                                        ; Used to initialize global variables
                                        ; global declarations and defaults
                                        ; temperature
                                        if !exists(global.bed_temp)
                                          global bed_temp = 0
                                        if !exists(global.hotend_temp)
                                          global hotend_temp = 0
                                        if !exists(global.chamber_temp)
                                          global chamber_temp = 0
                                        ; stepper currents
                                        if !exists(global.xy_current)
                                          global xy_current = move.axes[0].current
                                        if !exists(global.z_current)
                                          global z_current = move.axes[2].current
                                        if !exists(global.e_current)
                                          global e_current = move.extruders[0].current
                                        ; mechanical Z pin
                                        if !exists(global.zpinx)
                                          global zpinx = 194.5
                                        if !exists(global.zpiny)
                                          global zpiny = 355
                                        ; klicky probe
                                        ; the distance from the body of the klicky probe to it's own trigger point
                                        if !exists(global.klickyoffset)
                                          global klickyoffset = 0.23  ; a larger values makes the nozzle closer to the bed after running autoz
                                        ; the absolute X location of the klicky while docked
                                        if !exists(global.klickydockx)
                                          global klickydockx = 18.6
                                        ; the absolute Y location of the klickywhile docked
                                        if !exists(global.klickydocky)
                                          global klickydocky = 357.3
                                        ; the relative disance and direction of the klicky docking move
                                        if !exists(global.klickywipe)
                                          global klickywipe = 30  ; -30 for a left wipe 30 for a right wipe
                                        if !exists(global.klicky_status)
                                          global klicky_status = "none"
                                        ; bed
                                        ; define the bed size (print area from 0 to X and Y max)
                                        if !exists(global.bedx)
                                          global bedx = 350
                                        if !exists(global.bedy)
                                          global bedy = 350
                                        ; misc
                                        if !exists(global.initial_extruder)
                                          global initial_extruder = 0
                                        if !exists(global.bed_leveled)
                                          global bed_leveled = false
                                        if !exists(global.job_completion)
                                          global job_completion = 0
                                        if !exists(global.debug_mode)
                                          global debug_mode = true
                                        ; output current values
                                        ;echo "global.bed_temp defined. Value : " , global.bed_temp
                                        ;echo "global.hotend_temp defined. Value : " , global.hotend_temp
                                        ;echo "global.chamber_temp defined. Value : " , global.chamber_temp
                                        echo "global.klicky_status defined. Value : " , global.klicky_status
                                        echo "global.bed_leveled. Value : " , global.bed_leveled
                                        echo "global.job_completion defined. Value : " , global.job_completion
                                        echo "global.debug_mode defined. Value : " , global.debug_mode
                                        Agreed on that, an else condition that resulted in "invalid" the result was anything between 1 too 999 would fix that with an abort. But i can't figgure out how to construct that, for instance
                                        else sensors.probes[0].value[0] = {what to but here to check if the value is between 1 and 999?}
                                          echo "Klicky status invalid - aborting"
                                          abort
                                        echo ""
                                        Or just go the easy route with
                                        else
                                          abort
                                        echo ""
                                        Turns out the premature ending was a bug in DWC, so it wasn't my fault this time lol.
                                        @chrishamm said in Weird macro behaviour:
                                        Sweet, hope that beta see the light of day pretty soon!
                                        • OwenDundefined OwenD referenced this topic
