    I could use some help
    682
    63.5k
      A Former User @rexx
      @rexx my last cr build was an SM800 Octocopter.
      rexxundefined 1 Reply Last reply Reply Quote 2
        A Former User @droftarts
        @droftarts good suggestions. I checked both set screws they were plenty tight.
        AC2613F2-A6E1-43CC-8E00-4A45B735D8C9.jpeg EBE75CBC-C07E-4A72-A645-87C5171DC2C0.jpeg
        Ian, how would you represent the motor pictured above in my config.g?
        Mac
        droftartsundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
        • fcwiltundefined
          fcwilt @A Former User
          @mac said in I could use some help:
          This is the video I made of the test.
          Thanks mac,
          That was very informative. Something is seriously messed up.
          Just to play it safe would you please post your current config.g file so we can check the stepper settings.
          • fcwiltundefined
            Is it possible the stepper and belt are moving fine but the bed is not staying firmly hooked to the belt?
            I've never worked on one of these printers so I don't know how that connection is made.
            • rexxundefined
              rexx @A Former User
              @mac nice ESC maddness or just one not formiliar with it specifically but i run a revolt 31"boat" well 2 but one is stock the other has leopard 36/74 1650kva on 6s 100C lipo's turning close to 26500 rpm's at 53 MPH 2 blade prop, that octocopter looks stable as a table
              • Falkiaundefined
                Falkia
                Maybe an output of M122 after this strange jogging could give some information?
                Printer: "Deltacus" Delta with 510mm bed diameter and 925mm build height. Powered by Duet 2 WiFi. Duet Smart Effector with E3D Volcano.
                  droftarts administrators @A Former User
                  @mac I'm wondering if the motors just aren't compatible. If that screen grab is correct, 4.5ohms per phase of resistance is high, as is 9.5mH per phase of inductance. There's another thread about high inductance motors struggling with the Trinamic drivers on the Mini 5+. It could be why you have such high coil whine (the constant squealing noise).
                  I think one thing that did help earlier in this thread, and you're not doing at the moment as far as I know, is to use StealthChop all the time. Add D3 V0 to all of the M569 motor commands in config.g.
                  As for other settings, post your current config.g and I'll take another look.
                  A Former User? 2 Replies Last reply Reply Quote 1
                  • fcwiltundefined
                    @mac
                    Hi mac.
                    To add a bit of info to what @droftarts posted mentioning the resistance and inductance of your steppers, here are those specs from three of my printers
                                 Yours      Mine #1  Mine #2   Mine #3
                    Resistance    4.5         1.4      1.5       1.6
                    Inductance    9.5         3.0      3.8       2.8
                    As you can see your numbers are a good deal higher, at least as far as steppers go.
                    I believe that droftarts may have found the problem - which would be grand.
                      A Former User @fcwilt
                      @fcwilt both ends of the belt are hooked to the front and rear sides of the frame that supports the bed, creating a continuous loop. Each end of the belt is folded over a hook, and zip-tied in two ways: around the loop, and across the loop including the hook. If the belt isn't tight, the pulley wheel at the rear of the frame and yank on it, and eventually break it.
                        @droftarts I'll try your suggestion, but Ian, if these motors are crap, I will immediately buy excellent motors to replace them if only you'll make a recommendation!
                          @droftarts
                          Here's the newest config.g
                          ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
                          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jun 27 2022 12:50:38 GMT-0700 (Pacific Daylight Time)
                          G90                                                ; send absolute coordinates...
                          M83                                                ; ...but relative extruder moves
                          M550 P"Frankenstein's Cinderella"                  ; set printer name
                          M552 S1                                            ; enable network
                          M586 P0 S1                                         ; enable HTTP
                          M586 P1 S0                                         ; disable FTP
                          M586 P2 S0                                         ; disable Telnet
                          M569 P0.0 D3 V0 S1                                       ; physical drive 0.0 goes forwards
                          M569 P0.1 D3 V0 S0                                       ; physical drive 0.1 goes backwards
                          M569 P0.2 D3 V0 S1                                       ; physical drive 0.2 goes forwards
                          M569 P0.3 D3 V0 S1                                       ; physical drive 0.3 goes forwards
                          M584 X0.0 Y0.1 Z0.2 E0.3                           ; set drive mapping
                          M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
                          M92 X100.000 Y100.00 Z4000.00 E420.00                 ; set steps per mm
                          M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
                          M203 X6000.00 Y6000.00 Z600.00 E1200.00            ; set maximum speeds (mm/min)
                          M201 X500.00 Y500.00 Z200.00 E250.00               ; set accelerations (mm/s^2)
                          M906 X600 Y600 Z600 E600                           ; set motor currents (mA)
                          M84 S0                                             ; Disable motor idle current reduction
                          M208 X0 Y0 Z0 S1                                   ; set axis minima
                          M208 X220 Y220 Z240 S0                             ; set axis maxima
                          M574 X1 S1 P"!io5.in"                              ; configure switch-type (e.g. microswitch) endstop for high end on X via pin !^io5.in
                          M574 Y1 S1 P"!io6.in"							   ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin !^io6.in
                          M574 Z1 S1 P"!io2.in"							   ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin !^io2.in
                          M950 S0 C"io3.out"                                 ; create servo pin 0 for BLTouch
                          M558 P9 C"io3.in" H5 F120 T3600                    ; set Z probe type to bltouch and the dive height + speeds
                          G31 P500 X15.875 Y0.625 Z2.5                       ; set Z probe trigger value, offset and trigger height
                          M557 X5:190 Y5:215 S10                             ; define mesh grid
                          M308 S0 P"temp0" Y"thermistor" T100000 B4092       ; configure sensor 0 as thermistor on pin temp0
                          M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
                          M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
                          M140 H0                                            ; map heated bed to heater 0
                          M143 H0 S33                                        ; set temperature limit for heater 0 to 33C
                          M308 S1 P"temp1" Y"thermistor" T100000 B4092       ; configure sensor 1 as thermistor on pin temp1
                          M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
                          M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                          M143 H1 S100                                       ; set temperature limit for heater 1 to 100C
                          M950 F0 C"out3" Q500                               ; create fan 0 on pin out3 and set its frequency
                          M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
                          M950 F1 C"out4" Q500                               ; create fan 1 on pin out4 and set its frequency
                          M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
                          M563 P0 S"optional" D0 H1 F0                       ; define tool 0
                          G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
                          G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                          M501                                               ; load saved parameters from non-volatile memory
                          M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                          • fcwiltundefined
                            It sounds secure so @droftarts suggestion about changing the M569 settings is an excellent next step.
                            Are you going to have a chance to do that soon?
                            If you do get to make the changes, just do again what you did in the video and see if now each click on "move by 10" actually moves the bed by 10, visually that is, not by the DWC display, it will always show the correct value even if the bed did not move at all.
                            Let's hope the problem has been found.
                            Hope you are feeling better.
                              A Former User @rexx
                              @rexx I had it in the air for up to twenty minutes at a time. And then the FAA shut us down.
                              I'm hoping to get a Mini 3 soon.
                                @fcwilt ahhh, from my reading of Ian's comment, the D3 V0 will quiet the motors, but it won't address the resistance issues. I need to get better motors. Can you please suggest something. I'll order on Amazon, and have them in by the weekend if I'm quick enough.
                                  @fcwilt
                                  • fcwiltundefined
                                    I get my steppers from Stepperonline usually.
                                    All NEMA 17 steppers will be the same frame size but they can vary in length. Yours are listed as 38mm long whereas mine are 48mm.
                                    Only you can determine how much space you have to go beyond 38mm.
                                    I could not find any NEMA 17 38mm steppers at Stepperonline.
                                    • fcwiltundefined
                                      It may well do more than quiet them, the noise is just a symptom.
                                      It actually may allow them to work as they should.
                                        @fcwilt you're not going to like this, but here goes:
                                        G1 H1 Y-10 F3600 would NOT move the bed. I tried twice, and I clicked multiple times each time.
                                        Then I changed H1 to H2.
                                        The command sent the bed back to the endstop 10 mm's at a time. When it was at -220 I looked to see what's what. There was another 10mm's to go, so I clicked on the send button. The bed went back that 10mm's, and depressed the endstop.
                                        Then I clicked on the Y+50 joy button at the far right of Home Y. Instead of going 50mm's, the bed went all the way to the front of the printer, and stopped without pounding on the adjustment cap.
                                        This machine has a mind of it's own. My apologies for such bad news.
                                        fcwiltundefined deckingmanundefined 3 Replies Last reply Reply Quote 0
                                        • fcwiltundefined
                                          You did re-boot the printer after editing the config.g file?
                                          I have no idea why H2 would work and not H1. Perhaps because H2 is not checking for the endstop to be activated and H1 is.
                                          But you cannot use H2 to home, it has to be H1.
                                          Here is a set of steppers that might fit - they are 39mm instead of 38mm and their specs are much better in regards to resistance and inductance:
                                          https://www.amazon.com/STEPPERONLINE-Stepper-59-49oz-42x42x39mm-Connector/dp/B094CR3228/ref=sr_1_4?keywords=nema%2B17%2Bstepper%2Bmotor&qid=1656547436&sprefix=nema%2B17%2Bst%2Caps%2C83&sr=8-4&th=1
                                          How much longer then 38mm could you fit? The larger ones tend to have more power and better specs.
                                          A Former User? 2 Replies Last reply Reply Quote 0
                                          • fcwiltundefined
                                            Here is a thought. Did you run M119 to check the endstop status first?
                                            If the Y endstop were already activated then the G1 H1 would not move.
