PanelDue just says "connecting"
@phaedrux I will try to double check later this weekend. Unfortunately I have quite a few late workdays coming up.
I don't see anything that could be shorting out anywhere. All the crimps appear solid. Not seeing any loose wiring. Anything else I can check?
I would suggest updating the firmware on the PanelDue.
https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDueWhat firmware are you running on the Duet?
@shoggoth43 if you can attach a laptop to the Duet USB port, then you can send M111 S1 P3 to enable GCode debugging. RRF will then echo to the serial port all GCode commands is received and which channel they came from. For PanelDue, if the Duet is receiving data then you should see regular M409 commands from channel Aux.
@Phaedrux I have uploaded the 3.4 firmware to the PanelDue and upgraded to 3.41 on the Duet. The PanelDue was running 1.25 and the Duet had 3.40 so all the firmware should now be current release.
@dc42 I connected to the USB on the Duet, I tried connecting via 9600 baud and 57600 baud. I don't see any responses to screen. I tried sending homing commands and manually typed in a G1 X10 command using the console on the PanelDue. No response.
Can you show the wiring?
What was it installed in before the mini5? Have you tested it with the old board again?
@phaedrux Will try to get the wiring photos this weekend. This was only ever connected to the mini 5+. It was initially just hooked up outside the box and then was placed into the printer controller box and wired up.
@shoggoth43 Pics as requested.
@shoggoth43 it looks like the green and blue wires on the PanelDue end are the wrong way around. See:
From https://docs.duet3d.com/en/User_manual/Connecting_hardware/Display_PanelDue#option-1-4-way-cableIan
@droftarts That seems to have sorted it. I would have sworn it worked before but I don't see how the wires would have changed...
Thank you all for the assistance.
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
