    Vector 3D's printer calibration
    4.5k
    • nurooundefined
      nuroo
      I was waiting for some1 to post that video link here. I saw our firmware supports the M556 command similar to marlin and klipper. I bought the model and instructions knowing the duet RepRap wasn't supported so far in his video.
      Anyway I have the measurements, but unsure how to apply the correction factors.
      Measurements
      	Reading 1	Reading 2	Reading 3	Average
      1	99.68	99.64	99.7	99.67
      2	50.1	50.05	50.07	50.07
      3	99.36	99.35	99.36	99.36
      4	49.65	49.61	49.67	49.64
      5	99.81	99.75	99.75	99.77
      6	49.96	49.97	49.98	49.97
      7	99.5	99.52	99.53	99.52
      8	49.67	49.7	49.69	49.69
      9	99.59	99.58	99.52	99.56
      10	99.65	99.81	99.65	99.70
      Results
      	Error	Correction
      X	-0.38%	0.38%
      Y	-0.35%	0.35%
      Skew	-0.08°	0.08°
      Fix Skew
      Klipper G Code Fix
      	SET_SKEW XY=99.7,99.56,69.74
      	SKEW_PROFILE SAVE=my_skew_profile
      Marlin Firmware Adjustment
      	if ENABLED(SKEW_CORRECTION)
      	 define XY_SKEW_FACTOR 0.022
      Railcore 300 zl
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0
      • zaptaundefined
        zapta @nuroo
        @nuroo, so may this thread is duet related. 😉
        One way is to scale x/y in the slicer per model, but a set once and forget solution is better.
        Possibly you can also adjust your x/y steps/mm but I am not sure if the 0.38% you got is material dependent or fixed for the printer (e.g. ABS may shrink more?).
        • Adam - V3Dundefined
          Adam - V3D
          Hey, so the right way to implement this for skew is with the M556 command I believe. It will only need the X argument as it's only XY compensation that we are doing with this model. I have a v4 of the calculator that I have sent to one use to test to see if my calculations are working correctly as I don't have a duet printer running at the moment.
          For the shrinkage and step/mm that are either slicer based, or done using the obvious config file modification.
          nurooundefined 2 Replies Last reply Reply Quote 2
          • nurooundefined
            nuroo @Adam - V3D
            @adam-v3d
            I'm the guy asking if this works for the duet on your video's comments. I can also help if need be.
            https://docs.duet3d.com/en/User_manual/Reference/Gcodes
            M556
            reference command:
            M556 S100 X0.7 Y-0.2 Z0.6
            "The S parameter is the length of a triangle along each axis in mm."
            So we measured both 100mm and 50mm lengths, with your test. (will v4 average 50mm or 100mm measurements? I'm unsure how to use M556.
            see my post above for the results
            I have entered into the console:
            M556 S100 x0.38
            firmware accepts it
            M556 in console - output:
            M556
            Axis compensations - XY: 0.00380, YZ: 0.00000, ZX: 0.00000
            guess ill try with this
            oliofundefined 1 Reply Last reply Reply Quote 1
            • oliofundefined
              oliof @nuroo
              @nuroo you could also try this way to check for skew and compensation values, which was originally developed for the RepRap Ormerod, https://reprapltd.com/reprappro/documentation/ormerod-2/axis-compensation/index.html#Orthogonal_Axis_Compensation
              nurooundefined Noliroundefined 2 Replies Last reply Reply Quote 0
              • nurooundefined
                nuroo @oliof
                @oliof
                Thanks for the response. I also saw a different procedure and model outlined in the docs for the M556 command linked in my post above.
                My interest is to make sure duet users can benefit from vector3d's method. He outlines a few reasons the common 20mm calibration model is not ideal. (I realize what you and I linked above isnt the common 20mm cube).
                What I'm after here with these post is for duet users to be able to follow along with his new method. Currently, it only works for marlin and klipper.
                • Noliroundefined
                  Noliro @oliof
                  @oliof said in Vector 3D's printer calibration:
                  Thank you for this link, really useful article, and measuring method. I will try to do so tomorrow when I will get back to my property in Spain here
                  Hi
                  • zaptaundefined
                    zapta @nuroo
                    @nuroo said in Vector 3D's printer calibration:
                    +1. Will be useful to know how to calibrate a duet with the results of this measurement.
                    • nurooundefined
                      nuroo @Adam - V3D
                      @adam-v3d said in Vector 3D's printer calibration:
                      Hey Adam. Any updates on the v4 version of your calibration tool. Specifically how to follow your process on a duet machine. In one of my earlier post, I posted the results from your current tool on a railcore.
                      Still willing to help if u need extra tester's.
                      skrotzundefined 1 Reply Last reply Reply Quote 0
                      • skrotzundefined
                        skrotz @nuroo
                        @nuroo FYI the calculator has been updated to include a reprap compatible M556 command for skew adjustment and it seems to work.
                        • nurooundefined
                          nuroo
                          My login to get new version no longer works??
