    Converting From X Endstop On PCB to Simple Micro Switch
    409
    • GBusy24undefined
      GBusy24
      Duet Wifi( early model) running RRF3.4. 2 outer poles on micro switch wired to 2 outer poles on terminal of the board. Switch is showing triggered, but it's not and deleting the exclamation point from the M574 isn't having any effect. What am I missing? Here's the config.g
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jan 24 2022 20:50:56 GMT-0500 (Eastern Standard Time)
      M550 P"CoreXY 1" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P1 S0 ; physical drive 1 goes forwards
      M569 P3 S0 ; physical drive 3 goes forwards
      M92 X80.00 Y80.00 Z400.00 E852 ; set steps per mm
      M203 X6000.00 Y6000.00 Z900.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X800 Y800 Z800 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X320 Y185 Z300 S0 ; set axis maxima
      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y2 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
      M574 X1 Y2 S1 ; X home to min. Y home to max. Normally Closed limit switches.
      M574 Z1 S2 ; Define Z to use Probe. Home to Min
      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000
      G31 P500 X-41.8 Y32.2 Z2.2
      M557 X10:320 Y0:190 S50 ; define mesh grid
      M307 H0 R0.495 K0.404:0.000 D4.40 E1.35 S1.00 B0; disable bang-bang mode for the bed heater and set PWM limit
      M501
      No such thing as spare time. No such thing as free time No such thing as down time. All you got is lifetime. Go!
        For the sake of a sanity check and you take a photo of the switch and the board endstop port?
        Is there perhaps a solder bridge or stray wire making contact?
        GBusy24undefined 1 Reply Last reply Reply Quote 0
        • GBusy24undefined
          GBusy24 @Phaedrux
            I would check the wires for continuity.
            • GBusy24undefined
              GBusy24 @GBusy24
              @gbusy24 Pushing the switch by hand, it goes to untriggered.
              • GBusy24undefined
                GBusy24 @Phaedrux
                @phaedrux Okay.
                Norderundefined 2 Replies Last reply Reply Quote 0
                • Norderundefined
                  Norder @GBusy24
                  @gbusy24
                  Did you also use the two outer pins on the microswitch ?
                  Are there symbols for the pin assignment on the microswitch housing ?
                  A photo of the microswitch pins might be helpful.
                  Google Translate
                  ----- Original Text -----
                  Hast Du bei dem Microschalter auch die beiden äußeren Pins genommen ?
                  Stehen am Gehäuse des Microschalters Symbole für die Pinbelegung ?
                  Ein Foto von den Microschalter Pins wäre eventuell hilfreich.
                  DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
                  Thingiverse
                  • Norderundefined
                    Norder @GBusy24
                    @gbusy24
                    In my opinion you don't need the following line.
                    To test it, put a ; in front of it and restart the printer and test whether it works.
                    Google Translate
                    Meiner Meinung nach brauchst Du folgende Zeile nicht.
                    Mach dort zum testen einemal ein ; davor und starte den Drucker neu und teste ob es dann geht.
                    Thingiverse
                    • GBusy24undefined
                      GBusy24 @Norder
                      • GBusy24undefined
                        GBusy24 @Norder
                        @günter-jibben I just tried that and it didn't help.
                        Norderundefined 1 Reply Last reply Reply Quote 0
                        • Norderundefined
                          Norder @GBusy24
                          @gbusy24
                          Too bad it didn't work with the ; before the command line.
                          But I still think this command line is unnecessary, but the moderator can tell you more about it, he is more familiar with it because it is his daily job and he knows the various configurations.
                          I don't have the line and I couldn't find it anywhere in the documentation.
                          mine looks like this...
                          M574 X1  P"!xstop"                           		; configure unsupported switch-type endstop for low end on X via pin xstop
                          M574 Y1 S1 P"ystop"                           		; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                          M574 Z1  P"!zstop+!e0stop"                         	; configure unsupported switch-type endstop for low end on Z via pin null
                          On the Z-axis (2 endstops) and on the Y-axis I have self-made endstops that work with a HAL-Sensor and a magnet that I can adjust.
                          I still have the original endstop microswitch on the Y-axis, but with an LED and three cables.
                          You should use the two outer pins on the microswitch, i.e. C and NC
                          C is the input and NC and NO are the outputs.
                          NO = Normally Open
                          NC = Normally closed
                          Google Translate
                          Schade das es nicht funktioniert hat mit dem ; vor der Kommandozeile.
                          Ich glaube aber immer noch, diese Kommandozeile ist unnötig, aber dazu kann Dir der Moderator mehr sagen, der kennt sich damit besser aus weil es sein täglicher Job ist und er die verschiedensten Konfigurationen kennt.
                          Bei mir ist die Zeile nicht vorhanden und in der Dokumentation konnte ich sie auch nirgends finden.
                          Meine sieht so aus...
                          An der Z-Achse (2 Endstops) und an der Y-Achse habe ich selbstgebaute Endstops die mit einem HAL-Sensor und einem Magneten funktionieren den ich justieren kann.
                          An der Y-Achse habe ich noch den Original Microschalter Endstop, aber mit LED und drei Kabeln.
                          An dem Microschalter solltest Du die beiden äußeren Pins nutze, also C und NC
                          C ist der Eingang und NC und NO sind die Ausgänge.
                          NO = Normal Offen
                          NC = Normal geschlossen
                          Thingiverse
