    How can I calibrate the temperature of my bed
    Firmware installation
    8
    66
    3.0k
    • infiniteloopundefined
      infiniteloop @axiom
      @axiom Nice to see that @SpoonUnit and @engikeneer have jumped in - thx guys.
      Just to add on that: use the Console of Duet Web Control to follow the tuning process in order not to miss any messages. In case of errors or warnings, post them here.
        droftarts administrators @axiom
        @axiom said in How can I calibrate the temperature of my bed:
        Thermal Protection & Control: On board thermal fuse, thermostat, thermistor and PT100 are available as part of your thermal management solution.
        I measured the resistance and it is correct: At 23.6 degrees (room/bed temperature) I have a resistance of 106 ohms.
        Are you sure the heating mat temperature sensor isn't a PT100? What M308 command are you using now?
        axiomundefined 1 Reply Last reply Reply Quote 0
        • axiomundefined
          axiom @droftarts
          @droftarts
          @droftarts said in How can I calibrate the temperature of my bed:
          According to the manufacturer, it's a PT100 sensor...it's a Chinese one. Right now I'm doing the M303 H0 S70 command
          droftartsundefined infiniteloopundefined 2 Replies Last reply Reply Quote 0
            @axiom PLEASE TURN OFF POWER TO THE PRINTER IMMEDIATELY!
            You can't connect a PT100 sensor direct to the Duet board. You can only use thermistors or PT1000 sensors direct to the Duet board. Also, the resistance of a PT100 sensor INCREASES as the temperature INCREASES, while the resistance of a thermistor DECREASES. With the Duet configured to expect a thermistor, the reported temperature will DECREASE, while the real temperature INCREASES. You said earlier:
            I have a Duet2 Wifi board and optionally 2 PT100 daughterboards (not currently in use)
            You need to connect the PT100 temperature sensor to the PT100 daughterboard, and configure the firmware so it knows you're using a PT100. See https://docs.duet3d.com/User_manual/Connecting_hardware/Temperature_connecting_PT100
            axiomundefined 1 Reply Last reply Reply Quote 1
            • axiomundefined
              axiom @droftarts
              @droftarts this is the result of the autotune:
              Auto tuning heater 0 completed after 3 idle and 5 tuning cycles in 1199 seconds. This heater needs the following M307 command:
              M307 H0 R0.283 K0.463:0.000 D7.17 E1.35 S1.00 B0
              Edit the M307 H0 command in config.g to match this. Omit the V parameter if the heater is not powered from VIN.
              But where exactly do I have to write that? Do I have to delete something else for that?
              axiomundefined infiniteloopundefined 2 Replies Last reply Reply Quote 0
              • axiomundefined
                axiom @axiom
                is this the same procedure for the print heads (nozzles)?
                  infiniteloop @axiom
                  @droftarts @axiom
                  I’m not so sure. From the data sheet @axiom posted:
                  After my suggestion to try standard values with M308 (and to measure the thermistor’s resistance), @axiom returned:
                  I measured the resistance and it is correct: At 23.6 degrees (room/bed temperature) I have a resistance of 106 ohms. I swapped the line and the correct temperature is displayed...great!!
                  Given that the readings at room temperature match expectations, I assumed @axiom omitted the „k“ from his measurement of the thermal sensing device.
                  @droftarts: From the posts, I conclude we face a thermistor. The successful tuning gives further evidence. However: Thx for your immediate reaction!
                  @axiom: When you told @droftarts you got a PT100 sensor, @droftarts had no choice: you should have followed his urgent warning to turn the printer off immediately. Be glad that he had an eye on this and takes care!
                  gloomyandyundefined 1 Reply Last reply Reply Quote 1
                    infiniteloop @axiom
                    @axiom
                    So you tuned the bed heater with a target temperature of 70°C.
                    Just 20 minutes? That’s fast! Can you please elaborate your setup: Was the heater glued to the bed or did you test the silicon mat in plain air? If the mat was glued to the bed: how thick is that metal plate? I wonder how such an assembly could heat up and cool down so quickly multiple times.
                    If you have a reasonable explanation for this, you can adjust your config.g according to the tuning results:
                    In your config, you have (or had) this line (after M308 S0 … and M950 H0 …) :
                    Replace that with the line you got from your tuning:
                    M307 H0 R0.283 K0.463:0.000 D7.17 E1.35 S1.00 B0 ; bed heater: enter tuning results, disable bang-bang
                    • gloomyandyundefined
                      gloomyandy @infiniteloop
                      @infiniteloop Unfortunately a PT100 at 20C reads about 107Ohms so that reading if it was reported accurately could be a PT100.
                      @axiom Was the resistance of the temperature sensor at room temperature 106Ohms or 106KOhms?
                        infiniteloop @gloomyandy
                        @gloomyandy said in How can I calibrate the temperature of my bed:
                        Right, that's why I'm really glad @droftarts intervened. However, the temperature readings resulting from the M308 parameters in the config would be quite different, especially as the OP stated that his PT100 boards were "not currently in use".
                        • axiomundefined
                          axiom @infiniteloop
                          It's ohms not kiloohms...according to the manufacturer, the bed has a PT100 sensor on it...but I haven't connected it to the PT100 daughterboard yet, but first to the onboard input...I just wanted to test all 4 mats connect parallel to the output and test again
                          gloomyandyundefined infiniteloopundefined 2 Replies Last reply Reply Quote 0
                            gloomyandy @axiom
                            @axiom Please see @droftarts comments above. If you really do have a PT100 continuing to operate your heated bed may cause damage.
                              infiniteloop @axiom
                              To clarify: could you please post a screenshot or a photo of the heater's data sheet? In addition, I would like to see an image of the heater's wiring. Thanks.
                              axiomundefined 2 Replies Last reply Reply Quote 0
                              • axiomundefined
                                axiom @infiniteloop
                                @infiniteloop
                                Technical Data of Silicone Heaters:
                                Supply Voltage: 0~400 V, 1 or 3 phase
                                Insulation Material: Fiberglass reinforced Silicone Rubber
                                Max. Operating Temp.: 260 Deg C or 500 Deg F
                                Min. Element Temp.: -50 Deg C or -58 Deg F
                                Max.Power Density: 5 w/sq.cm depending on application
                                Resistance Tolerance: about +/- 5%
                                Standard Thickness: 1.5 mm
                                Flammability: Flame Retardant
                                Moisture Absorption: Moisture proof
                                Power Leads: 1 meter by default,other length available upon request
                                • axiomundefined
                                  axiom @infiniteloop
                                    infiniteloop @axiom
                                    @axiom Thank you.
                                    From the technical data:
                                    Sorry, but from your photos, I can't see any signal lines from neither a thermistor nor a PT100. Are there separate lines, or is there just one cable with two leads? In other words: if there are both a thermistor and a PT100 as the seller states, how can I select one of these?
                                    • axiomundefined
                                      axiom @infiniteloop
                                      2 wires for the power supply/mosfet and 2 wires for the sensor. I think the PT100 is welded into the mat and the sensor output is then the connection
                                        infiniteloop @axiom
                                        That's what I think. But where is then the thermistor?
                                        On the one hand, you have a configuration for a thermistor (at least I think so):
                                        M308 S0 P"bedtemp" Y"thermistor" R4700 T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                                        … proper temperature readings, and - as it looks - a successful tuning. That tells me: your bed heater has a thermistor. You can't get all this with a PT100 at 106 Ohm resistance and wired without a daughterboard.
                                        On the other hand, your measurement of the sensor's resistance says: there's a PT100 built in.
                                        Which side should I believe? Can you perhaps give me a link to the manufacturer where he elaborates on the "thermal management solution" he proclaims?
                                        • axiomundefined
                                          axiom @infiniteloop
                                          @infiniteloop Hello, this is the link from the dealer for the heating mats. I have 4 pieces 400x400x24V.
                                          https://de.aliexpress.com/item/4000577539832.html?spm=a2g0o.order_list.0.0.58df5c5fjtq3G7&gatewayAdapt=glo2deu
                                          Today I would then like to connect the mats to the PT100 daugterboards and then connect the outputs in parallel.
                                          then I want to do the autotune. Is an average value then automatically calculated for the sensors? At least that's how I understood the description.
                                            @axiom please post your current config.g. Until we understand if you have PT100 or thermistor, it is difficult to advise you.
