    How can I calibrate the temperature of my bed
    Firmware installation
    8
    66
    3.0k
    • axiomundefined
      axiom @infiniteloop
      @infiniteloop
      Technical Data of Silicone Heaters:
      Supply Voltage: 0~400 V, 1 or 3 phase
      Insulation Material: Fiberglass reinforced Silicone Rubber
      Max. Operating Temp.: 260 Deg C or 500 Deg F
      Min. Element Temp.: -50 Deg C or -58 Deg F
      Max.Power Density: 5 w/sq.cm depending on application
      Resistance Tolerance: about +/- 5%
      Standard Thickness: 1.5 mm
      Flammability: Flame Retardant
      Moisture Absorption: Moisture proof
      Thermal Protection & Control: On board thermal fuse, thermostat, thermistor and PT100 are available as part of your thermal management solution.
      Power Leads: 1 meter by default,other length available upon request
      • axiomundefined
        axiom @infiniteloop
        • infiniteloopundefined
          infiniteloop @axiom
          @axiom Thank you.
          From the technical data:
          Sorry, but from your photos, I can't see any signal lines from neither a thermistor nor a PT100. Are there separate lines, or is there just one cable with two leads? In other words: if there are both a thermistor and a PT100 as the seller states, how can I select one of these?
          axiomundefined 1 Reply Last reply Reply Quote 0
          • axiomundefined
            axiom @infiniteloop
            2 wires for the power supply/mosfet and 2 wires for the sensor. I think the PT100 is welded into the mat and the sensor output is then the connection
              infiniteloop @axiom
              @axiom said in How can I calibrate the temperature of my bed:
              That's what I think. But where is then the thermistor?
              On the one hand, you have a configuration for a thermistor (at least I think so):
              M308 S0 P"bedtemp" Y"thermistor" R4700 T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
              … proper temperature readings, and - as it looks - a successful tuning. That tells me: your bed heater has a thermistor. You can't get all this with a PT100 at 106 Ohm resistance and wired without a daughterboard.
              On the other hand, your measurement of the sensor's resistance says: there's a PT100 built in.
              Which side should I believe? Can you perhaps give me a link to the manufacturer where he elaborates on the "thermal management solution" he proclaims?
              • axiomundefined
                axiom @infiniteloop
                @infiniteloop Hello, this is the link from the dealer for the heating mats. I have 4 pieces 400x400x24V.
                https://de.aliexpress.com/item/4000577539832.html?spm=a2g0o.order_list.0.0.58df5c5fjtq3G7&gatewayAdapt=glo2deu
                Today I would then like to connect the mats to the PT100 daugterboards and then connect the outputs in parallel.
                then I want to do the autotune. Is an average value then automatically calculated for the sensors? At least that's how I understood the description.
                droftartsundefined infiniteloopundefined 2 Replies Last reply Reply Quote 0
                  droftarts administrators @axiom
                  @axiom please post your current config.g. Until we understand if you have PT100 or thermistor, it is difficult to advise you.
                    infiniteloop @axiom
                    @axiom Moin,
                    Thank you for the link. Unfortunately, it isn’t very descriptive, especially concerning the thermal sensors. As far as I understand it, they provide either a thermistor or a PT100, not both. What you get depends on what you order from them. So the problem remains: we don’t know whether your heaters are equipped with thermistors or PT100 sensors.
                    Today I would then like to connect the mats to the PT100 daugterboards and then connect the outputs in parallel. Then I want to do the autotune.
                    As long as we are not sure what sensors you got, this is a bad idea. Instead, you can try to configure a single heater with a PT100 daughterboard and see what readings you get at room temperature. Please don’t power the heaters at this stage!
                    axiomundefined 2 Replies Last reply Reply Quote 0
                    • axiomundefined
                      axiom @infiniteloop
                      @infiniteloop Ok, then I'll wait, but what should I do?
                      • axiomundefined
                        axiom @infiniteloop
                        @infiniteloop I just got it now...I should just connect a sensor to the daughterboard and see what is displayed?
                          @axiom Please post your config.g. It will show what command you are using to get the sensor to show the correct room temperature. This will tell us if it's a thermistor or PT100.
                          • axiomundefined
                            axiom @droftarts
                            @droftarts
                            As discussed, I have now connected the bed sensor to a PT100 daughterboard.
                            The console shows 2000 degrees!!!!!
                            Here is the current code:Configuration file for Duet WiFi (firmware version 3.3)
                            ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Jul 26 2022 17:05:20 GMT+0200 (Mitteleuropäische Sommerzeit)
                            M550 P"Don axoiom" ; set printer name
                            M552 S1 ; enable network
                            M586 P0 S1 ; enable HTTP
                            M586 P1 S0 ; disable FTP
                            M586 P2 S0 ; disable Telnet
                            M569 P4 S1 ; physical drive 4 goes forwards
                            M584 X0 Y1 Z2 E4:3 ; set drive mapping
                            M92 X80.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm
                            M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                            M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
                            M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
                            M906 X1800 Y1600 Z1600 E1600:1600 I30 ; set motor currents (mA) and motor idle factor in per cent
                            M84 S30 ; Set idle timeout
                            M208 X500 Y500 Z500 S0 ; set axis maxima
                            M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                            M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                            M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
                            M558 P1 C"zprobe.in" H5 F300 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                            G31 P500 X20 Y20 Z2.5 ; set Z probe trigger value, offset and trigger height
                            M308 S0 P"spi.cs1" Y"rtd-max31865" ; configure sensor 0 as PT100 on pin spi.cs1
                            M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
                            M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
                            M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                            M143 H2 S280 ; set temperature limit for heater 2 to 280C
                            M950 F0 C"fan1" Q500 ; create fan 0 on pin fan1 and set its frequency
                            M106 P0 S1 H0 T45 ; set fan 0 value. Thermostatic control is turned on
                            M950 F1 C"fan0" Q500 ; create fan 1 on pin fan0 and set its frequency
                            M563 P0 S"Filament" D0 H1 F0 ; define tool 0
                            M563 P1 S"Stuetzkonstruktion" D1 H2 F0 ; define tool 1
                              infiniteloop @axiom
                              Yep. And I see from your config that you've done that. What temperature readings do you now get from the bed heater at room temperature?
                              • axiomundefined
                                axiom @infiniteloop
                                @infiniteloop 2000 degrees!!!
                                  infiniteloop @axiom
                                  2000 degrees!!!
                                  That's far off. I would like to have @droftarts takes a look at this - I don't know what readings the daughterboard should produce if connected to a thermistor instead of a PT100.
                                  • axiomundefined
                                    axiom @infiniteloop
                                    @infiniteloop
                                    understand, ask him directly or do I need to contact @droftarts?
                                      @axiom cooking dinner at the moment! Can you post a picture of how you have wired the bed temp sensor to the daughterboard and Duet?
                                        infiniteloop @droftarts
                                        @droftarts said in How can I calibrate the temperature of my bed:
                                        bon appétit!
                                        • axiomundefined
                                          axiom @infiniteloop
                                            infiniteloop @axiom
                                            @axiom Thx. @droftarts will have a look at the photos … after dinner.
