Crying stepper motors
1.1k
    jason0607
    Hello!
    I have connected stepper motors, but they "cry" when I start them up on the Duet3Mini5+. Is there a solution for this?
    undefined undefined 3 Replies Last reply 12 Aug 2022, 10:33 Reply Quote 0
      dc42 administrators @jason0607
      @jason0607 usually this means that you have set a combination of acceleration too high, steps/mm too high, max movement speed too high, or motor current too low. If you post your config.g file and tell us what motors you are using, we can help further.
        jason0607
        M550 P"My Printer" ; set printer name
        M552 P169.254.179.25 S1 ; enable network and set IP address
        M553 P255.255.0.0 ; set netmask
        M554 P192.168.150.1 ; set gateway
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
        M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
        M203 X1000.00 Y1000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
        M201 X200.00 Y200.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
        M906 X200 Y200 Z200 E200 I60 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X230 Y210 Z200 S0 ; set axis maxima
        M574 X1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io1.in
        M574 Y2 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io2.in
        ;M950 S0 C"io3.out" ; create servo pin 0 for BLTouch
        ;M558 P9 C"temp2" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
        ;G31 P500 X25 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
        ;M557 X15:215 Y15:195 S20 ; define mesh grid
        M308 S0 P"spi.cs1" Y"thermocouple-max31856" A"Thermocouple" K"K" F50 ; configure sensor 0 as typ k thermocouple on pin spi.cs1 (TC0)
        M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
        M143 H0 S280 ; set temperature limit for heater 0 to 280C
        ;M308 S1 P"1.spi.cs1" Y"thermocouple-max31856" K"S"; define temperature sensor number 1 as a Type thermocouple on the first port of a temperature daughter board plugged into the expansion board with CAN bus address 3.
        ;M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
        ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
        ;M143 H1 S280
        ;Fans
        M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
        M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
        ;M563 P0 D0 H1 F0 ; define tool 0
        ;G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets
        ;G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
        T0 ; select first tool
        ; Configuring steps and speeds
        M584 X0 Y1 Z2:3 E4:5 ; set drive mapping
        M92 X80.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm
        ;Setting motor speeds and accelerations
        M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X500.00 Y500.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
        M201 X69000.00 Y69000.00 Z20.00 E250.00:250 ; set accelerations (mm/s^2)
        ;Setting motor currents
        ;M584 X0 Y1 Z2:3 E4:5 ; set drive mapping
        ;M906 X400 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
        undefined 1 Reply Last reply 16 Aug 2022, 06:45 Reply Quote 0
          jason0607
          Motor: / 103-H5210-4240 / NEMA17 / Flansch 42mm / 1A / 51 Ncm
            jason0607 @jason0607
            This post is deleted!
              undefined 1 Reply Last reply 16 Aug 2022, 06:44 Reply Quote 0
                Rushmere3D @jason0607
                @jason0607 I would say your motor current is to low. 200mA, for a 1A motor. Try increasing those to say 800mA.
                Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
                  @jason0607 you also have multiples of some commands acceleration, feedrate etc. Some are commented out but not all.
                  This for example is at the bottom of your config,
                  While you have another at the top,
                  The one at the bottom is way to high and getting used as it's called last.
                    jason0607
                    @Rushmere3D
                    M906 X800 Y800 Z800 E800 I60 ; set motor currents (mA) and motor idle factor in per cent
                    ;M143 H1 S280
                    ;Fans
                    ;M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
                    ;M92 X80.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm
                    ;M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                    ;M203 X500.00 Y500.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
                    ;M201 X69000.00 Y69000.00 Z20.00 E250.00:250 ; set accelerations (mm/s^2)
                    undefined 1 Reply Last reply 16 Aug 2022, 06:53 Reply Quote 0
                      @jason0607 Yeah better, you will need to maybe adjust some of your settings but that should work.
                      You have commented out you Tool settings.
                        jason0607
                        @Rushmere3D
                        Now the motor is just as loud but moves slower
                        undefined undefined 2 Replies Last reply 16 Aug 2022, 07:03 Reply Quote 0
                          @jason0607 Are the phases of the stepper motors connected correctly?
                          Is this a new build? Your config has multiple M584 commands make sure you have the correct one in use.
                            @jason0607 Yes they are connected correctly
                            undefined 1 Reply Last reply 16 Aug 2022, 07:13 Reply Quote 0
                              @jason0607 I would say these settings need, tweaking.
                              Something like this maybe? BUT you need to adjust based on your machine, these are based on one of my printers.
                              M566 X300.00 Y300.00 Z60.00 E420.00 ; set maximum instantaneous speed changes (mm/min)
                              M203 X18000.00 Y18000.00 Z360.00 E1500.00 ; set maximum speeds (mm/min)
                              M201 X3000.00 Y3000.00 Z300.00 E10000.00 ; set accelerations (mm/s^2)
                              undefined 1 Reply Last reply 16 Aug 2022, 07:50 Reply Quote 0
                                Rushmere3D
                                Would also be a good idea to share the results of m122 and M98 P"config.g" please?
                                undefined 2 Replies Last reply 16 Aug 2022, 07:31 Reply Quote 0
                                  jason0607 @Rushmere3D
                                  @rushmere3d
                                  RepRapFirmware for Duet 3 Mini 5+ version 3.4.1 (2022-06-01 21:06:56) running on Duet 3 Mini5plus Ethernet (standalone mode)
                                  Board ID: 0KSJD-0296U-D65J0-40KMS-K803Z-H4BUF
                                  Used output buffers: 3 of 40 (14 max)
                                  Static ram: 103684
                                  Dynamic ram: 104352 of which 100 recycled
                                  Never used RAM 33504, free system stack 182 words
                                  Tasks: NETWORK(ready,25.6%,244) ETHERNET(notifyWait,0.2%,576) HEAT(notifyWait,0.0%,374) Move(notifyWait,0.0%,290) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,339) TMC(notifyWait,0.7%,81) MAIN(running,71.8%,510) IDLE(ready,1.0%,29) AIN(delaying,0.8%,264), total 100.0%
                                  Owned mutexes:
                                  Last reset 00:00:56 ago, cause: software
                                  Last software reset at 2022-08-16 09:30, reason: User, GCodes spinning, available RAM 33520, slot 1
                                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                  Error status: 0x00
                                  MCU revision 3, ADC conversions started 56285, completed 56285, timed out 0, errs 0
                                  Step timer max interval 1487
                                  MCU temperature: min 23.9, current 24.8, max 24.8
                                  Supply voltage: min 24.0, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                                  Events: 2 queued, 2 completed
                                  Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 21, reads 2937, writes 11, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 27, reads 2935, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 27, reads 2934, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 21, reads 2936, writes 11, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 19, reads 2939, writes 9, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 5: not present
                                  Driver 6: not present
                                  Date/time: 2022-08-16 09:31:34
                                  Cache data hit count 97077235
                                  Slowest loop: 299.88ms; fastest: 0.13ms
                                  === Storage ===
                                  Free file entries: 10
                                  SD card longest read time 3.4ms, write time 11.7ms, max retries 0
                                  DMs created 83, segments created 3, maxWait 40644ms, bed compensation in use: none, comp offset 0.000
                                  === MainDDARing ===
                                  Scheduled moves 6, completed 6, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
                                  === AuxDDARing ===
                                  Segments left: 0
                                  Movement lock held by null
                                  HTTP is idle in state(s) 0
                                  Telnet is idle in state(s) 0
                                  File is idle in state(s) 0
                                  USB is idle in state(s) 0
                                  Aux is idle in state(s) 0
                                  Trigger is idle in state(s) 0
                                  Queue is idle in state(s) 0
                                  LCD is idle in state(s) 0
                                  SBC is idle in state(s) 0
                                  Daemon is idle in state(s) 0
                                  Aux2 is idle in state(s) 0
                                  Code queue is empty
                                  === CAN ===
                                  Messages queued 282, received 0, lost 0, boc 0
                                  Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 282/0/0
                                  Tx timeouts 0,0,281,0,0,0 last cancelled message type 30 dest 127
                                  === Network ===
                                  Slowest loop: 101.62ms; fastest: 0.03ms
                                  HTTP sessions: 1 of 8
                                  • Ethernet -
                                    State: active
                                    Error counts: 0 0 0 0 0
                                    @rushmere3d Error: M98: control character in string
                                    undefined 1 Reply Last reply 16 Aug 2022, 07:45 Reply Quote 0
                                      @jason0607
                                      M98 P"config.g"
                                      Didn't work?
                                      I'm out of ideas if your still having issues I'm sorry to say.
                                      undefined 1 Reply Last reply 16 Aug 2022, 07:52 Reply Quote 0
                                        @Rushmere3D What would be the settings for my motor?
                                        undefined 1 Reply Last reply 16 Aug 2022, 07:54 Reply Quote 0
                                          @rushmere3d M98 P"config.g"
                                          HTTP is enabled on port 80
                                          FTP is disabled
                                          TELNET is disabled
                                          Error: Failed to initialise thermocouple: bad response from sensor
                                          Warning: Sensor number 0 has not been defined
                                          1 out of 28
