    Everytime I run stop.g I get a heater 1 fault.....
    Using Duet Controllers
    heater fault stop.g
    492
    • dmandnundefined
      dmandn
      Everytime I run stop.g I get a heater 1 fault, I can print with this printer fine and everything seems normal, until stop.g is called.
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.1 (2022-06-01)
      Duet WiFi Server Version: 1.26
      I think I have made a mistake in my stop.g code, but can't seem to find the issue. I have ruled out the tune played at the end, and can see that the temps drop away normally to around 65ish then it goes crazy. So guessing it is to do with turning the hotend off?
      Note, this issue has carried through a firmware update and a temp sensor and wiring replacement.
      Stop.g
      ; stop.g
      ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
      M83 ; Relative extruder moves
      G91 ; Relative positioning
      G1 Z10 F3000 ; Lift gantry + nozzle 10mm
      G1 E-10 F600 ; Retract 10mm of filament
      ; M702 ; Unload filament settings from tool
      M117 "Retracted filament!"
      G10 ; Retract
      G1 E-5 F300 ; Retract 5mm filament to ensure clean homing on next run
      G10 P0 R0 S0 ; Turn-off hotend
      M116 P0 S50 ; Wait for temperatures to drop
      M117 "Extruder cooled!"
      ; Turn off fan
      M106 P1 S0 ;Turn-off extruder/HS fan
      M117 "Extruder fan off!"
      M140 S0 ; Turn off bed heater
      M106 S0 ; turn off part cooling fan
      M117 "Bed off!"
      G28 X ; Home X
      G1 Y330 ; Move head to rear left for complete bed & print access
      M98 P0:/Macros/Tunes/Mario.g ; call Mario.g tune macro file
      M81 ;Power Down to save power.
      gloomyandyundefined OwenDundefined 2 Replies Last reply Reply Quote 0
      • gloomyandyundefined
        gloomyandy @dmandn
        @dmandn What heater fault are you getting? It would also probably help if you could post a screen grab of the temperature chart when you get the error.
          How are you invoking stop.g?
          dmandnundefined 1 Reply Last reply Reply Quote 0
          • OwenDundefined
            OwenD @dmandn
            @dmandn said in Everytime I run stop.g I get a heater 1 fault.....:
            This shouldn't cause a heater fault but it won't work as you intend.
            Based on the S parameter of 50, I suspect you're trying to wait till the hotend gets to 50 degrees. (0 degrees +/- 50)
            However, M116 won't wait for target temps less than or equal to 40 degrees C
            So you would need to do it in two steps
            G10 P0 R0 S41
            M116
            G10 P0 S0 R0
            You should probably use M568 as G10 will likely be deprecated in future
            dmandnundefined 1 Reply Last reply Reply Quote 2
            • dmandnundefined
              dmandn @Phaedrux
              @phaedrux I'm using M0 in my slicer endcode.
              • dmandnundefined
                dmandn @OwenD
                @owend Ok, I will try this and see if it helps. Thank you!
                • dmandnundefined
                  dmandn @dmandn
                  Interesting, I just tried a print from prusaslicer and did not get an error after..... Maybe I have my profile wrong in Cura. Will have a look and get back to you.
                    Can you post an example file sliced in each?
                    • dmandnundefined
                      dmandn @Phaedrux
                      @phaedrux Yes, I will need to run more tests but will get an example from each from my printer tomorrow. Apologies for the slow replies. I only get to work with my printers on some weekends. My wife doesn't like me spending time with them XD
                      dmandnundefined 1 Reply Last reply Reply Quote 1
                      • dmandnundefined
                        dmandn @dmandn
                        Ok, this has now been resolved (at least on one printer. Will test on the others once I have rewired them).
                        To fix the issue, had to update firmware and rewrite the stop.g and cancel.g files. Guessing issue was somewhere in the old firmware or in those configs.
                        Updated to RRF3.4.4 (Sorry, the printers were in storage for months).
                        Cleared all entries in stop.g and started over.
                        Then found it would throw the heater fault on cancel.g but is now fine on stop.g.
                        Cleared cancel.g, then rewrote it calling stop.g with a couple calls before and it works now too.
                        On another topic, also found on very rare occasions to be breaking contact on the connector, even with new wires, new molex connector crimped, and new senso with appropriate connector. I have found this can be averted by fixing the connectors so they are not free to move around. ...I need to revise my cable management.
                        • droftartsundefined droftarts marked this topic as a question
                        • droftartsundefined droftarts has marked this topic as solved
