    SD Card not working
    738
    • AdrAsundefined
      AdrAs @jay_s_uk
      @jay_s_uk
      Yes, it is. Got it from china yikes
      AdrAsundefined 1 Reply Last reply Reply Quote 0
      • AdrAsundefined
        AdrAs @AdrAs
        @adras
        Maybe I broke the firmware, I think at one time I accidentally flashed DuetWifiServer.bin with bossa.
        Is there a way to make a complete reset of the processor? Because even after erasing it, my wifi settings are still present. Maybe there's something stuck in the memory somewhere
          dc42 administrators @AdrAs
          @adras you are running old beta firmware. Please upgrade to the 3.4.1 release.
          • AdrAsundefined
            AdrAs @dc42
            Still the same with 3.4.1. When I use 3.4.1 RC2 and run M122 I hear the windows device disconnect sound and I don't get any output at all
            • AdrAsundefined
              AdrAs @AdrAs
              m588 S"*"
              Failed to reset the WiFi module to factory settings
              ok
              This is also kinda interesting. Why doesn't that work?
              cncmachineguyundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
              • cncmachineguyundefined
                cncmachineguy @AdrAs
                @adras maybe because of this:
                "Yes, it is. Got it from china yikes"
                  jay_s_uk @AdrAs
                  @adras try sending M552 S0 before sending M558 S"*"
                    It's also possible you don't have a proper firmware flashed to the wifi module. Take the wifi server bin from the latest release and try flashing it with M997 S1.
                    If it still can't read from the SD card, then I think your socket may need to be reflowed.
                    AdrAsundefined 2 Replies Last reply Reply Quote 1
                    • AdrAsundefined
                      AdrAs @Phaedrux
                      @phaedrux
                      M997 S1 doesn't work, because the file is never found. I put one in the sys, one in the firmware and one in the www directory, I even specified the path myself
                      • AdrAsundefined
                        AdrAs @Phaedrux
                        @phaedrux
                        WOHOOO finally. Your reflow idea was great. I just used my hot air rework station set it to 350°C and heated the thing up. I saw some vapor/smoke coming (could have been some remaining flux from my soldering attempt).
                        But now ...
                        m21
                        Error: M21: No SD card present
                        ok
                        m21
                        SDHC card mounted in slot 0, capacity 31.91Gb
                        ok
                        My panel due is also lighting up now.
                        Cool, thanks for your help guys
                        • Phaedruxundefined Phaedrux has marked this topic as solved
                        • AdrAsundefined
                          AdrAs @AdrAs
                          Well, turned out it was something completely different. I just hooked up the board again and the panel due was blank. Suddenly everything stopped working.
                          It was also weird, that the Serial port changed. The working one was no. 4, the not working one was no.3. Then I thought ... wait a minute ... I've got two usb ports on my laptop, let's use the other one.
                          Turned out that connecting the duet to one port works, but connecting the duet to the other one doesn't.
                          I just used a usb tester. On the working port the duet board consumes about 300mA, on the non working port it consumes only 100mA.
                          And I thought the usb-port survied that 12V incident a couple of years ago. But even if the fuses seem to have recovered, that port is no longer able to deliver enough power.
                          So the entire problem all the time was having the duet connected to a broken usb-port which doesn't provide enough power.
