Warning: Cannot Initialize SD Card 0: Card is Unusable
@dc42 I did try this first with my professors card, then with a fresh one and got the same message.
Can you try sending these commands?
M552 S-1
M552 S0
M552 S1
M997 S1And report back with what you get.
hi,
just tried these and here is the error message I got -
Can you take a photo of the solder points around the SD card?
Is this a brand new board? Or has it been working previously?
@phaedrux It is a brand new board, I purchased it from MatterHackers about a week ago. I will send a pic
Are you able to view the contents of the original SD card on a PC?
@phaedrux yes, here is what I'm seeing
@phaedrux Full disclosure: i really need this printer to work before the end of this summer for my ceramic 3d printer project for school. i have spent so much time troubleshooting this board and I was so close before it stopped working. I was told I need approval from the forum to get it exchanged. Does it seem like something fixable or will I need a new board? Apologies for my directness im just in a bit of a time crunch. Again, I really appreciate all of the help
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
Sorry for the inconvenience.
Hello again,
Thank you for sending the Duet, thankfully it is working a lot better than the initial one, and is finally providing a wifi signal remotely.
That being said... I am now having trouble with my config.g file it seems. I am connected to the IP address all good but the board is having trouble homing the steppers. I am using my old config.g file since the new one wasnt even sending a consistent Access point out. I will send a screenshot of my current config. As always, Any advice is appreciated!
@mfertik We'll need to see the whole of your config.g. It's easier to copy the text from the config.g file, and paste it in your reply on the forum, rather than post images of it.
And we'll need to know a bit more about your machine. Is it a delta printer? I can see M665 and M666 commands. Usually, the endstops on a delta need to home at the maximum end of each axis, not the minimum, so your endstop assignment (which I can't see in the screenshot above) should look something like:
; Endstops M574 X2 S1 P"xstop" ; active-high endstop for high end on X via pin xstop M574 Y2 S1 P"ystop" ; active-high endstop for high end on Y via pin ystop M574 Z2 S1 P"zstop" ; active-high endstop for high end on Z via pin zstop
Note the X2, Y2 and Z2, which make the axis home at the 'high' end. You may also need to edit your homedelta.g file. Post that in your reply too.
@droftarts Hi Ian,
thanks for the quick reply. Yes, it is a delta printer that i made using the Jonathan keep open source model. I will paste my config below:; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Jul 29 2022 13:47:04 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"Max Printer" ; set printer name
M665 R112 L232 B100 H260 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M551 P"12345678" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet;networking
M540 PDE:AD:BE:EF:CA:FE ; MAC Address
M552 S2 ; start wifi network; Drives
M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop; Z-Probe
M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
M557 R85 S20 ; define mesh grid; Heaters
@mfertik said in Warning: Cannot Initialize SD Card 0: Card is Unusable:
What exactly happens?
Can you also post your homedelta.g and send M122 and M98 P"config.g" and copy paste the results here?
@phaedrux the first time i tried it, the X and Y axes began to home and then stopped. The next few times i tried to home them, i just got a loading wheel on the Movement Dashboard.
Here is my homedelta.g:
; homedelta.g
; called to home all towers on a delta printer
G91 ; relative positioning
G1 H1 X265 Y265 Z265 F1800 ; move all towers to the high end stopping at the endstops (first pass)
G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
G90 ; absolute positioning
G1 X0 Y0 F6000 ; move X+Y to the centre -
@phaedrux P.S. where should I send M122 and M98 P"config.g" ? In the config.g or in the homedelta.g?
In the gcode console tab in DWC.
Also, please check your version of DWC in the general tab of DWC.
@phaedrux The issue has been resolved! thanks for all your help
@mfertik What changed?
