    inputshaping issue
    input shaper
    826
    • sinoleundefined
      sinole
      My printer ca detect the accelerometer
      "m955 p0
      Accelerometer 0 type LIS3DH with orientation 41 samples at 1344Hz with 10-bit resolution, SPI frequency 2000000"
      but I every time I try to record motion , i get this error:
      Error: M956: Failed to start accelerometer data collection
      can anyone tell me what is going wrong?
      appriciate the hlep
      Norderundefined 1 Reply Last reply Reply Quote 0
      • Norderundefined
        Norder @sinole
        @sinole
        Please post the content of your config.g file.
        This is important to localize the error.
        DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
        Thingiverse
        sinoleundefined 1 Reply Last reply Reply Quote 0
        • sinoleundefined
          sinole @Norder
          @norder
          ; Configuration file for BTT SKR 2 (firmware version 3)
          ; generated by RepRapFirmware Configuration Tool v3.4.0-LPC-STM32+2 on Thu May 26 2022 15:28:29 GMT-0700 (Pacific Daylight Time)
          M80 C"pson" ;PSON
          M550 P"Sinole3D1" ; set printer name
          M575 P1 S2 B57600
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S1 ; disable FTP
          M586 P2 S0 ; disable Telnet
          ;Screen Setting
          ;M918 P1 E4 F100000 ;LCD
          M575 P1 S2 B57600 ;set tft
          M569 P0 S1 D3 V4000 ; physical drive 1 goes forwards - x-axis
          M569 P1 S0 D3 V4000 ; physical drive 1 goes backwards - y-axis
          M569 P2 S1 D3 V40 ; physical drive 2 goes backwards - z - left
          M569 P3 S1 D3 V40 ; physical drive 3 goes forwards - Extruder
          M569 P4 S1 D3 V40 ; physical drive 4 goes backwards - z righ
          M584 X0 Y1 Z2:4 E3 ; set drive mapping
          M671 X-39:291 Y0:0 S1.00 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
          M350 X16 Y16 Z16:16 E16 I1 ; configure microstepping with interpolation
          M92 X100.00 Y200.00 Z400.00:400.00 E830.00 ; set steps per mm
          ;speed
          M566 X600.00 Y600.00 Z24.00:24.00 E270.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X12000.00 Y12000.00 Z720.00:720.00 E7200.00 ; set maximum speeds (mm/min)
          M201 X3000.00 Y3000.00 Z200.00:200.00 E1250.00 ; set accelerations (mm/s^2)
          M204 P3000.0 T3000.0 ; set print and travel accelerations (mm(s^2)
          ;M201 X500.00 Y500.00 Z100.00 E500.00 ; set accelerations (mm/s^2)
          ;M203 X12000.00 Y12000.00 Z1200.00:1200.00 E7200.00 ; set maximum speeds (mm/min)
          ;M204 P500.0 T500.0 ; set print and travel accelerations (mm(s^2)
          ;M566 X600.00 Y600.00 Z48.00 E270.00 ; set maximum instantaneous speed changes (mm/min)
          M906 X1200 Y1700 Z400:400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S50 ; Set idle timeout
          M208 X0 Y-4 Z0 S1 ; set axis minima
          M208 X255 Y212.5 Z210 S0 ; set axis maxima
          M574 X1 S3 ; configure sensorless endstop for low end on X
          M574 Y1 S3 ; configure sensorless endstop for low end on Y
          ;M574 Z2 S3 ; configure sensorless endstop for high end on z
          M558 P5 C"zstop" H1 F600 T8000 A3 S0.03 ; set z probe to super pinda
          ;M308 S2 P"e1temp" A"Pinda V2" Y"thermistor" T100000 B3950 ; temperature of PINDA2
          ;G31 H2 S30 T0.005 X23 Y5 Z0.5 ; set Z probe trigger value, offset and trigger height
          ;G31 P1000 H2 S30 T0.005 X23 Y5 Z0.55 ; set Z probe trigger value, offset and trigger height super pinda
          M557 X25:250 Y5:200 S35 ; define mesh grid
          M574 Z1 S2 ; set endstops controlled by prob
          ; Stallguard Sensitivy
          M915 X S2 H200 R0 ; set X axis Sensitivity
          ;M915 X S2 R0
          M915 Y S1 H400 R0 ; set Y axis Sensitivity
          ;M915 Y S1 R0
          ;M915 Z S0 H150 R0 ; set Z axis Sensitivity
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
          M950 H0 C"bed" T0 ; create bed heater output on bed and map it to sensor 0
          M307 H0 R0.239 K0.525:0.000 D7.19 E1.35 S1.00 B0 ; disable bang-bang mode for the bed heater and set PWM limit
          ;M570 H0 S60 T2
          M308 S1 P"e0temp" Y"thermistor" C7.060000e-8 T100000 B4725 ; configure sensor 1 as thermistor on pin e0temp
          M307 H1 R2.623 K0.287:0.000 D7.21 E1.35 S1.00 B0 V24.0 ; disable bang-bang mode for heater and set PWM limit
          M106 P1 S0 H1 T45 ; set fan 1 value. Thermostatic control is turned on and set to 50% duty
          M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
          M106 P2 S0 H-1 ; set fan 2 value. Thermostatic control is turned off
          M302 S180 R180 ; allow extrusion starting from 180°C and retractions already from 180°C
          ; Custom settings
          ; other settings
          M18 XY ; release / unlock x, y
          M501 ; use config-override (for Thermistor Parameters and other settings)
          M83 ; ... but relative extruder moves
          ; filament handling
          ; execute macros that determine the status of the filament sensor
          M98 P"0:/sys/00-Functions/FilamentsensorStatus"
          ; Offsets - place off-sets for x and y here. z-offsets are handled in the print sheet macros
          G31 P1000 X23 Y5
          M950 J3 C"nil"
          M950 J3 C"PWRDET" ; input 1 e0 filament sensor
          M581 P3 T3 S0 R1 ; PLR sensor P1 triggers Trigger3.g always (R0) TRIGGER OFF
          M669 S1 t1
          ; Neopixel LED
          M150 X2
          M150 R255 U0 B0 P255
          G4 P600
          M150 R0 U255 B0 P255
          G4 P600
          M150 R0 U0 B255 P255
          G4 P600
          M150 R255 U255 B255 P255
          ; accelratometer
          M955 P0 C"E.9+E.10" I41
          • Norderundefined
            Norder @sinole
            @sinole
            Check if you have wired the LIS3DH correctly.
            I am not familiar with the Bigtreetech board and therefore do not know whether the entry C"E.9+E.10" is correct.
            Sorry I'm out of here.
            Thingiverse
            sinoleundefined 1 Reply Last reply Reply Quote 1
            • Mandragoraundefined
              Mandragora
              I was fighting with my accelerometer yesterday - LIS3DSH.
              1st it wasn't recognised on selected port, 680Ohm resistor on SDA SDO line helped.
              2nd I wanted to get some data to check if gravity is sensed but got similar error that I can't collect data. I didn't found any info on forum or wiki. Turned out that data can be collected after I homed the printer.
              • sinoleundefined
                sinole @Norder
                @norder ye, the setup is not for a duet board but I spoke with people on teamglumy actually gloomyandy himself, looks like the problem is the cable that I am using, a lot of people are having success with quality shielded usb cables and apparently it helps to reduce frequency. thank you for trying to help.
                • Norderundefined
                  Norder @sinole
                  @sinole said in inputshaping issue:
                  I can say something about that.
                  I took a USB3 cable and for the CS channel, which is the most sensitive, I took 2 wires of the USB3 cable, which are shielded together separately.
                  Maybe that helps you a little further?
                  Google Translate
                  --- Original Text ---
                  Dazu kann ich etwas sagen.
                  Ich habe ein USB3 Kabel genommen und für den CS Kanal der am empfindlichsten ist, habe ich 2 Adern des USB3 Kabels genommen die zusammen extra für sich noch einmal abgeschirmt sind.
                  Vielleicht hilft Dir das etwas weiter ?
                  Thingiverse
                  • sinoleundefined
                    sinole @Norder
                    @norder
                    thank you, I am trying lots of stuff, ill add that to the list. 😁
                    My theory is that my sensor is faulty. I used very very short USB cable and have same result.
                    some people add a resistor SDO I think.
                    • sinoleundefined
                      sinole @Mandragora
                      @mandragora I red I should add 1k resistor on SDO. are you sure its SDA? I do home my printer before readings , it still says: M400 M956 P0 S1000 A0 F"1-X64-191-0-none.csv" G1 X191 F12000
                      Mandragoraundefined 1 Reply Last reply Reply Quote 0
                        Mandragora @sinole
                        @sinole You are right, it is SDO, as documentation says here:
                        https://docs.duet3d.com/User_manual/Connecting_hardware/Sensors_Accelerometer
                        I've miss typed, gonna edit my post above.
                        • sinoleundefined
                          sinole @Mandragora
                          @mandragora I appriciate you sending me this link, I need to use a usb wire for cs that is running in a separate jacket looks like. I understand what could go wrong now.
                          • sinoleundefined
                            sinole
                            well I tried everything, I dont think this is wire issue, acclerometer is being detected but It doesn't stert recording.
                            "m955 p0
                            M956 P0 S1000 A0 F"4-X64-191-0-none.csv" G1 X191 F12000
                            in recorded file:
                            Sample,X,Y,Z
                            gloomyandyundefined 1 Reply Last reply Reply Quote 0
                            • gloomyandyundefined
                              gloomyandy @sinole
                              @sinole You are using an SKR 2 right? Please post the output from M122 P200 plus details of your M955 command. You can either do that here or over on our discord (please use the stm32-wifi-firmware channel).
                              • sinoleundefined
                                sinole @gloomyandy
                                @gloomyandy I put it there ill add it here too maybe it helps someone some day
                                m122.txt
                                m955 p0
                                Accelerometer 0 type LIS3DH with orientation 41 samples at 1344Hz with 10-bit resolution, SPI frequency 1000000
