    ST3Di Modelsmart 280 - Duet Maestro repair/upgrade
    My Duet controlled machine
    13
    139
    9.2k
    • Blacksheep99undefined
      Blacksheep99 @Hulsie3216
      @hulsie3216 hi, sorry I’ve just seen this. Currently on holiday but I’ll send you the info when I get a chance
      • DanWilliams94undefined
        DanWilliams94 @Hulsie3216
        @hulsie3216 can u send me the settings for cura because I tried slicing something and uploading it to the sd card and nothing shows?
          DanWilliams94 @Blacksheep99
          @blacksheep99 by any chance to u still have the g code edit?
          Blacksheep99undefined 2 Replies Last reply Reply Quote 0
            Blacksheep99 @DanWilliams94
            @danwilliams94 I have a guide somewhere. I'll dig it out and put a link here
              @danwilliams94 See if this works
              https://docs.google.com/document/d/1xLjEwIyu_P7TE6h6DIhYH68IQRL0Qa_p/edit?usp=sharing&ouid=116402951384827293733&rtpof=true&sd=true
              DanWilliams94undefined 2 Replies Last reply Reply Quote 0
                @blacksheep99
                My g codes don't look the same mine say this
                FLAVOR:Marlin
                ;TIME:31184
                ;Filament used: 8.0111m, 0m
                ;Layer height: 0.15
                ;MINX:60.218
                ;MINY:60.428
                ;MINZ:0.3
                ;MAXX:144.789
                ;MAXY:141.628
                ;MAXZ:116.55
                ;Generated with Cura_SteamEngine main
                T0
                M104 S200
                M105
                M109 S200
                M82 ;absolute extrusion mode
                G21 ;metric values
                G90 ;absolute positioning
                M82 ;set extruder to absolute mode
                M107 ;start with the fan off
                G28 X0 Y0 ;move X/Y to min endstops
                G28 Z0 ;move Z to min endstops
                G1 Z15.0 F9000 ;move the platform down 15mm
                T1 ;Switch to the 2nd extruder
                G92 E0 ;zero the extruded length
                Blacksheep99undefined 1 Reply Last reply Reply Quote 0
                  @blacksheep99 what would be ideal if I could get hold of the editor but I think the company went bust some time ago been looking online just incase someone made a copy of it but no look finding st3di edit
                    @danwilliams94 I have a copy. Link incoming
                      @danwilliams94
                      Hopefully works
                      https://drive.google.com/file/d/1f1yuOidiOxlcGvqfJhKm9rftpKGLOB2k/view?usp=drivesdk
                      DanWilliams94undefined 1 Reply Last reply Reply Quote 0
                        @blacksheep99
                        Worked perfect thank you for that your a life saver
                        My next question as these sealed spools of filament are no longer made I do have a full one but do u rekon I should make a spool holder and trick the machine because I have tons of standard pla and abs plastic on spools and I would rather use them because I can replace them fairly easily or would the st3di think something is wrong I'm not sure how smart this machine actually is tbh I'm not sure if u managed to use other rolls of filament and if so how
                          @danwilliams94 I just used to leave on of the spools on and then feed in any of the other filaments I wanted to use. That was before I swapped out to the Duet
                            @danwilliams94
                            Hopefully this word doc has the config files in. The principles should still be true.
                            https://docs.google.com/document/d/1T86iTxZwGsj3nLFBjzRinjlMTsEoz19Z/edit?usp=sharing&ouid=116402951384827293733&rtpof=true&sd=true
                            I'd move to Cura or Prusaslicer rather than use the old ST3DI slicer if you can.
                            The pla@**** is what is telling the printer how much filament you have used from their spools.
                            DanWilliams94undefined Asdfasdf426undefined 2 Replies Last reply Reply Quote 0
                              @blacksheep99
                              Yeah I'll give it ago again trying to set it up on cura later on its just abit of headscraching and headache then I'll figure it out 🤣
                              • Asdfasdf426undefined
                                Asdfasdf426 @Blacksheep99
                                @blacksheep99 Hi I know I'm a bit late to the thread but I have a ST3Di 280 printer and I am trying to set it up with Cura and to use 3d party filament. But in you word document I am unable to open them and they seem to be formatted as images. do you have another way that I can access these files.
                                  Blacksheep99 @Asdfasdf426
                                  @asdfasdf426 Hi, send me a DM with your email. I'll send you the word doc. I hoped you could right click the links here and save as?
                                  Asdfasdf426undefined 1 Reply Last reply Reply Quote 0
                                    @blacksheep99 I can open the links in this thread to get the google doc, my problem is that when you say save these file in the doc I cant because when I click on them they are images and I don't know what's happening same thing with the Cura profile (the one in the document that you have created I cant open it and when I click on it is treated like an image.) And I am unable to open/save the setup files. I am not sure what the problem is do you have any idea
                                      @asdfasdf426
                                      Link to a zip with the config files in
                                      https://drive.google.com/file/d/1JSyTzxHwKSFLeYJ-qqXJ88_kIwULIfp4/view?usp=sharing
                                      let me know if this works.
                                        @blacksheep99 Hi I think I may be having a small problem when I load gcode (from cura) onto a Micro SD card and put it in the printer the printer says no models found. To set up cura I just copied and pasted the start and gcode from your ST3Di_Modelsmart_200.def.json.zip file. Was this the right way to that or have I done it wrong. Or do you know if this may be another Issue.
                                        Additionally, do you know what I should put for the X and Y offsets for the nozzles because I don't really know what they are and how to find them out. (I just measured the distance between the nozzles with a vernier callipers and but that as the X offset Which I'm sure is not the right way, Do you possibly know how to do it and/or have the offsets?) Thanks for all your help so far.
                                          @blacksheep99 Also I just checked the Gcode files that cura is putting out are 0 bytes. Do you have any idea why this may be happening and possibly how to fix it?
                                            @asdfasdf426 said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
                                            Hi, I'm struggling to remember if I'm honest. I'll check for old configs for the 280 as the ones in the zip are for the 200 (principle is the same). Did you save those files to the folders as per the guide?
                                            For the 280 I think you need 2 extruder files and they should be referenced in the definition file.
                                            I don't recall needing to change the offset of the two extruders as I think they FW controls it. You may be able to use Cura to tweak it though if they are slightly out.
