    Hotend heater does not show up in DWC
    Duet Web Control
    8
    22
    1.0k
    • foesiundefined
      foesi @Norder
      @norder The change to T100000 made the difference - but I have put 84000 there wich is the resistance I measured at around 18°C and that made no difference.
      And no I did NOT just copy someone else's config.g 🙂 . I just saw the line in the config.g and gave it a try 😉 . I will definetly do a PID tuning for both - because I need to do this twice a year due to the fact that the temperatures of winter and summer are quite different in Austria.
      Thank you for your effort!
      mendenmhundefined 1 Reply Last reply Reply Quote 1
      • foesiundefined
        foesi
        Another thing which is not a problem but could be done better is the value of the Z-Probe.
        I got it to work whith a trigger value of 1000 and the usual value is 964.
        Is there a way to get the normal value down to 0?
        cosmowaveundefined 2 Replies Last reply Reply Quote 0
        • cosmowaveundefined
          cosmowave @foesi
          @foesi Which type of z-probe do you use?
          config?
          Mankati FSXT+, DeltaTowerV2, E3D MS/TC
          foesiundefined 1 Reply Last reply Reply Quote 0
          • foesiundefined
            foesi @cosmowave
            @cosmowave I use the orignal Tronxy TR leveling sensor.
            https://www.tronxyonline.com/Tronxy-Black-TR-Auto-Leveling-Sensor-p1486299.html
            I run it with 12V because I have not connected it to the 5V or the 3.3V of the IO port.
            • Norderundefined
              Norder
              @droftarts said in Hotend heater does not show up in DWC:
              With the comment he meant his Z-Probe.
              Not the thermistor.
              DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
              Thingiverse
                droftarts administrators @Norder
                @norder oops! Thanks, reading on phone screen, I missed that! I’ve deleted my reply.
                  cosmowave @foesi
                  @foesi said in Hotend heater does not show up in DWC:
                  An analog sensor needs at minimum a bit offset.
                  How is the sensor configured in config.g?
                  Can you exactly describe your wiring please.
                  • jumpedwithbothfeetundefined
                    jumpedwithbothfeet @foesi
                    This post is deleted!
                    • foesiundefined
                      foesi @cosmowave
                      @cosmowave the sensor is configured like this:
                      M558 P1 C"!io3.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
                      G31 P999 X-41 Y5 Z5 ; set Z probe trigger value, offset and trigger height
                      M557 X50:550 Y50:550 S50 ; define mesh grid
                      I have connected the signal to the io3.in of the IO_3 port. The + and - are connected to the 12V port in the center of the board.
                      cosmowaveundefined 1 Reply Last reply Reply Quote 0
                        cosmowave @foesi
                        @foesi For me, the config and wiring seems ok.
                        Perhaps it helps when you insert a resistor into the signal line from probe to io3 pin to get a lower value?
                        But i'm not completely sure if this will work...
                        • mendenmhundefined
                          mendenmh @foesi
                          @foesi
                          "but I have put 84000 there which is the resistance I measured at around 18°C"
                          That's a really unlikely resistance for a 100k thermistor at 18C. It should be well above 100k, close to 150k, at that temperature. These thermistors are specified at 25C, and have a negative temperature coefficient, which means the resistance is higher at lower temperatures.
                          Is it possible you used your fingers to hold the meter leads on the thermistor, and got a reduced reading due to leakage through your skin?
                          Anyways, use the nominal 100k value in your calibration. It is probably very close to correct.
                            jay_s_uk @mendenmh
                            @mendenmh the resistance of normal thermistors goes down when the temperature increases. Thats what NTC means negative temperature coefficient, so the values go in opposite directions.
                            PT100/1000 are positive temperature, so both values go in the same direction
                            @foesi using 84000 is incorrect. the value stated in the firmware is the value the thermistor will read at 0 degrees, so 100000 is what you should be using
                            mendenmhundefined 1 Reply Last reply Reply Quote 0
                            • mendenmhundefined
                              mendenmh @jay_s_uk
                              @jay_s_uk You and I said the same thing, about the negative temperature coefficient. I said resistance is higher at lower temperatures; you corrected to lower at higher temperatures. 🙂
                              However, your statement about the value for a thermistor being specified at zero degrees is wrong. Most thermistors are standardized at 25C. Pt100/Pt1000 are, indeed, standardized at 0C. But it is still correct that the 100000 is the right number to have put in the file.
                              • jumpedwithbothfeetundefined jumpedwithbothfeet referenced this topic
