    Hotend heater does not show up in DWC
    Duet Web Control
    8
    22
    1.0k
    • Norderundefined
      Norder @foesi
      @foesi said in Hotend heater does not show up in DWC:
      M140 H1 ; map EXTRUDER HEATER to heater 1
      The M140 command is for bed heating only.
      You can remove this command for the hotend.
      Info:
      M140 (GCode Dictionary)
      DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
      Thingiverse
      foesiundefined 1 Reply Last reply Reply Quote 0
      • foesiundefined
        foesi @jumpedwithbothfeet
        @jumpedwithbothfeet No, I haven't. I put the M563 P0 D0 H1 just now into config.g and it worked!
        The other strange thing is that the extruder and bed temperatures are at -21°C. What could be the cause of that?
        Norderundefined 1 Reply Last reply Reply Quote 0
        • foesiundefined
          foesi @Norder
          @norder I saw this in another config.g and gave it a try 😉
          • jumpedwithbothfeetundefined
            jumpedwithbothfeet @Phaedrux
            @foesi as phaedrux mentioned you should post your config.g along with your config-override.g files, I have seen the -21 issue before but for the life of me I cant remember the cause, best to check your using the correct settings for you hotend/bed thermistors/heaters before using them, are they stock parts or have you changed them?
            @phaedrux said in Hotend heater does not show up in DWC:
            Post your full config.g
            • Norderundefined
              Norder @foesi
              Make a T100000 out of the T10000 in the M308 command lines, i.e. one more 0.
              P.S.:
              But you didn't copy the settings for the thermistors from someone else's config.g ? 🤔
              You should already enter the thermistors that you have installed.
              Otherwise errors could occur or, in the worst case, your printer could catch fire and then there is a risk of death !
              If everything works, you should do a PID tuning for the bed and the hot end so that the temperatures are kept stable.
              Thingiverse
              • foesiundefined
                @jumpedwithbothfeet config.g-25082022.txt config.g.bak.txt
                The thermistors and heaters are stock parts - I have only changed the controller board to the duet 3 mini 5+ because the tronxy board was not reliable and made strange things during printing - after I had it for 4 months. Then I bought the duet because the tronxy support could not figure out what the problem was and I have another duet 2 wifi for 2 1/2 years now which works reliable on my own built printer.
                jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
                • foesiundefined
                  foesi @Norder
                  @norder The change to T100000 made the difference - but I have put 84000 there wich is the resistance I measured at around 18°C and that made no difference.
                  And no I did NOT just copy someone else's config.g 🙂 . I just saw the line in the config.g and gave it a try 😉 . I will definetly do a PID tuning for both - because I need to do this twice a year due to the fact that the temperatures of winter and summer are quite different in Austria.
                  Thank you for your effort!
                  mendenmhundefined 1 Reply Last reply Reply Quote 1
                  • foesiundefined
                    foesi
                    Another thing which is not a problem but could be done better is the value of the Z-Probe.
                    I got it to work whith a trigger value of 1000 and the usual value is 964.
                    Is there a way to get the normal value down to 0?
                    cosmowaveundefined 2 Replies Last reply Reply Quote 0
                    • cosmowaveundefined
                      cosmowave @foesi
                      @foesi Which type of z-probe do you use?
                      config?
                      Mankati FSXT+, DeltaTowerV2, E3D MS/TC
                      • foesiundefined
                        foesi @cosmowave
                        @cosmowave I use the orignal Tronxy TR leveling sensor.
                        https://www.tronxyonline.com/Tronxy-Black-TR-Auto-Leveling-Sensor-p1486299.html
                        I run it with 12V because I have not connected it to the 5V or the 3.3V of the IO port.
                        • Norderundefined
                          Norder
                          @droftarts said in Hotend heater does not show up in DWC:
                          With the comment he meant his Z-Probe.
                          Not the thermistor.
                          Thingiverse
                            droftarts administrators @Norder
                            @norder oops! Thanks, reading on phone screen, I missed that! I’ve deleted my reply.
                              cosmowave @foesi
                              An analog sensor needs at minimum a bit offset.
                              How is the sensor configured in config.g?
                              Can you exactly describe your wiring please.
                                jumpedwithbothfeet @foesi
                                This post is deleted!
                                • foesiundefined
                                  foesi @cosmowave
                                  @cosmowave the sensor is configured like this:
                                  M558 P1 C"!io3.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
                                  G31 P999 X-41 Y5 Z5 ; set Z probe trigger value, offset and trigger height
                                  M557 X50:550 Y50:550 S50 ; define mesh grid
                                  I have connected the signal to the io3.in of the IO_3 port. The + and - are connected to the 12V port in the center of the board.
                                  cosmowaveundefined 1 Reply Last reply Reply Quote 0
                                    cosmowave @foesi
                                    @foesi For me, the config and wiring seems ok.
                                    Perhaps it helps when you insert a resistor into the signal line from probe to io3 pin to get a lower value?
                                    But i'm not completely sure if this will work...
                                    • mendenmhundefined
                                      mendenmh @foesi
                                      @foesi
                                      "but I have put 84000 there which is the resistance I measured at around 18°C"
                                      That's a really unlikely resistance for a 100k thermistor at 18C. It should be well above 100k, close to 150k, at that temperature. These thermistors are specified at 25C, and have a negative temperature coefficient, which means the resistance is higher at lower temperatures.
                                      Is it possible you used your fingers to hold the meter leads on the thermistor, and got a reduced reading due to leakage through your skin?
                                      Anyways, use the nominal 100k value in your calibration. It is probably very close to correct.
                                        jay_s_uk @mendenmh
                                        @mendenmh the resistance of normal thermistors goes down when the temperature increases. Thats what NTC means negative temperature coefficient, so the values go in opposite directions.
                                        PT100/1000 are positive temperature, so both values go in the same direction
                                        @foesi using 84000 is incorrect. the value stated in the firmware is the value the thermistor will read at 0 degrees, so 100000 is what you should be using
                                        mendenmhundefined 1 Reply Last reply Reply Quote 0
                                        • mendenmhundefined
                                          mendenmh @jay_s_uk
                                          @jay_s_uk You and I said the same thing, about the negative temperature coefficient. I said resistance is higher at lower temperatures; you corrected to lower at higher temperatures. 🙂
                                          However, your statement about the value for a thermistor being specified at zero degrees is wrong. Most thermistors are standardized at 25C. Pt100/Pt1000 are, indeed, standardized at 0C. But it is still correct that the 100000 is the right number to have put in the file.
                                          • jumpedwithbothfeetundefined jumpedwithbothfeet referenced this topic
