    duet 3 6hc and raspberry p3b+
    1.2k
      A Former User @A Former User
      @sgk m122
      RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-9P63L-DJ3S0-7J1F8-3S46T-TVKH9
      Used output buffers: 1 of 40 (10 max)
      Static ram: 154604
      Dynamic ram: 162760 of which 48 recycled
      Exception stack ram used: 224
      Never used ram: 75580
      Tasks: ETHERNET(blocked,844) NETWORK(ready,1972) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4952) IDLE(ready,76)
      Owned mutexes:
      Last reset 00:04:04 ago, cause: power up
      Last software reset time unknown, reason: User, spinning module LinuxInterface, available RAM 74824 bytes (slot 1)
      Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
      Error status: 0
      MCU temperature: min 24.5, current 36.0, max 36.1
      Supply voltage: min 24.0, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
      Driver 0: standstill, reads 15483, writes 14 timeouts 0, SG min/max 0/0
      Driver 1: standstill, reads 15484, writes 14 timeouts 0, SG min/max 0/0
      Driver 2: standstill, reads 15484, writes 14 timeouts 0, SG min/max 0/0
      Driver 3: standstill, reads 15485, writes 14 timeouts 0, SG min/max 0/0
      Driver 4: standstill, reads 15485, writes 14 timeouts 0, SG min/max 0/0
      Driver 5: standstill, reads 15489, writes 11 timeouts 0, SG min/max 0/0
      Date/time: 2022-08-26 18:45:34
      Slowest loop: 4.51ms; fastest: 0.14ms
      === Storage ===
      Free file entries: 10
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP* is ready with "M122" in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon* is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 1.65ms; fastest: 0.01ms
      HTTP sessions: 0 of 8
      • Ethernet -
        State: establishingLink
        Error counts: 0 0 0 0 0
        === CAN ===
        Messages sent 647, longest wait 0ms for type 0
        === Linux interface ===
        State: 0, failed transfers: 1
        Last transfer: 15ms ago
        RX/TX seq numbers: 19844/19844
        SPI underruns 4, overruns 1
        Number of disconnects: 0
        Buffer RX/TX: 0/0-0
        === Duet Control Server ===
        Duet Control Server v3.4.1
        Failed to deserialize the following properties:
      • Spindle -> Int32 from 10000.0000000
        Code buffer space: 4096
        Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 1
        Full transfers per second: 40.80, max time between full transfers: 182.3ms, max pin wait times: 30.7ms/23.8ms
        Codes per second: 0.01
        Maximum length of RX/TX data transfers: 3176/308
      A Former User? Phaedruxundefined 2 Replies Last reply Reply Quote 0
        @sgk M98 P "config.g"
        Error: M98: non-empty string expected
            Phaedrux Moderator @A Former User
            @sgk said in duet 3 6hc and raspberry p3b+:
            You've got a space between P and "
              Update your Pi and firmware with sudo apt update and sudo apt upgrade from the pi terminal.
              A Former User? 2 Replies Last reply Reply Quote 0
                A Former User @Phaedrux
                @phaedrux yes ok
                  @phaedrux hello the same nothing works neither the fans nor the motors
                    Did you re-run M98 P"config.g" ?
                    Is this a coreXY?
                    Have you seen this?
                    https://docs.duet3d.com/en/How_to_guides/Commissioning
                    A Former User? 3 Replies Last reply Reply Quote 0
                      @phaedrux i have blv yes I read but before I had a duet 2 now I installed a duet 3 and I have a lot of worries for that I ask for help I'm sorry I'm lost with it
                        @phaedrux
                        yes i launched M98 P"config.g"
                          @phaedrux
                          I have the impression that there is something wrong because when I start the fans nothing lights up and the motor lights up but it advances step by step very slowly 1 cm by a cm
                            @sgk look home
                            video.mp4
                                What version of firmware does it have now?
                                Did you update on the Pi?
                                What version of DWC does it show it has?
                                  @phaedrux Board: Duet 3 MB6HC (MB6HC)
                                  DSF Version: 3.4.1
                                  Firmware: RepRapFirmware for Duet 3 MB6HC 3.1.1 (2020-05-19b2)
                                    @phaedrux
                                    I did the update with pi but now the motors don't work very well and the fans still don't work says it all
                                      @phaedrux that's when I do home x and the same for home yvideo 2.mp4
                                        DSF Version: 3.4.1
                                        You have a mismatch. When the pi updated the duet firmware didn't get updated at the same time. Please send M997 to initiate a manual firmware update and then check again with M115.
                                          @phaedrux 27/08/2022 00:28:39 m115
                                          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.1 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2022-06-01 21:09:12
                                          27/08/2022 00:28:22 Connection established
                                          27/08/2022 00:28:22 CORS disabled
                                          27/08/2022 00:28:22 Error: M552: Network-related commands are not supported when using an attached Single Board Computer
                                          27/08/2022 00:28:16 m997
                                          27/08/2022 00:21:32 Connection established
                                            Ok, so now when you send M122 you should see matching firmware and DCS versions of 3.4.1.
                                            Now in DWC can you check the DWC version?
