    duet 3 6hc and raspberry p3b+
    1.1k
      A Former User @A Former User
      @sgk M98 P "config.g"
      Error: M98: non-empty string expected
      A Former User? Phaedruxundefined 2 Replies Last reply Reply Quote 0
          Phaedrux Moderator @A Former User
          @sgk said in duet 3 6hc and raspberry p3b+:
          You've got a space between P and "
            Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
            Update your Pi and firmware with sudo apt update and sudo apt upgrade from the pi terminal.
            A Former User? 2 Replies Last reply Reply Quote 0
              A Former User @Phaedrux
              @phaedrux yes ok
                @phaedrux hello the same nothing works neither the fans nor the motors
                  Did you re-run M98 P"config.g" ?
                  Is this a coreXY?
                  Have you seen this?
                  https://docs.duet3d.com/en/How_to_guides/Commissioning
                  A Former User? 3 Replies Last reply Reply Quote 0
                    @phaedrux i have blv yes I read but before I had a duet 2 now I installed a duet 3 and I have a lot of worries for that I ask for help I'm sorry I'm lost with it
                      @phaedrux
                      yes i launched M98 P"config.g"
                        @phaedrux
                        I have the impression that there is something wrong because when I start the fans nothing lights up and the motor lights up but it advances step by step very slowly 1 cm by a cm
                          @sgk look home
                          video.mp4
                              What version of firmware does it have now?
                              Did you update on the Pi?
                              What version of DWC does it show it has?
                                @phaedrux Board: Duet 3 MB6HC (MB6HC)
                                DSF Version: 3.4.1
                                Firmware: RepRapFirmware for Duet 3 MB6HC 3.1.1 (2020-05-19b2)
                                  @phaedrux
                                  I did the update with pi but now the motors don't work very well and the fans still don't work says it all
                                    @phaedrux that's when I do home x and the same for home yvideo 2.mp4
                                      DSF Version: 3.4.1
                                      You have a mismatch. When the pi updated the duet firmware didn't get updated at the same time. Please send M997 to initiate a manual firmware update and then check again with M115.
                                        @phaedrux 27/08/2022 00:28:39 m115
                                        FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.1 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2022-06-01 21:09:12
                                        27/08/2022 00:28:22 Connection established
                                        27/08/2022 00:28:22 CORS disabled
                                        27/08/2022 00:28:22 Error: M552: Network-related commands are not supported when using an attached Single Board Computer
                                        27/08/2022 00:28:16 m997
                                        27/08/2022 00:21:32 Connection established
                                          Ok, so now when you send M122 you should see matching firmware and DCS versions of 3.4.1.
                                          Now in DWC can you check the DWC version?
                                            it stays like that
