    Mistake True bed levelling G32
    2.1k
      A Former User @jay_s_uk
      @jay_s_uk if I change this parameter by this him the
      M558 P8 C"io2.in" A2 H5 F120 T15000
      A5
        A Former User @A Former User
        @sgk
        I found the problem because of daylight, I don't know why with duet 2 it never does it to me and with duet 3 it does it to me. but even if I put a white sheet on the pei it does it do the same error.
          jay_s_uk @A Former User
          @sgk IR probes aren't great with direct sunlight
            @jay_s_uk
            even with a white sheet. What can you advise me specifically?
              @sgk i've never got on with them when i've tried them
                @jay_s_uk and what probe do you have?
                  @sgk on my machines now I use Euclid probes https://euclidprobe.github.io/ that can be picked up when used.
                  I have in the past used BFPtouches https://www.thingiverse.com/thing:2890290
                  I'm not a fan of normal bltouches as they seem to cause too many issues for people.
                  inductive can be good but you need to be able to adjust for temperature affecting the readings
                  A Former User? 2 Replies Last reply Reply Quote 0
                    @jay_s_uk I agree with you the ones I had before I had bltouch and I also had only problems he only had the ir that it was fine but now that I am in duet 3 only problems too
                      @jay_s_uk
                      this Euclid probes looks good to me but too complicated for me already that I have trouble with an ir probe or bltouch
                        @sgk you can also look at something like the klicky or unklicky
                          @jay_s_uk
                          it's magnetized?
                            @sgk yes. klicky, unklicky and euclid all use magnets for attaching the bottom half of the probe
                              @jay_s_uk it's too good this idea I imagine that it is necessary to program the printer and what to get the probe really quite complicated this part
                                @sgk the printer uses the probe as a standard switch.
                                there are example macros required for picking up and docking the probe so its fairly simple to implement
                                  @jay_s_uk ha but that's really what you're telling me, do you have any idea by chance where we could find it's macros?
                                  jay_s_ukundefined jumpedwithbothfeetundefined 2 Replies Last reply Reply Quote 0
                                    @sgk the euclid ones are here https://euclidprobe.github.io/06_rrf3.html
                                      @jay_s_uk ok thanks
                                      • jumpedwithbothfeetundefined
                                        jumpedwithbothfeet @A Former User
                                        @sgk Here are my macro's for my Klicky probe it`s mounted on a Voron trident, but they are quite simple but will need to be adjusted to your printer but hopefully they help 🙂
                                        homeall.g
                                        ; homeall.g
                                        ; called to home all axes
                                        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Apr 06 2020 18:55:28 GMT+0100 (British Summer Time)
                                        G1 H2 Z3 F6000          ; lift Z relative to current position
                                        G1 H1 X400 Y400 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                                        G1 H1 X400 ; fast home x
                                        G1 H1 Y400 ; fast home y
                                        G1 X-5 Y-5 F600       ; go back a few mm
                                        G1 H1 X10 ; fine home x
                                        G1 H1 Y10 ; fine home y
                                        G90                     ; absolute positioning
                                        G1 Y310 F7000 ; Pick Up Klicky
                                        G1 X42 F7000 ; Pick Up Klicky
                                        G1 Y358 F7000 ; Pick Up Klicky
                                        G1 X180 Y180 F7000      ; go to first bed probe point and home Z
                                        G30                     ; home Z by probing the bed
                                        G1 Y310 F7000 ; Drop Klicky
                                        G1 X42 F7000 ; Drop Klicky
                                        G1 Y358 F7000 ; Drop Klicky
                                        G1 X89 F7000 ; Drop Klicky
                                        G1 Z3 F100             ; lift Z relative to current position
                                        homez.g
                                        ; homez.g
                                        ; called to home the Z axis
                                        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Apr 06 2020 18:55:29 GMT+0100 (British Summer Time)
                                        G1 H2 Z5 F600    ; lift Z relative to current position
                                        G1 X180 Y180 F7000 ; go to first probe point
                                        G1 Z5 F100       ; lift Z relative to current position
                                        bed.g
                                        ; bed.g
                                        ;G29  ; probe the bed and enable compensation
                                        ;G28 ; home
                                        M401 ; deploy Z probe (omit if using bltouch)
                                        G30 P0 X30 Y0 Z-99999 ; probe near a leadscrew, Front left leadscrew
                                        G30 P1 X30 Y300 Z-99999 ; probe near a leadscrew, Rear left leadscrew
                                        G30 P2 X330 Y0 Z-99999 ; probe near a leadscrew, Rear Right leadscrew
                                        G30 P3 X330 Y300 Z-99999 S4 ; probe near a leadscrew and calibrate 4 motors
                                        M402 ; retract probe (omit if using bltouch)
                                        6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
                                          A Former User @jumpedwithbothfeet
                                          @jumpedwithbothfeet
                                          great thank you guys. it's possible that you make me a picture of your model to have an idea?
                                          jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
                                            @sgk https://www.vorondesign.com/voron_trident my trident is no long standard it has 4 lead screws on the z axis even the klicky probe is not standard however the macro`s should give you an idea when you compare them to yours.
