Mistake True bed levelling G32
@jay_s_uk
it's magnetized? -
@sgk yes. klicky, unklicky and euclid all use magnets for attaching the bottom half of the probe
@jay_s_uk it's too good this idea I imagine that it is necessary to program the printer and what to get the probe really quite complicated this part
@sgk the printer uses the probe as a standard switch.
there are example macros required for picking up and docking the probe so its fairly simple to implement -
@jay_s_uk ha but that's really what you're telling me, do you have any idea by chance where we could find it's macros?
@sgk the euclid ones are here https://euclidprobe.github.io/06_rrf3.html
@jay_s_uk ok thanks
@sgk Here are my macro's for my Klicky probe it`s mounted on a Voron trident, but they are quite simple but will need to be adjusted to your printer but hopefully they help
homeall.g
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Apr 06 2020 18:55:28 GMT+0100 (British Summer Time) G91 ; relative positioning G1 H2 Z3 F6000 ; lift Z relative to current position G1 H1 X400 Y400 F3000 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H1 X400 ; fast home x G1 H1 Y400 ; fast home y G1 X-5 Y-5 F600 ; go back a few mm G1 H1 X10 ; fine home x G1 H1 Y10 ; fine home y G90 ; absolute positioning G1 Y310 F7000 ; Pick Up Klicky G1 X42 F7000 ; Pick Up Klicky G1 Y358 F7000 ; Pick Up Klicky G1 Y310 F7000 ; Pick Up Klicky G1 X180 Y180 F7000 ; go to first bed probe point and home Z G30 ; home Z by probing the bed G1 Y310 F7000 ; Drop Klicky G1 X42 F7000 ; Drop Klicky G1 Y358 F7000 ; Drop Klicky G1 X89 F7000 ; Drop Klicky ; Uncomment the following lines to lift Z after probing G91 ; relative positioning G1 Z3 F100 ; lift Z relative to current position G90 ; absolute positioning
homez.g
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Apr 06 2020 18:55:29 GMT+0100 (British Summer Time) G91 ; relative positioning G1 H2 Z5 F600 ; lift Z relative to current position G90 ; absolute positioning G1 Y310 F7000 ; Pick Up Klicky G1 X42 F7000 ; Pick Up Klicky G1 Y358 F7000 ; Pick Up Klicky G1 Y310 F7000 ; Pick Up Klicky G1 X180 Y180 F7000 ; go to first probe point G30 ; home Z by probing the bed G1 Y310 F7000 ; Drop Klicky G1 X42 F7000 ; Drop Klicky G1 Y358 F7000 ; Drop Klicky G1 X89 F7000 ; Drop Klicky ; Uncomment the following lines to lift Z after probing G91 ; relative positioning G1 Z5 F100 ; lift Z relative to current position G90 ; absolute positioning
bed.g
; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Apr 06 2020 18:55:28 GMT+0100 (British Summer Time) M561 ; clear any bed transform ;G29 ; probe the bed and enable compensation ;G28 ; home G1 Y310 F7000 ; Pick Up Klicky G1 X42 F7000 ; Pick Up Klicky G1 Y358 F7000 ; Pick Up Klicky G1 Y310 F7000 ; Pick Up Klicky M401 ; deploy Z probe (omit if using bltouch) G30 P0 X30 Y0 Z-99999 ; probe near a leadscrew, Front left leadscrew G30 P1 X30 Y300 Z-99999 ; probe near a leadscrew, Rear left leadscrew G30 P2 X330 Y0 Z-99999 ; probe near a leadscrew, Rear Right leadscrew G30 P3 X330 Y300 Z-99999 S4 ; probe near a leadscrew and calibrate 4 motors M402 ; retract probe (omit if using bltouch) G1 Y310 F7000 ; Drop Klicky G1 X42 F7000 ; Drop Klicky G1 Y358 F7000 ; Drop Klicky G1 X89 F7000 ; Drop Klicky
@jumpedwithbothfeet
great thank you guys. it's possible that you make me a picture of your model to have an idea? -
@sgk https://www.vorondesign.com/voron_trident my trident is no long standard it has 4 lead screws on the z axis even the klicky probe is not standard however the macro`s should give you an idea when you compare them to yours.
@jumpedwithbothfeet
OK great I see every time you feel the bed she will look for the probe that's it? -
@sgk
the guy i ordered the probe more than receive it and install -
@sgk
@sgk the hot end assy moves to the klicky mount you can see on the rear left of the picture, it then picks up the klicky using the magnets, probes each part of the bed requested then goes back to the klicky mount and removes the probe, it is based on the Euclid probe and has worked flawlessly for me.
I have to make a support in 3d right?
@sgk if your using the Klicky probe then yes just print the files supplied and assemble, I cant comment on the Euclid probe as I donβt know what is supplied.
https://github.com/jlas1/Klicky-Probe Link for Klicky files
@jumpedwithbothfeet thanks
