Euclid facility
91
4.7k
    A Former User @dc42
    OK i understand thank you πŸ˜€πŸ‘
    undefined undefined 2 Replies Last reply 13 Sept 2022, 05:03 Reply Quote 0
      jumpedwithbothfeet @A Former User
      @sgk can you post your Homeall.g, homez.g, deployprobe.g, retractprobe.g, and bed.g put these in quotes (thats the little </> button above the reply box) I suspect your using a mish mash of different configurations which is causing the issue as @DC42 is alluding too.
      6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
      ? 1 Reply Last reply 13 Sept 2022, 18:12 Reply Quote 0
        A Former User @jumpedwithbothfeet
        @jumpedwithbothfeet
        hello it's true that I'm a little lost. thank you all for your patience and your help.
        retractprobe.g homez.g homeall.g deployprobe.g config.g bed.g
        undefined undefined 2 Replies Last reply 13 Sept 2022, 19:40 Reply Quote 0
          sinned6915 @A Former User
          @sgk all of this is pretty well addressed in the Euclid docs.
          https://euclidprobe.github.io/06_macros_overview.html
          there are annotated picures and macro files.
          if you need more help, the euclid discord might be faster, i dont come here often.
          and just so you know, Euclid does not like it when you call it klicky πŸ˜‰
            Nurgelrot @A Former User
            This post is deleted!
              @sgk in bed.g comment out M401 and M402 just like below and try it again πŸ™‚
              ; bed.g
              ; generated by Ben Levi - BLV developer as a basic version
              G91 ; relative positioning
              G90 ; absolute positioning
              G28 ; home all
              ;G30 P0 X10 Y175 Z-99999 ; probe near a leadscrew, half way along Y axis
              ;G30 P1 X330 Y175 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
              G29 S0 ; probe the bed and enable compensation
              M291 P"Leveling finished !" R"Probing.." S1 T2
              G1 Y8.5 F6000 ; Pick Up Klicky
              G1 X20 F2000 ;
              G1 X0 F1000 ; Pick Up Klicky
              G1 Y30 F1000 ;
              G1 Y50 F6000 ; Pick Up Klicky
              ;M401 ; deploy Z probe (omit if using bltouch)
              ;M402 ; retract probe (omit if using bltouch)
              G1 Y250 F6000 ; Drop Klicky
              G1 X0 F6000 ; Drop Klicky
              G1 Y8.5 F6000 ; Drop Klicky
              G1 X170 F6000 ; Drop Klicky
              G1 Y170 F6000 ;
              ? 1 Reply Last reply 14 Sept 2022, 05:09 Reply Quote 0
                @jumpedwithbothfeet Ha OK I will modify and I will let you know thank youπŸ˜€πŸ‘
                undefined 1 Reply Last reply 14 Sept 2022, 05:31 Reply Quote 0
                  @sgk I have just realised you should also move the M291 to the bottom of the file and also comment G29 S0 out, just like this -
                  ; bed.g
                  G28 ; home all
                  ;G29 S0 ; probe the bed and enable compensation
                  ;M291 P"Leveling started!" R"Probing.." S1 T2
                  G1 X20 F2000 ;
                  G1 Y30 F1000 ;
                  G1 Y170 F6000 ;
                  ? 2 Replies Last reply 14 Sept 2022, 10:06 Reply Quote 0
                    @jumpedwithbothfeet yes OK πŸ‘πŸ˜€thank you
                      @jumpedwithbothfeet The m 401 and m 402 I have to leave like this with [;]Screenshot_20220914_123858.jpg
                      undefined 1 Reply Last reply 14 Sept 2022, 11:05 Reply Quote 0
                        @sgk yes that’s the quickest way to get you up and running, but it’s not the conventional way, it all depends on how you what to use your Euclid probe, I think most people would use M401 and M402 in which case you would need to remove the G1 codes from bed.g, homeall.g, and homez.g, see how you get on, the best thing about rrf is it’s flexible, there are multiple ways of achieving the same thing. 😁
                        ? 2 Replies Last reply 14 Sept 2022, 12:03 Reply Quote 0
                          @jumpedwithbothfeet I will already change and see how it works.πŸ˜€πŸ‘
                            @jumpedwithbothfeet
                            hello I changed but it's the same nothing to change when I do home and after g29 or g32 it doesn't probing the bed.😒
                            undefined 1 Reply Last reply 15 Sept 2022, 04:44 Reply Quote 0
                              @sgk in homez.g remove or comment out -
                              G1 X152 Y166.4 F6000 ; go to first probe point
                              in homeall.g remove or comment out -
                              G1 X170 Y180 F6000 ; go to first probe point X11.5 Y65.8 Z0 The coordinate put the Z sensor in the center of the bed.
                              G30 ; Probe
                              repost both files once you have changed them πŸ™‚
                              ? 1 Reply Last reply 15 Sept 2022, 06:57 Reply Quote 0
                                @jumpedwithbothfeet I will change and seeπŸ‘
                                ? 1 Reply Last reply 15 Sept 2022, 16:22 Reply Quote 0
                                  A Former User @A Former User
                                  I changed but when I run g32 or g29 it doesn't work
                                  undefined 1 Reply Last reply 16 Sept 2022, 04:35 Reply Quote 0
                                    @sgk ok back to the beginning, when you home all axis, the printer does this? the euclid probe is detected and you can move all axes of the printer independently?
                                    ? 1 Reply Last reply 16 Sept 2022, 10:03 Reply Quote 0
                                      @sgk this thread is getting long and I have lost track of what the current problem is. Can you state it again?
                                      To clarify how we intend a deployable probe such as the Euclid to be used:
                                      • Put the GCode movement commands needed to deploy or pick up the probe in file sys/deployprobe.g on the SD card, and nowhere else
                                      • Put the GCode movement commands needed to retract or stow the probe in file sys/retractprobe.g on the SD card, and nowhere else
                                      • Then if you run M401 it should pick up the probe. If you run M401 again then it will not repeat the pickup moves, but it will increment an internal counter
                                      • If you run M402 it will stow the probe, unless the internal counter indicates that M401 was run more than once without an intervening M402; in which case it just decrements the counter
                                      • When you have that working, if you command the nozzle to a XY position over the bed and execute G30, it should pick up the probe, return to the original position, probe the bed, and stow the probe
                                      • Running G29 S0 should pick up the probe, run mesh probing (assuming you have used M557 to define the grid), and stow the probe
                                      • The only time you need to use M401 and M402 explicitly is in a bed.g file that contains multiple G30 commands. If you don't use M401 then it will pick up and stow the probe for every probe point. If you use M401 before the first G30 command then it will pick up the probe once at the start and stow it once at the end.
                                      • Never invoke deployprobe.g or retractprobe.g directly. That would pick up or stow the probe without adjusting the internal counter, which RRF uses to keep track of whether the probe is deployed or stowed.
                                      HTH David
                                      ? 1 Reply Last reply 16 Sept 2022, 09:54 Reply Quote 0
                                        A Former User @dc42
                                        @dc42 to put it simply since I installed the euclid probe when I run the g32 or g29 command nothing happens, that is to say the probe does not palpate the bed.
                                        I followed the euclid probe instructions. Deploy and retract config.g homeall home z. I'll make another video to see better.
                                          @jumpedwithbothfeet When I go home all she goes to get the probe and pats the center of the bed.
                                          Yes I can move all my axes.
                                          undefined 1 Reply Last reply 16 Sept 2022, 10:07 Reply Quote 0
                                          59 out of 91
