    Euclid facility
    91
    4.7k
    • jumpedwithbothfeetundefined
      jumpedwithbothfeet @A Former User
      @sgk I have just realised you should also move the M291 to the bottom of the file and also comment G29 S0 out, just like this -
      ; bed.g
      ; generated by Ben Levi - BLV developer as a basic version
      M561 												; clear any bed transform
      G91               									; relative positioning
      G1 H2 Z5 F6000   									; lift Z relative to current position
      G90              									; absolute positioning
      G28 												; home all
      ;G30 P0 X10 Y175 Z-99999 							; probe near a leadscrew, half way along Y axis
      ;G30 P1 X330 Y175 Z-99999 S2 						; probe near a leadscrew and calibrate 2 motors
      ;G29 S0                                              ; probe the bed and enable compensation
      ;M291 P"Leveling started!" R"Probing.." S1 T2
      G1 Y8.5 F6000 ; Pick Up Klicky
      G1 X20 F2000 ;
      G1 X0 F1000 ; Pick Up Klicky
      G1 Y30 F1000 ;
      G1 Y50 F6000 ; Pick Up Klicky
      ;M401 ; deploy Z probe (omit if using bltouch)
      ;M402 ; retract probe (omit if using bltouch)
      G1 Y250 F6000 ; Drop Klicky
      G1 X0 F6000 ; Drop Klicky
      G1 Y8.5 F6000 ; Drop Klicky
      G1 X170 F6000 ; Drop Klicky
      G1 Y170 F6000 ;
      M291 P"Leveling finished !" R"Probing.." S1 T2
      6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
      A Former User? 2 Replies Last reply Reply Quote 0
        A Former User @jumpedwithbothfeet
        @jumpedwithbothfeet yes OK πŸ‘πŸ˜€thank you
          @jumpedwithbothfeet The m 401 and m 402 I have to leave like this with [;]Screenshot_20220914_123858.jpg
          jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
            @sgk yes that’s the quickest way to get you up and running, but it’s not the conventional way, it all depends on how you what to use your Euclid probe, I think most people would use M401 and M402 in which case you would need to remove the G1 codes from bed.g, homeall.g, and homez.g, see how you get on, the best thing about rrf is it’s flexible, there are multiple ways of achieving the same thing. 😁
              @jumpedwithbothfeet I will already change and see how it works.πŸ˜€πŸ‘
                @jumpedwithbothfeet
                hello I changed but it's the same nothing to change when I do home and after g29 or g32 it doesn't probing the bed.😒
                  @sgk in homez.g remove or comment out -
                  G1 X152 Y166.4 F6000 ; go to first probe point
                  G30                 ; home Z by probing the bed
                  in homeall.g remove or comment out -
                  G1 X170 Y180 F6000	    ; go to first probe point X11.5 Y65.8 Z0 The coordinate put the Z sensor in the center of the bed.
                  G30 					; Probe
                  repost both files once you have changed them πŸ™‚
                    @jumpedwithbothfeet I will change and seeπŸ‘
                      A Former User @A Former User
                      I changed but when I run g32 or g29 it doesn't work
                        @sgk ok back to the beginning, when you home all axis, the printer does this? the euclid probe is detected and you can move all axes of the printer independently?
                          @sgk this thread is getting long and I have lost track of what the current problem is. Can you state it again?
                          To clarify how we intend a deployable probe such as the Euclid to be used:
                          • Put the GCode movement commands needed to deploy or pick up the probe in file sys/deployprobe.g on the SD card, and nowhere else
                          • Put the GCode movement commands needed to retract or stow the probe in file sys/retractprobe.g on the SD card, and nowhere else
                          • Then if you run M401 it should pick up the probe. If you run M401 again then it will not repeat the pickup moves, but it will increment an internal counter
                          • If you run M402 it will stow the probe, unless the internal counter indicates that M401 was run more than once without an intervening M402; in which case it just decrements the counter
                          • When you have that working, if you command the nozzle to a XY position over the bed and execute G30, it should pick up the probe, return to the original position, probe the bed, and stow the probe
                          • Running G29 S0 should pick up the probe, run mesh probing (assuming you have used M557 to define the grid), and stow the probe
                          • The only time you need to use M401 and M402 explicitly is in a bed.g file that contains multiple G30 commands. If you don't use M401 then it will pick up and stow the probe for every probe point. If you use M401 before the first G30 command then it will pick up the probe once at the start and stow it once at the end.
                          • Never invoke deployprobe.g or retractprobe.g directly. That would pick up or stow the probe without adjusting the internal counter, which RRF uses to keep track of whether the probe is deployed or stowed.
                          HTH David
                            A Former User @dc42
                            @dc42 to put it simply since I installed the euclid probe when I run the g32 or g29 command nothing happens, that is to say the probe does not palpate the bed.
                            I followed the euclid probe instructions. Deploy and retract config.g homeall home z. I'll make another video to see better.
                              @jumpedwithbothfeet When I go home all she goes to get the probe and pats the center of the bed.
                              Yes I can move all my axes.
                                jay_s_uk @A Former User
                                @sgk lets start a fresh shall we? please post the contents of the following files.
                                • config.g
                                • homez.g
                                • homeall.g
                                • deployprobe.g
                                • retractprobe.g
                                • bed.g
                                  A Former User @jay_s_uk
                                  retractprobe.g homez.g homeall.g deployprobe.g config.g bed.g
                                  πŸ‘
                                  want the files in raw or it goes in ZIP
                                    A Former User
                                    My bed 350x350x350 and prob euclid X0 y8. 5 IMG_20220916_191317_edit_18382711277923.jpg
                                      M558 K0 P5 C"^io2.in" H8 F300 60 T9000 A3 S0.01
                                      G31 K0 P500 X-27.955 Y-18.716 Z1.033
                                      If you include K0, you need to use K0 everywhere else the probe is called. You only have a single probe, so remove K0 from your config where you have it.
                                      In your bed.g and home all you have a bunch of moves to pick the probe but then you also call the probe deploy. Your pickup moves should just be in the deploy macro.
                                      G1 X20 F2000 ;
                                      G1 Y30 F1000 ;
                                        A Former User @Phaedrux
                                        @phaedrux ok thank you I have to change the probe control in the bed m558 and g31?
                                          A Former User? Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                            https://youtu.be/9wJ2RCimWXU
                                            it gives me that
