    PanelDue 5i White Screen
    PanelDue
    1.2k
      Take a look at this post on using Bossa on a Mac
      https://forum.duet3d.com/topic/11445/flashing-firmware-on-mac-os-x
        dc42 administrators @conradhoshall
        @conradhoshall have you tried pressing the PanelDue Erase button followed by the Reset button?
        conradhoshallundefined 1 Reply Last reply Reply Quote 0
        • conradhoshallundefined
          conradhoshall @conradhoshall
          @conradhoshall Oooh, nice, I'll check this out.
            conradhoshall @dc42
            @dc42 Ok, I've tried erase, reset multiple times. No change. Terminal still won't recognize the paneldue. I did follow Phaedrux' link and got everything prepped but until the PanelDue is recognized it's kind of mute.
              Were you able to get bossa working? Does the PanelDue show there?
                conradhoshall @Phaedrux
                @phaedrux I've never gotten the GUI version of BOSSA working. Is there a difference in how it works vs command line?
                  No but it does give a GUI to see some more info.
                  Do you have a raspberry pi to check with perhaps?
                    @phaedrux I'm going to try borrowing my dad's windows computer.
                      Phaedrux Moderator @conradhoshall
                      @conradhoshall If there is still nothing showing up after doing an erase/reset while connected to USB than we'd have a better idea if the paneldue is failing or not.
                        @phaedrux I got on a windows computer, got BOSSA downloaded. The GUI is working fine. Unfortunately, the Bossa port is not visible in device manager and the PanelDue is not visible in the BOSSA GUI. I've tried all the USB ports. The PanelDue lights up while plugged in but will do nothing else. I've done an erase and reset while plugged into USB and there is no reaction whatsoever; the PanelDue continues to show white screen and doesn't even flinch during erase and reset.
                          Thanks for patiently testing. When and where did you purchase the PanelDue?
                            @phaedrux I purchased it from Filastruder about 2 months ago.
                              Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                                @phaedrux Ok, I'll email them. Thanks
                                elmoretundefined 1 Reply Last reply Reply Quote 1
                                • elmoretundefined
                                  elmoret @conradhoshall
                                  Closing the loop on this:
                                  I have checked the return, and here’s what I’ve found:
                                  1.) Upon initial power up, a white screen and no firmware loaded
                                  2.) I then flashed the firmware, as was requested on the forum
                                  3.) The Paneldue 5i now works normally, I tested it with both 4 pin and 10 pin connections, photos attached.
                                  conradhoshallundefined 1 Reply Last reply Reply Quote 1
                                    conradhoshall @elmoret
                                    @elmoret Thanks for your help on this. I recently purchased a high quality micro USB cable to make sure that that wasn't the issue. It turns out that it was. I think my old cable was damaged and that's why I wasn't able to connecct.
                                    I really appreciate this team's patience.
                                    • Phaedruxundefined Phaedrux has marked this topic as solved
