    Passage de 3.1 au dernier soucis
    My Duet controlled machine
    guenteur@hotmail.com
    718
    • HighFrequndefined
      HighFreq @alankilian
      @alankilian,
      Scusa fammi capire devo tradurre io quello che scrive lui perchè lui non ha voglia di tradurlo per postare su un forum dove tutti parlano in inglese?
      E' anche una questione di rispetto.
      Se ognuno di noi che veniamo da 20 nazioni diverse scrive nel thread nella propria lingua immagina il casino che viene fuori.
      Ma se a te va bene così, non c'è problema, io mi limito a saltare i post non scritti in inglese.
      alankilianundefined 1 Reply Last reply Reply Quote -2
      • alankilianundefined
        alankilian @HighFreq
        @highfreq You just received a HUGE amount of help diagnosing an issue you were having and the author of the firmware created several test versions to help nail down your issue.
        It helped the firmware author fix a bug and it hopefully helps you get your system running.
        If you want to skip the issues of others because you don't want to translate, that's fine.
        However, in the spirit of community, I hope others don't skip your problems as well because of your attitude.
        HighFrequndefined 1 Reply Last reply Reply Quote 2
          Phaedrux Moderator @HighFreq
          @highfreq said in Passage de 3.1 au dernier soucis:
          @thomas25 The entire forum writes in english, could show some respect to all users that do not speak your language and write in english like everybody else if you really want some help. French grandeur i guess.
          We aim to help all users here regardless of language barriers.
          HighFrequndefined 1 Reply Last reply Reply Quote 0
          • HighFrequndefined
            @alankilian if in the thread were i received all that help (i tried to do my best to help too) i would have written in my own language people would never find it using search in case they have a similar problem.
            If you are ok with it, i am not, just different point o view.
            To solve my problem weren't issued several versions, i was asked to carry out some tests wich i did and developer nailed the prob on first attempt.
            • HighFrequndefined
              HighFreq @Phaedrux
              @phaedrux to help a lazy one that doesn’t use google to translate you hide the content for all the others when using search function.
              Phaedruxundefined A Former User? 2 Replies Last reply Reply Quote -2
                Please leave this thread.
                HighFrequndefined 1 Reply Last reply Reply Quote 1
                • Thomas25undefined
                  Thomas25 @alankilian
                  @alankilian bonjour, J ai une duet wifi 1.02, J avais mis le firmware 3.01 rc11. La carte pilote mon imprimante hypercube ngen, une core xy. Avant d avoir essayé de passé la dernière version de rff J arrivais à imprimer. Depuis elle de référence plus et le wifi ne fonctionne plus.
                  Falcounetundefined 1 Reply Last reply Reply Quote 1
                  • Falcounetundefined
                    Falcounet @Thomas25
                    @thomas25 There is some changes on the gcode configuration commands from RRF 3.0 to the current one.
                    I believe it may be faster to use the configurator to generate a new updated config
                    Note that you may also need to update the WiFi firmware (DuetWiFiServer.bin file) and to update DWC at the same version number of the board firmware.
                    Thomas25undefined 1 Reply Last reply Reply Quote 1
                    • HighFrequndefined
                      HighFreq @Phaedrux
                      @phaedrux As you wish Mr. Mod
                      • Thomas25undefined
                        Thomas25 @Falcounet
                        @falcounet merci beaucoup pour votre aide.
                          A Former User @HighFreq
                          This post is deleted!
                            alankilian @Thomas25
                            @thomas25 Yes, as @Falcounet says, you should go through the RRF configurator and generate files you can upload to the board to get it working again.
                            BUT, since you do not have WiFi working, you will have to try some extra steps.
                            You should use the instructions listed HERE under "Fallback #1".
                            It's a lot of steps, and is complicated, so try them one at a time, and let us know where you get stuck, or if you have success!
