    Syringes printer, adjust different offset
    Firmware installation
    1.2k
    • FJ3Dundefined
      FJ3D @jay_s_uk
      @jay_s_uk said in Syringes printer, adjust different offset:
      @fj3d you set the Z offset of each tool in G10 for each tool in config.g
      You mean here right?
      M563 P0 S"T0" D0         ; Define tool 0
      [[[In this:]]]  G10 P0 X0 Y0 Z20 	; Reset tool 0 axis offsets
      G10 P0 R0 S0
      I have Z20 on but it doesn't do anything different when it starts printing...
        jay_s_uk @FJ3D
        @fj3d said in Syringes printer, adjust different offset:
        [[[In this:]]]
        yes, thats where you set the offset, although I don't know what that bit is that you highlighted.
        this is also from the changelog of 3.4.0
        After changing tool, RRF no longer moves the new tool head to the coordinates at which the old tool head as at when the Tn command was actioned. In most situations this should not matter, because GCode enerators usually generate commands to move to the correct XYZ position after generating a Tn command. Usually, they restore XY before Z. However, Cura does it the other way round, which risks dragging the tool head across the print. Therefore when using Cura, or in any other situations in which you want to restore the old ehaviour, we suggest you add command G1 R2 X0 Y0 Z2 Fxxx followed by G1 R2 Z0 Fxxx to the end of your post#.g files, if you don't already use those or similar commands
        FJ3Dundefined 1 Reply Last reply Reply Quote 0
        • FJ3Dundefined
          FJ3D @jay_s_uk
          @jay_s_uk sorry, the "[[[in this]]]" was just to highlight it for you to see.
          I use RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later + DueX5
          should i update? do i have to install everything again?
            jay_s_uk @FJ3D
            @fj3d i would update.
            check the changelog to see if any changes affect you. there may be, its been a while since i ran 3.2.2
            FJ3Dundefined 2 Replies Last reply Reply Quote 0
            • FJ3Dundefined
              FJ3D @jay_s_uk
              @jay_s_uk I have updated to 3.4.4, but it still ignores the Z parameter. Put 5, 20 or 40 it always stays at the same height
              :::::::EDIT::::
              Fixed, I had repeated the command at the end of config.g
              • FJ3Dundefined
                FJ3D @jay_s_uk
                @jay_s_uk
                Hello.
                I was wondering how to assign an endstop to act as a leveler for each tool.
                I have a tool with syringes, which have to be changed often and the sizes are different, sometimes shorter and sometimes longer. As initial configuration, I have assigned offset for each tool with EXAMPLE
                G10 P0 X-9 Y39 Z-17.5
                Well, if now I want to change the needle in that tool and calculate the z offset so that I know and save that value? Is there any way to do it, creating a macro or similar?
                HebigTundefined 1 Reply Last reply Reply Quote 1
                • HebigTundefined
                  HebigT @FJ3D
                  @fj3d
                  Yes, you can create a macro to do it. Here is a potential procedure, and probably not the only, or best way to do it.
                  This is mostly from memory so it will need tweaking.
                  Also be sure to update to the latest stable firmware version first, if possible. In the gcode examples below, i'm assuming at least RRF v3.0
                  1. Mount a switch somewhere on the build plate where every tool can reach.
                  2. Define an additional Z-endstop in the console. Add this line to the beginning of your macro, later on, as well.
                    (e.g. M574 Z0 P"pin_name" S1)
                  • Before proceeding, you need to measure the height at which your z-offset probing switch actuates (e.g. "z_switch_actuation_height")
                  • Pickup any tool with a syringe tip and clear the existing Z-offset
                  • move the tip above the switch
                  Tx ; Pick up a tool with syringe tip
                  G10 Px Z0 ; clear z-offset for active tool
                  G1 Xx Yx ; move syringe tip over z-offset switch
                  • manually jog the bed upward until the switch actuates (use M119 in the console to determine the endstop state and note at which height it changes. Always use M114 in the console to check axes positions, the positions in the DWC dashboard are rounded numbers)
                  • write down the current z-position (for instance 40mm)
                  • move off the switch and manually jog the buildplate up to the syringe tip (use a sheet of paper, if needed, to feel when the tip is close to touching the build plate).
                  • write down the current z-position (for instance, 25mm)
                  • Initiate a global variable for the actuation height. This will always be the same unless you change something about your z-switch mount.
                  global z_switch_actuation_height = 40 - 25 ; minus the thickness of the sheet of paper, too , if needed
                  • Put this global variable at the end of your config.g
                  The Automatic offset macro:
                  1. Write some gcode to pick up a tool (with newly installed syringe tip), move the syringe tip over the switch and probe the switch
                  Tx ; pick up a tool
                  G1 Z10 ; Move the bed down (probably taken care of by your tpostx.g macros already, just need to more the bed to a safe position to prevent crashes)
                  G10 Px Z0 ; clear the previous Z-offset for the active tool
                  G1 Xx Yx ; move over the switch
                  G91 ; set to relative positioning
                  G1 Z-10 H4 ; Syringe tip probes the switch and stops when the switch actuates (that's what the H4 does)
                  G90 ; set to absolute positioning
                  Query the object model for the current position of the Z-axis and initiate a variable. An if statement checks if the variable already exists, and will overwrite it if so, or initiate it if not. This is useful if you are running the macro multiple times; otherwise RRF will give you an error that a variable already exists.
                  if exists (var.current_z_pos)
                      set var.current_z_pos = move.axes[2].machinePosition
                  else
                      var current_z_pos = move.axes[2].machinePosition
                  1. Take the measured z-position and subtract your pre-determined z-switch 'actuation height'
                  var Tx_z_offset = var.current_z_pos - global.z_switch_actuation_height
                  1. The difference calculated in step 4 should be your new z-offset for the active tool. Add this to the active tool's G10 command, ENSURE IS IT NEGATIVE, and save with M500 to the config-override.g
                  G10 Px Z{var.Tx_z_offset} ; set new z-offset
                  M500 ; save the offset (will appear in config-override.g)
                  T-x ; return the tool to the dock
                  FJ3Dundefined 2 Replies Last reply Reply Quote 3
                  • FJ3Dundefined
                    FJ3D @HebigT
                    @hebigt
                    Wow!! It is brilliant, i'll try next week.
                    • FJ3Dundefined
                      FJ3D @HebigT
                      @hebigt said in Syringes printer, adjust different offset:
                      {1}
                      Hello.
                      I have been this afternoon testing and understanding a little the operation.
                      I have followed all the steps, the macro works but when it reaches the limit switch and activates it, this message appears:
                      M98 P"0:/macros/Prueba Z TOOL CALIBRACION"
                      Error: Bad command: {1}
                      Error: in file macro line 16 column 37: meta command: unknown variable 'current_z_pos'
                      My Macro:
                      T0 ; pick up a tool
                      G1 Z30 ; Move the bed down (probably taken care of by your tpostx.g macros already, just need to more the bed to a safe position to prevent crashes)
                      G10 P0 Z0 ; clear the previous Z-offset for the active tool
                      G1 X-12.5 ; move X over the switch
                      G1 Y-2 ; move X over the switch
                      {1}
                      else
                      var T0_z_altura = var.current_z_pos - global.z_switch_actuation_height
                      I have added at the end of my config.g the following:
                      global z_switch_actuation_height = 38 - 19 ; minus the thickness of the sheet of paper, too , if needed
                      And in the config.g:
                      ;OFFSET TOOLS
                      G10 P0 X-9 Y39 Z-18.5				; T0
                      ;PARA OFFSET HERRAMIENTA
                      G10 P0 Z{var.T0_z_altura} ; set new z-offset
                      T-1 ; return the tool to the dock
                      HebigTundefined 1 Reply Last reply Reply Quote 0
                      • HebigTundefined
                        HebigT @FJ3D
                        @fj3d If you haven't already, you can safely delete the {1} from your macro.
                        I don't know why it showed up in the formatting for my last message but it popped in there.
                        Phaedruxundefined FJ3Dundefined 2 Replies Last reply Reply Quote 0
                          Phaedrux Moderator @HebigT
                          @hebigt I think that's the forum software adding the {1}
                          I haven't seen that happen in a while.
                          • FJ3Dundefined
                            FJ3D @HebigT
                            @hebigt
                            The error must be something else, I keep getting the same error:
                            I am reviewing the macro, and it may be that what I highlight is the error? it seems that the var.current_z_pos is in parentheses and makes it a comment, I think that's the error!
                              jay_s_uk @FJ3D
                              @fj3d you're missing a dot after var on line 14
                              • FJ3Dundefined
                                FJ3D @jay_s_uk
                                @jay_s_uk
                                It is true!! changing that now these appear:
                                Error: Bad command: var.current_z_pos = move.axes[2].machinePosition
                                Error: in file macro line 15 column 37: meta command: unknown variable 'current_z_pos'
                                CODE
                                T0 ; pick up a tool
                                else
                                  jay_s_uk @FJ3D
                                  @fj3d actually, it was right the first time without the dot as thats setting the variable up, so i was wrong on that one.
                                  Just thinking about it, you don't need to run an exists on a variable in a macro as you're only using it in that macro.
                                  The one that may be causing you the issue is the global. does that one exist?
                                  best to change your macro to
                                  var current_z_pos = 0
                                  T0 ; pick up a tool
                                  I suppose the next question is what are you going to do with the variable T0_z_altura as after the macro finishes its gone
                                  • FJ3Dundefined
                                    FJ3D @jay_s_uk
                                    @jay_s_uk
                                    With this code I no longer get an error.
                                    • Picks up the tool, positions itself at the endstop
                                    • Activates it and here the maro is over, it does nothing else
                                    Inside config I have the following:
                                    ;OFFSET TOOLS
                                      jay_s_uk
                                      @fj3d you can't reference a variable like that as its only present during the macro its ran so you'd have to make it a global instead.
                                      and what do you mean you have that inside config.g? and changes to a G10 tool offset won't get saved in config.g unless M500 P10 is used
                                      • FJ3Dundefined
                                        FJ3D @jay_s_uk
                                        @jay_s_uk
                                        Ok, I misunderstood the explanation @HebigT
                                        What I have inside config.g goes inside the macro, of course, it's logical now thought. Sorry but I don't understand programming of this type...
                                        I have executed the macro and it seems that now it does everything.
                                        • Activate endstop and return execute T-1
                                        Now my question is, am I supposed to save myself with M500 the value in config-override.g right?
                                        But I go in and this is what I see and I have:
                                        ; config-override.g file generated in response to M500 at 2022-09-28 10:15
                                        ; Heater model parameters
                                        M307 H4 R2.430 K0.560:0.000 D5.50 E1.35 S1.00 B0 V0.0
                                        ; Workplace coordinates
                                        G10 L2 P1 X0.00 Y0.00 Z0.00 C0.00
                                        G10 L2 P2 X0.00 Y0.00 Z0.00 C0.00
                                        G10 L2 P3 X0.00 Y0.00 Z0.00 C0.00
                                        G10 L2 P4 X0.00 Y0.00 Z0.00 C0.00
                                        G10 L2 P5 X0.00 Y0.00 Z0.00 C0.00
                                        G10 L2 P6 X0.00 Y0.00 Z0.00 C0.00
                                        G10 L2 P7 X0.00 Y0.00 Z0.00 C0.00
                                        G10 L2 P8 X0.00 Y0.00 Z0.00 C0.00
                                        G10 L2 P9 X0.00 Y0.00 Z0.00 C0.00
                                        My macro looks like this:
                                        T0 ; pick up a tool
                                        ** Ingnore {1}, is added in the forum...**
                                          jay_s_uk @FJ3D
                                          @fj3d you need to use M500 P10 not M500
                                          • FJ3Dundefined
                                            FJ3D @jay_s_uk
                                            @jay_s_uk
                                            Yes!!!! I already see added in config-override.g!!!
                                            With this it would be enough if I configure it for each tool, right? In other words, if I change the needle right now by executing this macro, my tool would already be calibrated, right?
                                            ; config-override.g file generated in response to M500 at 2022-09-28 10:28
                                            ; Probed tool offsets
                                            G10 P0 X-9.00 Y39.00 Z21.10 C0.00 0.00 0.00 0.00 0.00 0.00 0.00
                                            G10 P1 X-9.00 Y39.00 Z-18.50 C0.00 0.00 0.00 0.00 0.00 0.00 0.00
                                            G10 P2 X-9.00 Y39.00 Z-18.50 C0.00 0.00 0.00 0.00 0.00 0.00 0.00
                                            G10 P3 X-9.00 Y39.00 Z-10.00 C0.00 0.00 0.00 0.00 0.00 0.00 0.00
