    Syringes printer, adjust different offset
    Firmware installation
    1.3k
    • HebigTundefined
      HebigT @FJ3D
      @fj3d If you haven't already, you can safely delete the {1} from your macro.
      I don't know why it showed up in the formatting for my last message but it popped in there.
      Phaedruxundefined FJ3Dundefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @HebigT
        @hebigt I think that's the forum software adding the {1}
        I haven't seen that happen in a while.
        • FJ3Dundefined
          FJ3D @HebigT
          @hebigt
          The error must be something else, I keep getting the same error:
          I am reviewing the macro, and it may be that what I highlight is the error? it seems that the var.current_z_pos is in parentheses and makes it a comment, I think that's the error!
            jay_s_uk @FJ3D
            @fj3d you're missing a dot after var on line 14
            FJ3Dundefined 1 Reply Last reply Reply Quote 0
            • FJ3Dundefined
              FJ3D @jay_s_uk
              @jay_s_uk
              It is true!! changing that now these appear:
              Error: Bad command: var.current_z_pos = move.axes[2].machinePosition
              Error: in file macro line 15 column 37: meta command: unknown variable 'current_z_pos'
              CODE
              T0 ; pick up a tool
              G1 Z30 ; Move the bed down (probably taken care of by your tpostx.g macros already, just need to more the bed to a safe position to prevent crashes)
              G10 P0 Z0 ; clear the previous Z-offset for the active tool
              G1 X-12.5 ; move X over the switch
              G1 Y-2 ; move X over the switch
              G91 ; set to relative positioning
              G1 Z-10 H4 ; Syringe tip probes the switch and stops when the switch actuates (that's what the H4 does)
              G90 ; set to absolute positioning
              if exists (var.current_z_pos)
                  set var.current_z_pos = move.axes[2].machinePosition
              else
              var T0_z_altura = var.current_z_pos - global.z_switch_actuation_height
                jay_s_uk @FJ3D
                @fj3d actually, it was right the first time without the dot as thats setting the variable up, so i was wrong on that one.
                Just thinking about it, you don't need to run an exists on a variable in a macro as you're only using it in that macro.
                The one that may be causing you the issue is the global. does that one exist?
                best to change your macro to
                var current_z_pos = 0
                T0 ; pick up a tool
                I suppose the next question is what are you going to do with the variable T0_z_altura as after the macro finishes its gone
                • FJ3Dundefined
                  FJ3D @jay_s_uk
                  @jay_s_uk
                  With this code I no longer get an error.
                  • Picks up the tool, positions itself at the endstop
                  • Activates it and here the maro is over, it does nothing else
                  Inside config I have the following:
                  ;OFFSET TOOLS
                  G10 P0 X-9 Y39 Z-18.5				; T0
                  ;PARA OFFSET HERRAMIENTA
                  G10 P0 Z{var.T0_z_altura} ; set new z-offset
                  M500 ; save the offset (will appear in config-override.g)
                  T-1 ; return the tool to the dock
                  global z_switch_actuation_height = 38 - 19 ; minus the thickness of the sheet of paper, too , if needed
                    jay_s_uk
                    @fj3d you can't reference a variable like that as its only present during the macro its ran so you'd have to make it a global instead.
                    and what do you mean you have that inside config.g? and changes to a G10 tool offset won't get saved in config.g unless M500 P10 is used
                    • FJ3Dundefined
                      FJ3D @jay_s_uk
                      @jay_s_uk
                      Ok, I misunderstood the explanation @HebigT
                      What I have inside config.g goes inside the macro, of course, it's logical now thought. Sorry but I don't understand programming of this type...
                      I have executed the macro and it seems that now it does everything.
                      • Activate endstop and return execute T-1
                      Now my question is, am I supposed to save myself with M500 the value in config-override.g right?
                      But I go in and this is what I see and I have:
                      ; config-override.g file generated in response to M500 at 2022-09-28 10:15
                      ; Heater model parameters
                      M307 H4 R2.430 K0.560:0.000 D5.50 E1.35 S1.00 B0 V0.0
                      ; Workplace coordinates
                      G10 L2 P1 X0.00 Y0.00 Z0.00 C0.00
                      G10 L2 P2 X0.00 Y0.00 Z0.00 C0.00
                      G10 L2 P3 X0.00 Y0.00 Z0.00 C0.00
                      G10 L2 P4 X0.00 Y0.00 Z0.00 C0.00
                      G10 L2 P5 X0.00 Y0.00 Z0.00 C0.00
                      G10 L2 P6 X0.00 Y0.00 Z0.00 C0.00
                      G10 L2 P7 X0.00 Y0.00 Z0.00 C0.00
                      G10 L2 P8 X0.00 Y0.00 Z0.00 C0.00
                      G10 L2 P9 X0.00 Y0.00 Z0.00 C0.00
                      My macro looks like this:
                      T0 ; pick up a tool
                      ** Ingnore {1}, is added in the forum...**
                        jay_s_uk @FJ3D
                        @fj3d you need to use M500 P10 not M500
                        • FJ3Dundefined
                          FJ3D @jay_s_uk
                          @jay_s_uk
                          Yes!!!! I already see added in config-override.g!!!
                          With this it would be enough if I configure it for each tool, right? In other words, if I change the needle right now by executing this macro, my tool would already be calibrated, right?
                          ; config-override.g file generated in response to M500 at 2022-09-28 10:28
                          ; Probed tool offsets
                          G10 P0 X-9.00 Y39.00 Z21.10 C0.00 0.00 0.00 0.00 0.00 0.00 0.00
                          G10 P1 X-9.00 Y39.00 Z-18.50 C0.00 0.00 0.00 0.00 0.00 0.00 0.00
                          G10 P2 X-9.00 Y39.00 Z-18.50 C0.00 0.00 0.00 0.00 0.00 0.00 0.00
                          G10 P3 X-9.00 Y39.00 Z-10.00 C0.00 0.00 0.00 0.00 0.00 0.00 0.00
                            jay_s_uk @FJ3D
                            @fj3d assuming your endstop position is calibrated, yes, it should be.
                            but best jog down to the bed and check etc
                            • FJ3Dundefined
                              FJ3D @jay_s_uk
                              @jay_s_uk
                              Another question, should I remove this line from config.g ?
                              ;OFFSET TOOLS
                              jay_s_ukundefined HebigTundefined 2 Replies Last reply Reply Quote 0
                                jay_s_uk @FJ3D
                                @fj3d shouldn't hurt having them as they get overwritten by config-override.g
                                • HebigTundefined
                                  HebigT @FJ3D
                                  @fj3d Ah, sorry you ran into issues! Thanks, @jay_s_uk for your insight.
                                  I think that's exactly right - you won't need to check whether that variable exists because I believe that variable (var.curr_z_pos) is lost when the macro ends. But I might be wrong.
                                  You would need an 'if' statement if you set up a macro to probe multiple tools in the same macro, or maybe better, just define variables specific to each tool (curr_z_pos_T0). There may be better ways to do this, though!
