    zoffset changing every time
    758
      Your homing files probe at one location, and your start gcode probes at another. They should be the same.
      How did you set the G31 trigger height?
      Please post your config.g and config-override.g
      What happens if you run a macro like this to measure the trigger height repeatedly? Does the value stay consistent, or does it drift?
      G1 Z5
      M400
      G30 S-1
      M400
      G1 Z5
      M400
      G30 S-1
      M400
      G1 Z5
      M400
      G30 S-1
      M400
      G1 Z5
      M400
      G30 S-1
      M400
      G1 Z5
      M400
      G30 S-1
      M400
      G1 Z5
      M400
      G30 S-1
      M400
      G1 Z5
      M400
      G30 S-1
      M400
      G1 Z5
      M400
      G30 S-1
      M400
      G1 Z5
      M400
      G30 S-1
      M400
      G1 Z5
      M400
      Tinchusundefined 2 Replies Last reply Reply Quote 0
      • Tinchusundefined
        Tinchus @Phaedrux
        @phaedrux @phaedrux The values do not drift al all, the sensor for sure is not the problem. The average error of the measurements in this test is 0.003 mm .
        I noticed the "error " on the homing files, but some days ago I asked about this and the answer made notbothering in change it, because: this is the 3rd machine assembled at the scholl, the oter 3 are identical in every sense, they have the same config but not the problem. The first thing I thought was "sensor failure". So I switched and used a sensor from the other printer, and the problem was still there, so the sensor was removed as the suspect ja
        • Tinchusundefined
          Tinchus @Phaedrux
          @phaedrux said in zoffset changing every time:
          to set the trigger height:
          .- Home all
          .- Cancel any existing bed compensation by sending M561
          .- Send M564 S0 to allow movement lower than where the firmware thinks Z=0 is.
          .- G1 Z1
          .- Command the print head down in small steps until the nozzle just touches the bed
          .- Send G92 Z0 to define that height as Z=0
          .- Command the nozzle up 5mm (G1 Z5)
          .- move zprobe to nozzle location:
          ---G91
          ---G1 X-7.5 Y-27
          ---G90
          .- Send G30 S-1 to probe the bed without resetting the Z=0 position (repeat 3 or 4 times to average)
          Read off the Z height from the web interface. That is the trigger height.
          Norderundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          • Norderundefined
            Norder @Tinchus
            @tinchus said in zoffset changing every time:
            Was the nozzle tip clean?
            A tiny bit of filament can falsify the result.
            DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
            Thingiverse
            Tinchusundefined Norderundefined 2 Replies Last reply Reply Quote 0
            • Tinchusundefined
              Tinchus @Norder
              @norder the nozzle is clean.
                Phaedrux Moderator @Tinchus
                With the nozzle and bed at print temp?
                G29
                Can you post a photo of your heightmap being displayed?
                Tinchusundefined 1 Reply Last reply Reply Quote 0
                • Norderundefined
                  Norder @Norder
                  The print bed and the nozzle should be heated up during this measurement.
                  Best with the temperatures that are used for the most part.
                  It is best to use a feeler gauge or a metal setting plate for this measurement.
                  If this setting plate has a thickness of 0.5 mm, for example, then later subtract this value from the release height.
                  I do it like this...
                  Heat up the print bed and nozzle.
                  Homen (G28).
                  Run the nozzle directly over a level screw of the print bed with a Z height of 0.05mm.
                  Place a 0.05mm spring steel sheet between the nozzle and the print bed and adjust the level screw of the print bed so that the adjustment sheet is slightly clamped.
                  Make sure that there is no filament at the nozzle tip!
                  Now I move the sensor exactly over the spot where the nozzle was before.
                  I measure 10x the trigger height and then determine the subtotal.
                  This is the exact Z offset of the probe!
                  Google Translate
                  -- Original Text --
                  Das Druckbett und die Düse sollten bei dieser Messung aufgeheizt sein.
                  Am besten mit den Temperaturen die zum größten Teil genutzt werden.
                  Nehme für diese Messung am besten eine Fühllehre oder ein Einstellblech aus Metall.
                  Hat dieses Einstellblech zB eine Stärke von 0,5mm, dann ziehe diesen Wert später von der Auslösehöhe wieder ab.
                  Ich mache es so...
                  Druckbett und Düse aufheizen.
                  Homen (G28).
                  Düse direkt über eine Levelschraube des Druckbettes fahren mit einer Z Höhe von 0,05mm.
                  0,05mm Federstahlblech zwischen Düse und Druckbett legen und die Levelschraube des Druckbettes so einstellen dass das Einstellblech leicht geklemmt wird.
                  Dabei darauf achten das kein Filament an der Düsenspitze ist !
                  Jetzt bewege ich den Sensor genau über die Stelle wo vorher die Düse war.
                  Ich messe 10x die Auslösehöhe und ermittele danach die Zwischensumme.
                  Das ist der genau Z-Offset der Sonde !
                  Thingiverse
                  • Tinchusundefined
                    Tinchus @Norder
                    @norder Lets focus. We are talking about a heated chamber printer, is not a prusa clone. Have you tried to put a gage under he nozzle while the nozzle is at 400 degrees C and the chamber is at 120 degrees celcius? The way to do it is on cold, THEN you add and offset rlated to temperature.
                    As I said: this is not the first time I do it and we have another 2 printers, exactly the same in hardware and configuration, and the procedure on them was the same, and this behaviour is not happening on them
                    Norderundefined 1 Reply Last reply Reply Quote 0
                    • Tinchusundefined
                      Tinchus @Phaedrux
                      @phaedrux No, I do it on cold, knowing that later the real value will need to be adjusted with babystepping, and I use the babystepping extra to correct the z trigger gotten on cold. It is not possible to do this with the chamber hot, it is at 120 degrees celsius, you would burn your face and fingers...
                      But going back to original question: im not having a problem with the mesh, once I adjust with baby stepping, the first layer is excelent.
                      The problem is later when I turn off the printer and start a new one: I have to baby step again, EVEN after I already corrected the offset on the config, and I already checked using G31 that the new offset is acive
                      • Norderundefined
                        Norder @Tinchus
                        @tinchus
                        Then the next step would be to measure the geometry and check whether components are deformed or have loosened connections that could cause this behavior.
                        Thingiverse
                          I have to baby step again, EVEN after I already corrected the offset on the config, and I already checked using G31 that the new offset is active
                          Understood. However, if you're using the babystep method to modify the Z offset, are you waiting the same amount of time for heat soak to occur? I could see variance in temperature and time resulting in different Z positions. You meanion other printers, are they all identical?
                          • Tinchusundefined
                            Tinchus @Phaedrux
                            @phaedrux Yes, the probing on the ced start ONLY after 10 minutes of waiting to be sure all temp is stable (actually the variation inside the cmaber is only 3 degrees at the front and back, very stable). I do the baby stepping when the print has already started and printing a brim wich I use to fine tune the first layer by eye (there is a window to see). The other 2 printer are exactly the same, same hardware, same software, same configuration. There is no even 1 single screw different. I have checked the hardware to see if there is something loose, it is all ok.
                            And the offset variation is very stable: I i print and baby step 0.2 mm, next time the printer is ON and ofsset already corrected and active on config, I will have to baby steps another 0.2mm again... same value as before.
                            Very weird.
                            How can I update the firmware to a specific version? Im think on reflashing the firmware? coud it be corrupt or something like that?
                            • Norderundefined
                              Norder @Tinchus
                              @tinchus
                              Have you tried copying the most important files such as config.g, homeall.g etc. from one of the two printers 1:1 without any problems and then overwriting the files on the problem printer?
                              A tiny mistake quickly creeps in that is overlooked.
                              If the three printers are identical, this shouldn't be a problem.
                              Google Translate
                              -- Original Text --
                              Hast Du schon versucht die wichtigsten Dateien wie config.g, homeall.g etc. von einem der beiden Druckern ohne Probleme, 1:1 zu kopieren und dann die Dateien auf dem Problem-Drucker zu überschreiben ?
                              Es schleicht sich schnell mal ein winziger Fehler mit ein den man übersieht.
                              Wenn die drei Drucker identisch sind, sollte das kein Problem darstellen.
                              Thingiverse
                              • Tinchusundefined
                                Tinchus @Norder
                                @norder it is the way the printer got its config: I just copied the files from the other one
                                  Upload the full zip file for the version you want. I don't think it's a firmware issue though.
                                  It sounds like there is a stray command somewhere that is altering the expected value.
                                  The results of M122 and M98 P"config.g" as well please.
                                    If the firmware is the same. The config is the same. Then I suspect a mechanical difference.
                                    • Tinchusundefined
                                      Tinchus @Phaedrux
                                      @phaedrux M98 P"config.g" ginves nothing, no error, just the green OK
                                      M122:
                                      RepRapFirmware for Duet 3 MB6HC version 3.4.1 (2022-06-01 21:09:01) running on Duet 3 MB6HC v1.01 or later (SBC mode)
                                      Board ID: 08DJM-956BA-NA3TJ-6J1FD-3S46K-KA8AS
                                      Used output buffers: 1 of 40 (13 max)
                                      Static ram: 151000
                                      Dynamic ram: 66952 of which 0 recycled
                                      Never used RAM 132528, free system stack 154 words
                                      Tasks: SBC(ready,0.6%,438) HEAT(notifyWait,0.0%,321) Move(notifyWait,0.0%,267) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.0%,333) TMC(notifyWait,8.5%,58) MAIN(running,90.5%,923) IDLE(ready,0.3%,30), total 100.0%
                                      Owned mutexes: HTTP(MAIN)
                                      Last reset 00:20:26 ago, cause: software
                                      Last software reset at 2022-10-06 17:11, reason: User, GCodes spinning, available RAM 132560, slot 2
                                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                                      Error status: 0x00
                                      Step timer max interval 155
                                      MCU temperature: min 37.8, current 38.2, max 38.6
                                      Supply voltage: min 24.0, current 24.5, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                                      12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
                                      Events: 0 queued, 0 completed
                                      Driver 0: standstill, SG min 0, mspos 696, reads 37630, writes 24 timeouts 0
                                      Driver 1: standstill, SG min 0, mspos 280, reads 37631, writes 24 timeouts 0
                                      Driver 2: standstill, SG min 0, mspos 264, reads 37615, writes 40 timeouts 0
                                      Driver 3: standstill, SG min 0, mspos 616, reads 37615, writes 40 timeouts 0
                                      Driver 4: standstill, SG min 0, mspos 680, reads 37631, writes 24 timeouts 0
                                      Driver 5: standstill, SG min 0, mspos 8, reads 37636, writes 19 timeouts 0
                                      Date/time: 2022-10-06 17:31:53
                                      Slowest loop: 179.60ms; fastest: 0.04ms
                                      === Storage ===
                                      Free file entries: 10
                                      DMs created 125, segments created 8, maxWait 88059ms, bed compensation in use: mesh, comp offset 0.000
                                      === MainDDARing ===
                                      Scheduled moves 486, completed 486, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
                                      === AuxDDARing ===
                                      Bed heaters -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 0 -1 -1 -1, ordering errs 0
                                      Heater 0 is on, I-accum = 0.0
                                      Heater 1 is on, I-accum = 0.0
                                      Segments left: 0
                                      Movement lock held by null
                                      Telnet is idle in state(s) 0
                                      File* is idle in state(s) 0
                                      USB is idle in state(s) 0
                                      Aux is idle in state(s) 0
                                      Queue* is idle in state(s) 0
                                      LCD is idle in state(s) 0
                                      SBC is idle in state(s) 0
                                      Daemon is idle in state(s) 0
                                      Aux2 is idle in state(s) 0
                                      Code queue is empty
                                      === CAN ===
                                      Messages queued 10990, received 0, lost 0, boc 0
                                      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 6131/0/0
                                      Tx timeouts 0,0,6130,0,0,4858 last cancelled message type 30 dest 127
                                      === SBC interface ===
                                      Transfer state: 5, failed transfers: 0, checksum errors: 0
                                      RX/TX seq numbers: 49406/49406
                                      SPI underruns 0, overruns 0
                                      State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2b880
                                      Buffer RX/TX: 0/0-0, open files: 0
                                      === Duet Control Server ===
                                      Duet Control Server v3.4.1
                                      Code buffer space: 4096
                                      Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
                                      Full transfers per second: 40.44, max time between full transfers: 197.2ms, max pin wait times: 71.4ms/30.4ms
                                      Codes per second: 0.62
                                      Maximum length of RX/TX data transfers: 3266/884
                                        I still think it's mechanical issue on this printer. Since you have other identical printers you have the perfect way to verify, albeit with some time and effort, you could take the entire Duet and transplant it into the other printer, and vice versa. Does the issue follow the Duet, or stay with the printer?
                                        Norderundefined 1 Reply Last reply Reply Quote 1
                                        • Norderundefined
                                          Norder @Phaedrux
                                          @phaedrux
                                          We are of the same opinion.
                                          But what is strange... that it is always about this 0.2mm, which could be more for a wrong command line, for example in config.g or config-override.g.
                                          But you would have to be able to see these files, which you asked for three times.
                                          @tinchus
                                          Please post the requested files (config.g and config-override.g) if you want help here.
                                          Thingiverse
