Cura & RRF Power Supply (M80)
Hi All,
I've now got power supply management working and wanted to have the gcode turn on the power before a print begins. However if I put M80 in Cura's "Machine Settings", "Start G-code" the generated code try's to set heater temps etc before turning on the PSU, i.e. there is code in the print file before the M80 command.Any thoughts on how I sort this? Is there somewhere else in Cura to put pre-printing commands?
Any constructive thoughts would be much approciated.
Cheers
Barry M -
@cncmodeller Can you post the Cura 'start G-code' you are using, and the start of the Gcode file it generates?
@cncmodeller Perhaps you could place your M80 in a start.g file, I think that gets run before any of the gcode in the file being printed....
@gloomyandy , that's a good idea I'll give it a go, thanks
@droftarts said in Cura & RRF Power Supply (M80):
Start GCode
G80 G28 ;Home G1 Z15.0 F6000 ;Move the platform down 15mm ;Prime the extruder G92 E0 G1 F200 E3 G92 E0 Cura Generated file
;FLAVOR:RepRap ;TIME:14160 ;Filament used: 17.4632m, 0m ;Layer height: 0.2 ;MINX:-47.024 ;MINY:-47.02 ;MINZ:0.3 ;MAXX:47.026 ;MAXY:47.03 ;MAXZ:61.3 ;Generated with Cura_SteamEngine main T0 M190 S90 M104 S240 M109 S240 M82 ;absolute extrusion mode G80 G28 ;Home G1 Z15.0 F6000 ;Move the platform down 15mm ;Prime the extruder G92 E0 G1 F200 E3 G92 E0 As you can see the heaters get triggered before the machine setting Gcode is executed.
In order to have Cura move the temp commands later in the file you would have to add some placeholder tokens to your start gcode.
http://files.fieldofview.com/cura/Replacement_Patterns.html
When it parses your start gcode and sees you are using temp commands it will stop adding its own temp commands to the start of the file.
@gloomyandy said in Cura & RRF Power Supply (M80):
For completeness this approach works great.
I also have a M81 S1 in my stop.g to shut off power after a print has been completed.
Thanks All,
Barry M -
