    M140 P0 S55 Error: Invalid password!
    1.7k
      jay_s_uk @Dizzwold
      @Dizzwold have you modified the bed file in any way or is the one you posted higher up still valid?
      Dizzwoldundefined 1 Reply Last reply Reply Quote 0
      • Dizzwoldundefined
        Dizzwold @jay_s_uk
        @jay_s_uk
        Still valid;
        ; bed.g
        ; generated by RepRapFirmware Configuration Tool v3.3.13 on Mon Sep 19 2022 16:04:20 GMT+0100 (British Summer Time)
        ;M561 ; clear any bed transform
        ;G29  ; probe the bed and enable compensation
        G28			; home
        G30 P0 X5 Y5 Z-9999				; probe front left
        G30 P1 X278 Y5 Z-9999			; probe front right
        G30 P2 X278 Y302 Z-9999			; probe rear right
        G30 P3 X5 Y302 Z-9999 S4  		 ;probe rear left
        G1 X0 Y0
        ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
        M575 P1 S1 B57600                                  ; enable support for PanelDue
        G90                                                ; send absolute coordinates...
        M83                                                ; ...but relative extruder moves
        M550 P"Duet 3"                                     ; set printer name
        M669 K1                                            ; select CoreXY mode
        ; Bed Adjustment Screw Positions
        M671 X5:278:278:5 Y5:5:302:302 P0.5					; front left, front right, back right, back left
        G4 S1												;wait for expansion boards to start
        M569 P0.0 S0                                       ; physical drive 0.0 goes backwards
        M569 P0.1 S0                                       ; physical drive 0.1 goes backwards
        M569 P0.2 S1                                       ; physical drive 0.2 goes forwards
        M569 P0.3 S1
        M569 P121.0 S0                                       ; physical drive 0.3 goes forwards
        M584 X0.0 Y0.1 Z0.2:0.3 E121.0                           ; set drive mapping
        M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
        M92 X80.00 Y80.00 Z400.00 E333.40                  ; set steps per mm
        M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
        M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
        M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
        M906 X900 Y900 Z900 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
        M84 S30                                            ; Set idle timeout
        M208 X-2 Y-8 Z0 S1                                 ; set axis minima
        M208 X330 Y330 Z400 S0                             ; set axis maxima
        M574 X1 S1 P"!121.io1.in"                              ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !io1.in
        M574 Y1 S1 P"!io2.in"                              ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !io2.in
        M574 Z1 Z1 S2									   ; set endstops controlled be probe
        M558 P8 C"^!121.io0.in" H5 F120 T6000                 ; set Z probe type to switch and the dive height + speeds
        G31 P500 X-46 Y-19 Z2.52                            ; set Z probe trigger value, offset and trigger height
        M557 X19:244 Y-2:304 P9                           ; define mesh grid
        M308 S0 P"temp0" Y"thermistor" T100000 B4138       ; configure sensor 0 as thermistor on pin temp0
        M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
        M307 H0 R0.187 K0.192:0.000 D1.89 E1.35 S1.00 B0   ; disable bang-bang mode for the bed heater and set PWM limit
        M140 H0                                            ; map heated bed to heater 0
        M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
        M308 S1 P"121.temp0" Y"thermistor" T100000 B4138       ; configure sensor 1 as thermistor on pin temp1
        M950 H1 C"121.out0" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
        M307 H1 R2.498 K0.275:0.349 D6.79 E1.35 S1.00 B0 V24.0  ; disable bang-bang mode for heater  and set PWM limit
        M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
        M950 F0 C"121.out1" Q500                               ; create fan 0 on pin out4 and set its frequency
        M106 P0 C"Print Cooler" S0 H-1                     ; set fan 0 name and value. Thermostatic control is turned off
        M950 F1 C"121.out2" Q500                               ; create fan 1 on pin out5 and set its frequency
        M106 P1 C"Extruder Cooling" S1 H1 T45              ; set fan 1 name and value. Thermostatic control is turned on
        M563 P0 S"Hemera" D0 H1 F0                         ; define tool 0
        G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
        G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
        ; Emergency Stop
        M950 J1 C"io4.in"
        M851 P1 T0 S0 R0
        T0
        M501
          jay_s_uk @Dizzwold
          @Dizzwold the only thing that jumps out at me as being strange is you tell the firmware you have 4 screws, and probe 4 points but only have 2 motors. I would suggest that this may be causing you issues.
          you should only set the 2 positions where the bed pivots on the z motor mounts
          • Dizzwoldundefined
            Dizzwold @jay_s_uk
            @jay_s_uk
            Okay, I'll change that.
            I had problems connecting directly. I couldn't connect, so I've been a purchase one of these RJ45 testers and everything was fine. Checked the address again in the monitor connected to the RPi and the address completely changed, xxx.xxx.xxx.xxx/16, butwith a 404 page not found?
            I'll change the bed.g now and run another test.
            • Dizzwoldundefined
              Dizzwold @Dizzwold
              @jay_s_uk
              Thank you for pointing this out and correcting me on the correct path.
              I remember reading about the leadscrew positions when I purchased the Duet over a year ago, and I think it was in the old guide (was it the RRF2 configure?), but when I used the configurer, when I finally got around to installing the Duet, things had changed and I didn't see anything regarding the leadscrew positions.
              After I'd configured the duet I thought about this, so had a little search around. As I didn't find much to date on this, I just presumed things had moved on and this was no longer needed.
              The guide does also state that for a bed like mine, to use the bed.g and give the positions of the screws to level it (using the manual bed levelling process, not the leadscrews).
              Maybe I got confused?
              Anyhow, I've changed the bed.g and config.g to suit the positions of my 2 leadscrews.
              I'm now on ethernet, on my network, wifi disabled on the RPi and all my cables checkout okay.
              Guess what. Only 1 scan with the bed compensation now and not 2 or 3, but still throwing up a network error?
              I didn't have either the bed or nozzle heaters on for this, so going to d another PID for the nozzle before I try the bed compensation again.
              At-least some progress. Thank you.
                jay_s_uk @Dizzwold
                @Dizzwold do you have any more information on the probe you are using?
                • Dizzwoldundefined
                  Dizzwold @jay_s_uk
                  @jay_s_uk
                  Not a great deal. I asked Tronxy and they either don't want to give much detail of they don't know. Here's there reply when I asked for details;
                  The TR leveler has no parameters.
                  All I know is it's 6-32v (won't work on 5v), NPN inductive glass sensor. I've connect it to the 24v power in on the Fysetc toolboard v1.0.
                  From my understanding it's similar to the PL-08N, except it will detect glass, and pretty good at doing so imo, although I've only used it with the ‘Lattice Glass’ that comes with it.
                  Blue cable = -v wired to toolboard io0 gnd
                  Black cable = signal wired to toolboard io0 in
                  Brown cable = +v wired to Vin power in on toolboard
                    jay_s_uk @Dizzwold
                    @Dizzwold no more thoughts on that then.
                    have you tried running the 6HC in standalone mode if you're using ethernet?
                    avoiding the SBC route is typically my advice anyway
                    • Dizzwoldundefined
                      Dizzwold @jay_s_uk
                      @jay_s_uk
                      Hmm, no I've not tried it in stand alone.
                      To do so will I have to restart again with the configuration tool?
                        jay_s_uk @Dizzwold
                        @Dizzwold you can download all your config files from the printer before you switch over, so download everything from the sys folder.
                        You'll need to add M552 S1 P0.0.0.0 somewhere in your config.g to turn on the ethernet interface.
                        https://docs.duet3d.com/en/User_manual/Overview/Getting_started_Duet_3_MB6HC#getting-started
                        Then use another SD card and put the downloaded files in a folder called sys in the root of the SD card
                        Also download DWC for the version you're running from here https://github.com/Duet3D/RepRapFirmware/releases and extract it to a folder called www in the root of the sd card.
                        Pop that in your machine and you should be good to go.
                        • Dizzwoldundefined
                          Dizzwold @jay_s_uk
                          @jay_s_uk
                          Lol, I've only got 64gb sd cards spare, not 32gb, what a dilemma to have.
                          I was just looking at the page you've linked to (getting started), I was also looking at setting up a fixed ip on the next page (getting connected).
                          Looks like I'll have to wait for nozama to deliver some 32gb cards tomorrow (i read somewhere you shouldn't go above that). Thinking about it I still have the original sd card that came with the unit.
                            jay_s_uk @Dizzwold
                            @Dizzwold yes, fat32 only originally supported up to 32gb. you can force a 64gb to partition etc but its too much effort
                            • Dizzwoldundefined
                              Dizzwold @jay_s_uk
                              @jay_s_uk
                              Just tried it again after nozzle pid, heaters on G28, G32, G29;
                              It scanned twice again and through up the network error on the 5th row (9 across x 9 front to back), on the second scan.
                                jay_s_uk @Dizzwold
                                @Dizzwold you must have a G29 somewhere in your files as that's what will do the 9x9
                                • Dizzwoldundefined
                                  Dizzwold @jay_s_uk
                                  @jay_s_uk
                                  Isn't that under M557 Z-Probe in config.g ?
                                  G31 P500 X-46 Y-19 Z2.48                            ; set Z probe trigger value, offset and trigger height
                                    jay_s_uk @Dizzwold
                                    @Dizzwold M557 sets the grid size. G29 does the actual probing
                                    • Dizzwoldundefined
                                      Dizzwold @jay_s_uk
                                      @jay_s_uk
                                      I was under the impression that you have the grid size and probe points in Z-Probe M557 in config.g, like I currently have and then you just send G29 from the DWC console?
                                        jay_s_uk @Dizzwold
                                        @Dizzwold yes, you can call G29 from the console or from within a marco or job
                                        • Dizzwoldundefined
                                          Dizzwold @jay_s_uk
                                          @jay_s_uk
                                          That's what I'd done.
                                          The last 2 screenshots, the top one, I did M561, G28, G32, followed be G29 @ 17.24.11, you can see the spinning Blue Send Button.
                                          I ran 1 full scan of 9 x9 probe points, then immediately started a 2nd scan. Half way through the 2nd scan if gave the G29 Network Error in DWC @ 17.34.26 and continued to finish the 2nd scan.
                                          I wanted to show that I was sending all the correct command codes in sequence and show how and when the error was popping up.
                                          Please correct me if I'm doing this wrong, and this is why I'm getting the issues.
                                          It's just weird that it will complete a full scan, then for unknown reasons start a 2nd scan, then halfway through the 2nd give the error?
                                            jay_s_uk @Dizzwold
                                            @Dizzwold do you have a mesh.g file?
