    Induction probe false triggering
    849
    • bubblevisorundefined
      bubblevisor
      I have a confusing problem where the induction probe often randomly triggers without being close to the bed. It behaves fine 90% of the time but occasionally it just randomly gives a false positive. I can't even get it to complete a full bed mesh without a false trigger error. I have swapped probes but no change.I t seems like some kind of interference to me. Anyone else experienced this?
        Give us some more details on your setup. Hardware and config.
          bubblevisor
          Its a v2 FINDA type probe. The bed is spring steel on magnetic sheet. Duet 2 wifi. When I test the probe by placing something ferrous close to it, it seems fine. However running bed mesh and gantry tramming it gives false positives around 10% of the time.
            bubblevisor
            M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
            Board ID: 0JD0M-9P61A-J8PS8-6JTDG-3S86M-TVVAT
            Used output buffers: 3 of 24 (24 max)
            Static ram: 23876
            Dynamic ram: 75904 of which 60 recycled
            Never used RAM 11720, free system stack 86 words
            Tasks: NETWORK(ready,383.5%,217) HEAT(delaying,11.1%,305) Move(notifyWait,184.8%,283) MAIN(running,467.8%,420) IDLE(ready,6.1%,29), total 1053.4%
            Owned mutexes: WiFi(NETWORK)
            Last reset 72:48:15 ago, cause: power up
            Last software reset at 2022-10-07 22:43, reason: User, GCodes spinning, available RAM 14784, slot 2
            Error status: 0x0c
            Aux0 errors 0,2,0
            Step timer max interval 0
            MCU temperature: min 43.6, current 58.4, max 63.4
            Supply voltage: min 23.8, current 24.0, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
            Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/1844/1758, gc cycles 0
            Driver 0: position 175221, ok, SG min/max 0/717
            Driver 1: position -11459, standstill, SG min/max 0/1023
            Driver 2: position 67200, standstill, SG min/max 0/1023
            Driver 3: position 0, ok, SG min/max 0/1023
            Driver 4: position 0, ok, SG min/max 0/292
            Driver 5: position 0
            Driver 6: position 0
            Driver 7: position 0
            Driver 8: position 0
            Driver 9: position 0
            Driver 10: position 0
            Driver 11: position 0
            Date/time: 2022-10-25 21:53:25
            Slowest loop: 785.68ms; fastest: 0.09ms
            === Storage ===
            Free file entries: 9
            SD card longest read time 4.4ms, write time 23.4ms, max retries 0
            DMs created 83, maxWait 48763938ms, bed compensation in use: none, comp offset 0.000
            === MainDDARing ===
            Scheduled moves 96276, completed moves 96236, hiccups 64845, stepErrors 0, LaErrors 0, Underruns [80, 0, 13], CDDA state 3
            === AuxDDARing ===
            Heater 0 is on, I-accum = 0.1
            Heater 1 is on, I-accum = 0.5
            Segments left: 1
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is doing "G1 X118.473 Y141.742 F18000" in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 785.85ms; fastest: 0.00ms
            HTTP sessions: 1 of 8
            • WiFi -
              Network state is active
              WiFi firmware version 1.26
              WiFi MAC address e8:db:84:cf:b6:f1
              WiFi Vcc 3.39, reset reason Power up
              WiFi flash size 4194304, free heap 26904
              WiFi IP address 192.168.1.11
              WiFi signal strength -69dBm, mode 802.11n, reconnections 0, sleep mode modem
              Clock register 00002002
              bubblevisor
              T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 0
                T3P3Tony administrators @bubblevisor
                @bubblevisor can you see if having the FAN on or off makes a difference. It looks to me like the probe is mounted right next to the fan motor.
                bubblevisorundefined 1 Reply Last reply Reply Quote 0
                  bubblevisor @T3P3Tony
                  @T3P3Tony I was wondering the same thing. Let me do some back to back comparisons and report back.
                    bubblevisor
                    Testing back to back, it does seem the running fan is causing the false triggering problem. I need to test further to better confirm this but I can now complete a bed mesh without errors with the fan off.
                    My question now is; how can you shield the probe from magnetic flux emanating from the fan? I realise the more obvious solution is to move the probe further away, however I am keen to keep the probe in its position close to the nozzle to reduce error and for packaging reasons.
                    The stainless probe barrel is non magnetic so I am thinking a mild steel foil around the FINDA probe. Any other ideas?
                      Phaedrux Moderator @bubblevisor
                      @bubblevisor said in Induction probe false triggering:
                      Any other ideas?
                      Turn off the fan during probing.
                        bubblevisor @Phaedrux
                        @Phaedrux Thanks for the suggestion. How would you suggest doing this without there being a overheating risk? It seems if you set fan M106 S1 H1 T45 thermistor mode then you cannot overide this in subsequent gcode.
                          bubblevisor @bubblevisor
                          I thought I could just change the start gcode to not heat up the hotend until bed mesh is done but I can't see the facility to do this with slicing software. I use prusaslicer.
                            dc42 administrators @bubblevisor
                            @bubblevisor you have the inductive sensor in the worst possible place relative to the fan, from the point of view of picking up magnetic fields from it. Can you move the sensor sideways, so that it is on one side of the fan or at least lined up with one edge of the fan?
                              In prusa slicer you must insert your own temperature commands into your start gcode for it to stop inserting it's own preheating commands to the beginning of the files. You can use the placeholder values to insert your chosen temps.
                              Here is a list of placeholder variables: https://help.prusa3d.com/article/list-of-placeholders_205643 and here https://help.prusa3d.com/article/macros_1775
                              The first one doesn't seem to be complete for some reason.
                              Example would be something like
                              M106 S0 H-1 ; disable hotend fan
                              G28 ; home
                              G32 ; leveling
                              G29 ; mesh
                              M106 S1 H1 T45 ; re-enable temp controlled fan
                              M104 S{first_layer_temperature[0]} ; set first layer temp
                              M116 ; wait for temp
                                bubblevisor
                                I have changed the induction probe position to ensure no emc noise is reaching from the fan. However I still have z homing and bed mesh issues.
                                I'm beginning to think it a problem with the board. It worked fine when I built the printer over a year ago but lately there have been increasing intermittent issues with the z induction probe "not triggering" or "triggering before move" errors.
                                Now, the printer won't respond to the tool length micro switch. Bizarrely it now z homes responding to the induction probe. All without me changing the config! What could be going on here??
                                I have checked the board led is reacting correctly to the tool length probe switch, which it does so fine. Could this really be a faulty board?
                                  bubblevisor
                                  ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jul 20 2021 13:11:51 GMT+0100 (British Summer Time)
                                  M550 P"Saphire" ; set printer name
                                  M669 K1 ; select CoreXY mode
                                  M552 S1 ; enable network
                                  M586 P0 S1 ; enable HTTP
                                  M586 P1 S0 ; disable FTP
                                  M586 P2 S0 ; disable Telnet
                                  M569 P0 S1 D2 ; physical drive 0 goes forwards
                                  M569 P4 S1 D2 ; physical drive 4 goes forwards
                                  M569 P2 S0 D2 ; physical drive 2 goes forwards
                                  M569 P3 S0 D2 ; physical drive 3 goes forwards
                                  M569 P1 S0 D2
                                  M584 X0 Y4 Z1:2 E3 ; set drive mapping
                                  M350 X128 Y128 Z128 E16 I0 ; configure microstepping without interpolation
                                  M92 X640.00 Y640.00 Z6400.00:6400.00 E669.00 ; set steps per mm
                                  M566 X1000.00 Y1000.00 Z100:100 E520.00 P1 ; set maximum instantaneous speed changes (mm/min)
                                  M203 X20000.00 Y20000.00 Z800.00:800.00 E70000.00 ; set maximum speeds (mm/min)
                                  M201 X20000.00 Y20000.00 Z200.00:200.00 E4000.00 ; set accelerations (mm/s^2)
                                  M906 X1100 Y1100 Z1300 E850 I30 ; set motor currents (mA) and motor idle factor in per cent
                                  M84 S30 ; Set idle timeout
                                  M208 X300 Y299 Z340 S0 ; set axis maxima
                                  ;M556 S100 X0 Y0 Z0:0:0 ; set skew x.xxmm on 100mm square x-y obtuse
                                  M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin !xstop
                                  M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin !ystop
                                  M574 Z0 P"nil" ; No Z endstop
                                  M558 K0 P5 C"^zprobe.in" H2 F1000 T6000 A20 S0.01 ; set Z probe type to effector and the dive height + speeds, max number of probes per point, tolerance(MM)
                                  ;M308 S2 P"e1temp" A"PINDA" Y"thermistor" T100000 B3950 ; configure sensor 2 as thermistor on pin e1temp
                                  G31 K0 P1000 X-34.5 Y-13 Z0.18 ;H2 S27 T0.020 ; set Z probe trigger value, xy offset, z trigger height(higher=closer to bed)don't care, temp sensor number, reference temp, compensation coefficient mm/degree(higher more close when hot)
                                  ;Bed Levelling
                                  M671 X4:233 Y170:170 S25 ;leadscrew/pivot locations and max allowable deviation
                                  M557 X10:265 Y5:270 P6:6 ; define mesh grid
                                  ; Z Tool Length probe
                                  M558 K1 P5 C"^zstop" T8000 F600 H2 A10 S0.01 R0.2 ;set second (K1) Z probe: pin in, travel speed to probe, probing speed, dive height, max number of probes, tolerance(MM), rest time
                                  G31 K1 P500 X0 Y0 Z0.75 ;set second (K1) Z probe: trigger value (higher value = closer nozzle)
                                  M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                                  M307 H0 B0 R1.028 C177.2 D6.82 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
                                  M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
                                  M307 H1 B0 R2.373 C103.0 D8.21 S1.00 V24.2 ; disable bang-bang mode for heater and set PWM limit
                                  M308 S3 A"Chamber" P"exp.thermistor3" Y"thermistor" T100000 B3950 ; configure sensor 3 as "thermistor" type on pin "thermistor3" (Henry added for chamber monitoring)
                                  M106 P0 S0 H-1 C"Part cooling fan" ; set fan 0 value. Thermostatic control is turned off
                                  M106 P1 S1 H1 T85 C"Heat Break Fan" ; set fan 1 value. Thermostatic control is turned on
                                  M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency (Henry add chamber fan)
                                  M106 P2 S0 H-1 C"Chamber fan" ; set fan 0 value. Thermostatic control is turned off
                                  ;LED Lights
                                  M950 P0 C"e1heat"
                                  M42 P0 C"LEDs"
                                  M563 P0 S"Dragon" D0 H1 F0:1 ; define tool 0
                                  M911 S21 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                                  T0 ; select first tool
                                    bubblevisor
                                    Here's the homez.g
                                    ; homez.g
                                    ; called to home the Z axis
                                    ;G91 ; relative positioning
                                    ;G1 H2 Z5 F6000 ; lift Z relative to current position
                                    ;G90 ; absolute positioning
                                    M98 P"go to z-switch.g"
                                    G30 K1 Z-999 ; home Z by probing the bed via K1
                                    G1 Z5 F2000 ;lift z
                                      bubblevisor
                                      Btw, the board is a duet 2 wifi.
                                        bubblevisor @dc42
                                        @dc42 Could my issue be a board fault? The printer now is completely non responsive to the tool length probe micro switch (that also doubles as Z endstop). Instead it now z end stops via the induction probe. All without me touching the config!. Can this be a board/firmware fault??
                                          Can you post the rest of your macros?
                                          This still sounds like interference. Did you investigate turning the fan off during probing?
                                            bubblevisor
                                            config.g homeall.g homez.g bed.g
