    Strange Blobbing on Layer Change
    blob
    13
    54
    7.4k
    • Norderundefined
      Norder @Phaedrux
      @Phaedrux
      Does prusa slicer now allow per move jerk settings as well as acceleration? I didn't think so.
      The PrusaSlicer has its own jerk setting (mm/s), maximum acceleration (mm/s²) and maximum feed (mm/s)
      for each axis.
      DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
      Thingiverse
        Phaedrux Moderator @Norder
        @Norder said in Strange Blobbing on Layer Change:
        Where? You mean in the machine limits?
        Norderundefined 1 Reply Last reply Reply Quote 0
        • Norderundefined
          Norder @Phaedrux
          @Phaedrux
          Yes, exactly.
          But it is clear that the upper limit is determined by the config.g.
          Thingiverse
          davidewenundefined 1 Reply Last reply Reply Quote 0
          • davidewenundefined
            davidewen @Norder
            @Norder @Phaedrux @weed2all
            Thank you all for responding.
            I will not be able to check settings or respond back with said settings until late next week.
            Cheers
              davidewen @Phaedrux
              @Phaedrux
              Yes, I made those changes in PrusaSlicer.
              Are you suggesting that I make the changes in config.g?
              And if so, is that command M566?
              My current M566 is not labeled "jerk" so I just want to confirm.
              M566 X1500.00 Y1500.00 Z600.00 E120.00			; set maximum instantaneous speed changes (mm/min)
              M203 X12000.00 Y12000.00 Z600.00 E2100.00		; set maximum speeds (mm/min)
              M201 X1500.00 Y1500.00 Z500.00 E250.00			; set accelerations (mm/s^2)
                Yes, maximum instantaneous speed changes is often called jerk.
                  davidewen @Phaedrux
                  @Phaedrux
                  Got it. Do you have some recommendations from my current settings?
                    Phaedrux Moderator @davidewen
                    @davidewen Try these
                    M566 X1500.00 Y1500.00 Z600.00 E3000			; set maximum instantaneous speed changes (mm/min)
                    M203 X12000.00 Y12000.00 Z600.00 E6000		; set maximum speeds (mm/min)
                    M201 X1500.00 Y1500.00 Z500.00 E3000			; set accelerations (mm/s^2)
                      davidewen @Phaedrux
                      @Phaedrux
                      Thanks for the info. This has helped a lot. Seam is still there, but greatly improved.
                      I will play around with these settings to see if I can get it to almost perfect.
                      Cheers!
                        @davidewen said in Strange Blobbing on Layer Change:
                        Have you tune pressure advance yet? That's the remaining piece of the puzzle.
                        https://docs.duet3d.com/en/User_manual/Tuning/Pressure_advance
