Spindle inactive on resume
@Nightowl I don't think it has to do with not having enough time to write anything to the SD card as I do a Controlled Power Off. The job is paused, resume state saved and the Duet tells you you can turn it off.
I put an M3 command into the resurrect-prologue.g file hoping this would fix the problem. The spindle turns on and dwells for 2 seconds as programmed but then turns off before it rams the endmill into the part. If I am quick enough I am able to turn it on via the dashboard but this is too risky.
Looking at the resurrect.g file, I think all tools are deselected before the job is resumed.
If I could find a way to reselect the spindle, it should work. -
Firmware version?
@Phaedrux 3.4.4
@chimaeragh said in Spindle inactive on resume:
I'm not sure, but wouldn't pausing the process and powering down provide enough time for the resurrect file to be written, rather than an instant(ish) power failure?
Having said that, I think I misread your original post. You appear to want to do this as a matter of routine, for a particularly long job, for example?
As a casual CNC user, I wouldn't want my spindle to turn on after power failure. I hope that feature is optional in RRF3.5?
I also have a separate PSU for the spindle and was wondering, if there is a way to have two different power loss command lines? One for Duets power, the other for spindle power.Sorry if that was slightly offtopic, but it got me concerned what I read here.
Hopefully it won't, @o_lampe
The CNC should stay off without user intervention, as the machine would need to be re-homed on all axes before returning to the last known co-ordinates and restarting the cut.
I don't know about 3D printer users, but I would never leave a CNC unattended when it's working.
@chimaeragh I confirm that spindle state and RPM are not saved in resurrect.g. Also the tool select command in resurrect.g that occurs after the command to run resurrect-prologue.g will set the spindle state to stopped, as required by the NIST specification.
I have implemented what I hope is a fix in the RRF 3.5 code. I had to include a fixed delay after the M3 or M4 command, and I chose 2 seconds for this.
Meanwhile, if you want to resurrect a job with the spindle running, you will need to edit the M3 or M4 command and the G4 delay command into resurrect.g after the T command.
Thank you, @dc42 (although you didn't need to say it three times
Thank you too for implementing the changes in 3.5
@Nightowl sorry, there was an error message from the forum software that made me think that my first two attempts to post were unsuccessful.
@dc42 said in Spindle inactive on resume:
@dc42 Thank you
