Solved Milling motor control - Duet3/PWM Converter
Thanks, @dc42, I'll check it out
Just out of curiosity, how do I find out what the Q setting should be?
Is this information relative to the PWM controller, which is advertised as being 1kHz to 3kHz?
Thanks
@Nightowl its more relative to VFD
@Nightowl said in Milling motor control - Duet3/PWM Converter:
Is this information relative to the PWM controller, which is advertised as being 1kHz to 3kHz?Yes, use between 1000 and 3000.
Some progress!
Using the code below, I can now start/stop the motor with M3 Sn and M5 respectively, but I can't change the speed: it is constant at 4,000RPM, which suggests to me that the voltage required to change the speed isn't there. Possibly a fault with the PWM converter?
Here's the code:
; Milling motor and relay configuration M950 R0 C"vfd+out7" L0:25000 Q1000 ; enable router relay on out7 M563 P0 S"Sorotec" R0 ; assign spindle 0 to tool 0 and name it Sorotec T0 ; select tool 0 M5 ; ensure motor is turned off
@Nightowl have you adjusted the variable resistor on the top? have you set the VFD up for PWM control? I had to change some of the registers on my VFD to use PWM rather than RS485
If you mean this one (arrowed), no I haven't:
I'm not using a VFD, though. Just following the instructions from the Ooznest website, the M950 guide and this document.
I've just noticed point 2 indicates the "5V/24V PWM input signal level option" should be set to 5V, so I'll need to check that...
One thing I've checked - very carefully, is the voltage across the 12V and GND connectors, adjacent to the 5V PWM connectors, on the Duet control board, and they're only providing 6V.
Also, the voltage across terminals GND and AO on the PWM board doesn't change when I adjust the motor speed (without the cable connected to the motor, so there's no load) from M3 S1000 to M3 S25000
That can't be right, surely?
Also, the jumper on the PWM board is set to 5V.
@Nightowl can you just confirm where the PWM is wired to on the duet board?
Certainly. The pins on the PWM board are connected to the Out9 VFD\Laser\Servo Drive header:
Port 1 (PWM in -ve) to 5V_Ext
Port 2 (PWM in +ve) to Out9
Port 3 (Power Supply 12-30V) to 12V
Port 4 (Power Supply GND) to GND
Port 5 (Voltage Out GND) to GND
Port 6 (Voltage Out +ve AO) to the motor plugThere is a loop between Ports 4 and 5, and this is also connected to the GND wire on the motor plug.
The third wire from the motor plug is connected to the PSU 24V +ve of the PSU.
@Nightowl thats where you'll be going wrong then as the header you're using is always on (i think). change numbers 3 and 4. it'll also probably explain why its always on at power up without that relay. i would just wire them to an out connector and switch your M950 accordingly.
@Nightowl ah bugger, you're right. i looked at the diagram wrong
All sorted, thank you gentlemen!
It was in fact down to way the PWM converter was connected to the Duet board.
I'll amend my diagram and publish it here (and delete the earlier one!
Here's the updated connection diagram:
...and this is the code from the config.g file:
; Milling motor and relay configuration M950 R0 C"vfd+out7" L4000:25000 Q1000 ; enable router relay on out7 M563 P0 S"St George" R0 ; assign spindle 0 to tool 0 and name it St George T0 ; select tool 0 M5 ; ensure motor is turned off
Note: I have used this relay to provide mains power to the milling motor, which is activated from Out7 in this case. I guess any Out could be used, but the code would need to be changed accordingly.
Many thanks to @dc42 and @jay_s_uk for helping me resolve this, and I hope this diagram will be of use to others.
