    Large Format Dowell to Duet conversion
    362
    35.8k
      T3P3Tony administrators @Charles Fraser
      @charles-fraser It looks like the 3.3V regulator & possibly other ICs on the 3HC was blown by the 3d touch. I suspect given that it caused issues before that it is faulty, I don't know much about the 3d touches but if they are the same as the BL touch internally they should not blow the board by just mis wiring.
      Yes you need to replace the 3HC
      Charles Fraserundefined 2 Replies Last reply Reply Quote 0
      • Charles Fraserundefined
        Charles Fraser @T3P3Tony
        @t3p3tony
        Okay I will as soon as I have some money. Is there a way to diagnose what caused this? Is a fan wired the wrong way or a 3D touch really able to blow a whole board?
          @t3p3tony hi Tony, I have the replacement 3HC now and am awaiting a BL Touch to arrive next week.
          I’ll try to reconnect the new 3HC and rewire it as it was before just leaving out the fan and 3D Touch.
            @charles-fraser sounds good.
              @t3p3tony Hi Tony,
              Sorry for the radio silence. The Marquee that I am storing the 3D printer in became quite damp and would drip with moisture when it had rained and any sun shone on a cold day, dispite the cotton inner lining and ventillation I had made for the dome. So I wrapped up the printer in some synthetic sheets and tarps to mothball it over winter. I am now planning to get back into it, starting in the next couple of weeks. I will work to connect everything only through the second (hopefully not faulty extruder block).
              Thanks
              Charles
                @t3p3tony marquee was destoryed in the storm. Project is mothballed till I complete/afford an upgrade to the frame to include cbearm linear actuators from openbuilds to mount my MDPH2 extruder on as per Dr. D Flo’s work
                Thanks for your help getting this far
                  That's sad to see. Hopefully you can get it back on track.
                  Charles Fraserundefined 1 Reply Last reply Reply Quote 0
                    Charles Fraser @Phaedrux
                    Big Green Machine Update:
                    @dc42 @T3P3Tony @chrishamm @Phaedrux
                    Hi dear Duet team and community. I’m happy to say my Green Camp business is making income so I can afford to keep making some progress:
                    Update:
                    1.cutting down the Dowell frame so it fits in my garage:
                    2: upgrading the X-Y gantry with openbuilds’ 1500 C-Beam Linear Actuators:
                    This will allow me to run the Massive Dimension MDPH2 Extruder (I crowdfunded for one last year and have it on my desk waiting) just like Dr. D Flo is teaching us how:
                    https://youtu.be/s27CzktFDCg
                    link text
                    Present situation:
                    • The 6HC, PU and Raspberry survived being drenched for 3 days in the hurricane!!! (Kudos to Duet!!!)
                    • Old 3HC shorted by fan with and needed replacing
                    • New 3HC has arrived needs to be fitted and firmware updated.
                    • What’s the console command that updates the 6HC and 3HC again please?
                    • In order that I don’t fry another 3HC, I need to learn how to determine the polarity of the wires of the fan and the pins on the board to match them
                    • I need to work out what is the expansion board I need to drive the MDPH2
                    • I need to workout the firmware config file. I will ask Dr. D Flo for his
                    • I need to work out how to reattach the 4 X lead screws for the Z axis / heater bed after I cut them down to match the decrease in size of the printer that I had to make so it would fit in my garage.
                    Charles Fraserundefined 1 Reply Last reply Reply Quote 1
                      Charles Fraser @Charles Fraser
                      So latest update is that I have installed all of the C-beam actuators, installed new ball thread rods and cut those and the slide rods to fit onto this frame since it has been cut down to fit inside the garage.
                      The next steps would be to:
                      • Define what parts are still needed for the printer & order
                      • Plug kinematics (X Y), test
                      • Plug Z Axis, test
                      • plug endstops, test
                      • plug probe, test
                      • plug heaters, test
                      • plug bed, test
                      • leave the AC to the end
                      • connecting the extruder requires a metal plate to fit onto the C-beam trolly
                      • Connecting heated bed
                      • Pellet feed system
                      • Drying pellets and testing the system
                      I am seeking help to complete this project as I lack the time and skills to complete safely.
                        Are those ball screws rusty?
                          @Phaedrux dude they are so damn rusty I had to cover them in greace and force the slidey thing up and down till it all started moving again. I could only afford to buy one new one.
                            @Phaedrux also my effort to drill custom 16mm holes for those pulleys so they fit on the ball rods was so jankey it is crazy. I tried so hard to get them centre but they are anything but centre. I finally found some new ones with 16mm bores and I will bang those ones off and replace them with these new ones. At least those were good for proving the concept. If I have to buy more ball rods I will.
                            I'm looking on upwork for someone to come spend some time with me to work on the machine and get it going as I don't have the time to look after the machine now and it's getting rusty.
                              Charles Fraser
                              NB: Since I started this project a very capable (but not very friendly) engineer, Dr. D Flo, has started building with the same ingredients. I did reach out to him for help so we can print our green camp system shelters for refugee camps etc but he blocked me. Anyway, he seems to have it all working. Have a look how Dr. D Flow built a similar printer using Duet and this extruder in this 4 part series here:
                              Part 1:
                              https://www.youtube.com/watch?v=m7JpumMS0Po
                              Part 2: https://www.youtube.com/watch?v=xP074X8fUu8&t=1192s
                              Part 3: https://www.youtube.com/watch?v=sW0k0BZvWno&t=1749s
                              Part 4: https://youtu.be/s27CzktFDCg
                              • EC_Engineeringundefined
                                EC_Engineering
                                Hello Charles,
                                How are you?
                                I am hoping to do the same upgrade to my Dowell.
                                How is the printer going? If you were to upgrade the printer again, would you do the same upgrade?
                                Is there any tips that you havent posted I should know about?
                                Many thanks,
                                Ryan
                                soare0undefined 1 Reply Last reply Reply Quote 0
                                • soare0undefined
                                  soare0 @EC_Engineering
                                  @EC_Engineering
                                  Upgrading a Dowell, is easier then building a new printer, as you have all basically... preassembled. I assume that by now you figured how though. Still, if you are not much enough in the rabbit hole, and by rabbit I mean hardware and coding too, it is pretty overhelming.
                                  My dowell, wich WAS a DH8, is working now again, better than previously, but you may want to start a new topic for it, if did not until now, as it is not a simple task.
                                  Other than stepper drivers, and power supply (and yes, power button, hehe), I removed all electronics on it, and restarted with some DUET boards. They did the job, even if the interface is ... like 90s. I would use some Klipper boards (BTT and stuff), but for this project... nah... to much work.
                                  Good luck, and if you are starting some thread, you are welcome to ask. If you are not very skilled in hardware and coding, just ... use it as it is, otherwise you may fail. Sorry for being blunt, but it is the truth, unless you will hire somebody skillful enough...
