    not able to get a good first layer using 3PL and bed mesh
    3.2k
    • moth4017undefined
      moth4017 @Phaedrux
      @Phaedrux ```
      ; homez.g
      echo "home Z.g "
      G90 ;Set to Absolute Positioning
      G1 F6000 X155 Y184 ; make sure X Y centreed
      G30 F2000 ;Single Z-Probe
      G1 Z18 F4000 ;move away a little
      ;M122 ;send Diagnose to console
      no skew xy  already checked ,  probe looks fine i did a repeatability test  results "0.161 0.166 0.163 0.163 0.163 0.163 0.161 0.161 0.163 0.163, mean 0.162, deviation from mean 0.001"
      ![Capture1.PNG](/assets/uploads/files/1670646339712-capture1.png)
      moth4017undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • moth4017undefined
        moth4017 @moth4017
        @moth4017 ive tried a few height maps some with just 4 point and others with 36 point non seem to make a differance.
        moth4017undefined 1 Reply Last reply Reply Quote 0
        • moth4017undefined
          moth4017 @moth4017
          @moth4017 by the way my bed is very flat i put a straight edge on it last night and could not get a 0.05 mm feeler gauge under it
            Phaedrux Moderator @moth4017
            @moth4017 said in not able to get a good first layer using 3PL and bed mesh:
            The flat bed and the image showing some twist would suggest otherwise. 😉
            • moth4017undefined
              moth4017 @Phaedrux
              @Phaedrux would you expect the bed mesh to compensate for this twist?
                A Former User @moth4017
                This post is deleted!
                • moth4017undefined
                  moth4017
                  ok i can get a 4 point mesh to this
                    I would suggest loosening the bolts for the XY stage, checking with a square and retightening.
                    • moth4017undefined
                      moth4017
                      2nd.jpg same result
                      • moth4017undefined
                        moth4017 @moth4017
                        @moth4017 i made changes to get the 4 point mesh this level
                        • moth4017undefined
                          moth4017 @moth4017
                          @moth4017 I just did a check to see if i could see my Z motors turning , i have a gear box's on the z axis so i should be able to see the steeper motor turning , but there is no movement
                          • moth4017undefined
                            moth4017 @moth4017
                            @moth4017 start G code befor a print
                            M104 S[first_layer_temperature] ; set extruder temp
                            M140 S[first_layer_bed_temperature] ; set bed temp
                            M190 S[first_layer_bed_temperature] ; wait for bed temp
                            M109 S[first_layer_temperature] ; wait for extruder temp
                            G28 ; home all axes
                            G29 ; mesh bed
                              Is the gearbox having backlash?
                              You can send M122 to check if mesh is active. If you have G29 in your slicer start gcode it should be. Do you have a mesh.g file?
                              • moth4017undefined
                                moth4017 @Phaedrux
                                @Phaedrux no back lash gear box belt driven ,
                                M122
                                RepRapFirmware for Duet 3 Mini 5+ version 3.4.5 (2022-11-30 19:41:16) running on Duet 3 Mini5plus WiFi (standalone mode)
                                Board ID: 3R9YY-6T9RL-D65J0-40KMN-2UW2Z-RHYT0
                                Used output buffers: 1 of 40 (18 max)
                                Static ram: 103652
                                Dynamic ram: 111396 of which 124 recycled
                                Never used RAM 23492, free system stack 126 words
                                Tasks: NETWORK(notifyWait,13.9%,237) HEAT(notifyWait,0.0%,320) Move(notifyWait,0.1%,265) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,328) CanClock(delaying,0.0%,339) TMC(notifyWait,1.2%,82) MAIN(running,83.9%,347) IDLE(ready,0.0%,30) AIN(delaying,0.8%,263), total 100.0%
                                Owned mutexes: WiFi(NETWORK)
                                Last reset 00:49:54 ago, cause: software
                                Last software reset at 2022-12-11 09:53, reason: User, GCodes spinning, available RAM 23540, slot 1
                                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                Error status: 0x00
                                MCU revision 3, ADC conversions started 2994886, completed 2994886, timed out 0, errs 0
                                Step timer max interval 1476
                                MCU temperature: min 34.9, current 38.4, max 41.7
                                Supply voltage: min 23.6, current 23.9, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                Heap OK, handles allocated/used 99/11, heap memory allocated/used/recyclable 2048/1652/1440, gc cycles 0
                                Events: 0 queued, 0 completed
                                Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 7, reads 9988, writes 68, timeouts 0, DMA errors 0, CC errors 0
                                Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 9986, writes 69, timeouts 0, DMA errors 0, CC errors 0
                                Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 79, reads 10050, writes 6, timeouts 0, DMA errors 0, CC errors 0
                                Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 104, reads 10042, writes 14, timeouts 0, DMA errors 0, CC errors 0
                                Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 252, reads 10024, writes 32, timeouts 0, DMA errors 0, CC errors 0
                                Driver 5: standstill, SG min 0, read errors 0, write errors 0, ifcnt 251, reads 10023, writes 33, timeouts 0, DMA errors 0, CC errors 0
                                Driver 6: standstill, SG min 0, read errors 0, write errors 0, ifcnt 245, reads 10024, writes 32, timeouts 0, DMA errors 0, CC errors 0
                                Date/time: 2022-12-11 10:43:08
                                Slowest loop: 68.52ms; fastest: 0.10ms
                                === Storage ===
                                Free file entries: 10
                                SD card longest read time 4.9ms, write time 3.0ms, max retries 0
                                DMs created 83, segments created 8, maxWait 173411ms, bed compensation in use: mesh, comp offset -0.065
                                === MainDDARing ===
                                Scheduled moves 560, completed 560, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
                                === AuxDDARing ===
                                Bed heaters 0 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0
                                Heater 0 is on, I-accum = 0.1
                                Heater 1 is on, I-accum = 0.3
                                Segments left: 0
                                Movement lock held by null
                                HTTP is idle in state(s) 0
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Trigger is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                SBC is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Aux2 is idle in state(s) 0
                                Code queue is empty
                                === Filament sensors ===
                                Extruder 0 sensor: ok
                                === CAN ===
                                Messages queued 26948, received 0, lost 0, boc 0
                                Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 14971/0/0
                                Tx timeouts 0,0,14971,0,0,11976 last cancelled message type 4514 dest 127
                                === Network ===
                                Slowest loop: 74.73ms; fastest: 0.00ms
                                Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                HTTP sessions: 1 of 8
                                = WiFi =
                                Network state is active
                                WiFi firmware version 1.27
                                WiFi MAC address f0:08:d1:02:a1:0b
                                WiFi Vcc 3.34, reset reason Power up
                                WiFi flash size 2097152, free heap 26440
                                WiFi IP address 192.168.0.19
                                WiFi signal strength -54dBm, mode 802.11n, reconnections 0, sleep mode modem
                                Clock register 00002002
                                ;mesh.g
                                echo "mesh.g"
                                M561
                                M98 P"/macros/ProbePickUp"			; probe pick up; absolute positioning
                                G29 S0
                                M98 P"/macros/ProbeDropOff"			; probe pick up; absolute positioning
                                  Were you using your detailed mesh or the simplified 4 point? The movement could be incredibly hard to see with a mean error of -0.006mm
                                  • moth4017undefined
                                    moth4017 @Phaedrux
                                    @Phaedrux hi i was using the 4 point mesh , but the difference in nozel height from the bed was bad enough for the left hand side not to stick to the bed and the right hand side had a nice squish , see photo
                                    above
                                    • moth4017undefined
                                      moth4017 @moth4017
                                      @moth4017, 1 step on my stepper motor moves the bed 0.025mm, using 1.8deg steppers
                                      Phaedruxundefined moth4017undefined 2 Replies Last reply Reply Quote 0
                                        If your single step distance is 0.025mm and the mesh points have a difference of ~0.006mm you would be depending on microstepping for position. Perhaps between that and the gear box there isn't enough actual movement happening?
                                        Regardless, I still think there is an issue with skew.
                                        • moth4017undefined
                                          moth4017 @moth4017
                                          @moth4017
                                          if i do a height check G30 s-1
                                          results
                                          12/11/2022, 11:04:22 AM Stopped at height 9.786 mm
                                          Cen
                                          ProbeDropOff
                                          12/11/2022, 11:04:19 AM Stopped at height 10.011 mm
                                          RL
                                          12/11/2022, 11:04:15 AM Stopped at height 9.952 mm
                                          RR
                                          12/11/2022, 11:04:11 AM Stopped at height 9.898 mm
                                          FR
                                          12/11/2022, 11:04:08 AM Stopped at height 9.877 mm
                                          FL
                                          looking at the height map the rear left (RL)corner is highest, if i look at the probe height for RL 10.011 is that the correct?
                                          • moth4017undefined
                                            moth4017 @moth4017
                                            @moth4017 if i measure the thickness of the first layer at each corner ,
                                            layer height requested 0.3mm, nozzel dia 0.8mm
                                            FL 0.35
                                            FR 0.19
                                            RR 0.33
                                            RL 0.44
